Question about Oreck XL21 Bagged Upright Vacuum
Belt is ok. difficult to push - Oreck XL21 Bagged Upright Vacuum
Riccar vacuum 8625 vacuums the floors;but does not seem to have suction for the carpets
The belt may look fine but could have lost elasticity. Stretch belts will lose elasticity and should be replaced at least once or twice per year. If the brush strips are worn or frayed it will not pick up properly.
Mar 01, 2015 | Riccar Vacuums
Is there an easy way to see if a drive belt may be broken? It's so difficult to push my Kenmore upright vacuum!
Well there is only turning the vacuum over and see if the brush is rotating.
If it is not moving then you need to replace the belt.
If you need to know how to remove the bottom plate to replace the belt, please post the model number, the numbers you posted above are not the kenmore model numbers, the model numbers will look like this
316135912,FPF311PHSB, FGF316WGSK
Feb 15, 2010 | Kenmore 35912 / 35913 Progressive Upright...
Oreck XL hard to push
yes. it might be broken. you will need to remove the 5 screw on the bottom and see if the belt is burned. it more that likly is.
Oct 16, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Self propel does not work and it is real hard to push this way. We checked the belts and they both ok. Not sure what else to look at, the on line manual does not show any information
Hi there SmartAlec from NelsonVacuums.com.au here. Ok on this particular machine the belts strtch quite a bit and make the machine very hard to push even though the belts seem to be ok. I would recommend first making sure that the driving self propell is actually working at all. Tip the machine on its back all flat and turn it on. When you push handle up and down you should see a pair of wheels spinning one way then the other (corresponding to the way handle is pushed or pulled). As long as the wheels are moving then it is just that the wide flat belt just needs changing even though it is not broken. If the wheels are not turning at all even though belts are in place then you have a more sinister problem that will require a technition to check over.
hope this helps!
happy Vacuuming :)
Aug 12, 2009 | Hoover U6616-900 WindTunnel Bagless...
HOW DO I REPLACE THE DRIVE BELT ON A HOOVER WIND TUNNEL SELF PROPELLED
Take the brush belt and slip it over the pull into the groove. Then take the flat belt and hook onto the motor shaft and then pull belt over pull and push it around the entire pulley. It can be difficult but after the first time it is easy. You have to push the belt up with your thumbs so the belt will wrap all the way around
Apr 06, 2008 | Hoover Company Wind Tunnel U53019 Upright...
DC07 Very difficult to push forward.
on the front of the base there are 3 very small rollers made out of rubber, these are either just dry and won't turn or worn and or damaged,
that is your problem / honest its that simple
Oct 13, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Oreck XL21 Bagged Upright Vacuum Logo
27 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
