Question about Samsung Rechargeable 3D Glasses
My samsung rechargeable 3d glasses appear to have died. Hardly used and only owned for about 3 months. SSG-3570CR/ZA
SSG-3570CR/ZA. The LED won't light up when it is plugged in to the usb port. Pushing the earpiece button won't activate pairing or power. I'm having the same problem with two pairs, similar age and use.
  • Mike Dini
    Mike Dini Feb 19, 2014
    After some research, I found out that the glasses have a "reset" pinhole next to the charge port. After reset, the glasses worked fine. I still don't know what tripped the reset, unless it is the USB charger I'm using. Haven't had any trouble with other devises using the charger, though.
  • 10 Answers
SOURCE: Wireless headset pairing
With the Samsung WEP210 this is a common problem (which is actually just a user error)
This is what you do:
1. Of coarse make sure the headset is charged
2. Make sure the bluetooth headset if OFF
3. PRESS and HOLD the top/middle (on/off) button until the light stays on (it will blink then should stay on continuously). That means it is now in pairing mode.
4. Tell you phone to search for bluetooth devices.
5. It should find the headset, and by default type "0000" to pair your new headset**
**You can use whatever pin code you like......but I would recommend the default which is four zeros.
Posted on Dec 10, 2008
  • 3 Answers
SOURCE: Cant get my Samsung SBH500 to pair with my Samsung MP3 PLAYER,yp-t10
the directions from Samsung to pair the headset was way off. You need to hold down the main button then turn on the headset. Only then will the headset go into pairing mode by maintaining a solid blue light. It took me a couple of days of troubleshooting and experimenting to realize this pairing method. I just hope that this problem is only due to my headset because I assume a lot of people who buy this headset and try out Samsung's directions will become very frustrated. I almost returned the product and I am sure many others would too.
Posted on May 31, 2009
benwabnick
  • 2404 Answers
SOURCE: Samsung 932B Plus monitor does not turn on. Blinking LED
If you can open up the monitor from the back and get the cover off. Look on the power board and see if there are any puffy capacitors, most of the caps will have a silver flat top but if there are any bad ones, they will have a puffy top that stick up.
If you see any then make sure you replace them with capacitors of the same Uf rating and at least the same volts or more.
If you don't see any puffy caps then that means the screen is bad and the whole monitor would need to be replaced.
Posted on Nov 30, 2009
Testimonial: "Opened the LCD monitor up, and it was as he said. A bad capacitor. Thanks!! Replied within minutes."
faceofftech
  • 185 Answers
SOURCE: pair my samsung sbh170 headphones
set your mp3 ready to find your headphones.
1. Turn headset off 2. press and hold the "calling button" ---do not let go--- 3. slide the on/off switch to "on" don't let go of the "calling button" 4. it will flash blue red and purple (twice) then will turn solid blue 5. let go of the button 6. your mp3 should be able to find it now (that puts headset on discovery mode)
if it works for you don't forget to rate me
thx
Posted on May 25, 2010
pgh_pa_guy
  • 2992 Answers
SOURCE: hi, i have a samsung T220HD
Bad capacitors are a very common problem. They're like buckets that fill up and store energy so other parts have power to do their jobs. When the capacitors go bad they don't charge or a very slow to charge, and this can be your trouble. This site addresses his exact problem on your model, so you can see if self-repair is something you'd like to try. Good luck, and thanks for using Fixya!
Posted on Jan 06, 2011
SONY BRAVIA 3D ANDROID TV MODEL-43W800C 3d active or passive in bangladesh? Which 3d glass required?
A 3-D glass won't be effective; especially in Bangladesh. A 3-D mirror; which look like a (kaleidoscope) is needed to see images in 3-D; in your country. Look for that.
Jul 04, 2016 | Sony Televison & Video
Which brand 3D glasses do you like to use?
You need to know what brand is compatible with your TV.
Apr 13, 2016 | Samsung 3D GLASSES ADULT BATTERY TYPE...
I want to buy a pair of 3D glasses,which brand do you think is better?
There should be a part number in your owners manual that will be compatible with your TV
Apr 09, 2016 | Samsung 3D GLASSES ADULT BATTERY TYPE...
Half of my TV screen is 3D all the time
It's seem to be a T-Con board problem. If you don't deal with electronics repair, call to a service center. If you deal with it, first thing is to search for service manual or schematic diagram. For more articles on how to repair this issue visit jestine's yong blog.
Cheers !
Dec 23, 2017 | Samsung UN46C8000XFXZA UN46C8000 46 3D LCD...
I just want a manual and how long do you charge them for
Hi christosyard,
The battery takes about 2 hours to charge fully and with one charge it will last for about 30 hours. You can check the review of some user of Samsung Rechargeable 3D Glasses here.
Thanks for using Fixya.
Feb 10, 2011 | Samsung Re-Chargeable 3D Glasses For...
My Samsung L73 digital camera will not charge. Batt is dead. When I plug the charger in, the camera led turns green, then orange, then off. No matter how long I leave the charger plugged in, it will not...
Have you recharged the battery many times since you owned it? Did you leave it alone for an extended time and it completely discharged and died? Rechargeable batteries sometimes only last 3 years.
Jun 14, 2010 | Samsung L73 Digital Camera
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Samsung Rechargeable 3D Glasses Logo
70 people viewed this question
Jerry Greenberg
Jerry Greenberg
