Question about Amana Front Load Washing Machine Washer Soap Dispenser Nfw7200tw
Need picture of tech sheet inside dryer amana 7200 series
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Amana 7200 dryer, runs but has no while running.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 03, 2011
hunter19_46m
  • 7482 Answers
SOURCE: I have a 7200 series
Hi ket1011...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me
Posted on Jul 31, 2011
SOURCE: amana 7200 series gas dryer wont dry
need more info
Posted on Aug 22, 2012
SOURCE: My Amana 7200 Dryer will not heat???
Heating element in drier may be burnt out.
Posted on Nov 12, 2012
Amanda dryer 7200 series error code E5 code?
The E5 error code is only referenced by a technician. More than likely it refers to a circuit board problem. Only solution is to have it replaced by a technician.
Apr 18, 2014 | Amana NED7200TW Electric Dryer
How to find and replace the thermistor on an amana ned7200tw dryer?
Hi Marissa,
Have you run the diagnostic program to find the fault?
Your problem could be the high limit thermostat, thermal fuse or the heater. Take the panel off at the back and locate the tech sheet. On the tech sheet you will find the instructions for running the diagnostic program. Run the diagnostic program and this will tell you where the problem is and the corrective actions needed.
It is a bit involved to get at the thermistor, but easy to replace. see http://www.youtube.com/watch?v=mCmGRijX_14, as this leads you through the process very well.
Feb 02, 2014 | Amana NED7200TW Electric Dryer
How do I acess the inside of an Amana 7200 dryer to replace parts
You could access to inside any dryer from top or front or back on most brands
Dec 08, 2013 | Dryers
How do i acess the inside of a ammana 7200 dryer
Consult your owners manual; if you can't find your manual go to this site: http://www.searspartsdirect.com/?SID=MerchSearsxHSTopNavPartsDirect you should be able to download the manual there. Good Luck!
Dec 08, 2013 | Amana NED7200TW Electric Dryer
Amana Dryer model PDLE330RAW parts manual and service manual. I need these to fix my Amana dryer that I purchased in December of 2001. Where can I find one ?
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Dryer-Parts/Model-DLE330RAWPDLE330RAW/1268/0151200?pathTaken=&prst=0&shdMod=DLE330RAW-PDLE330RAW
Remember, on all older Amana (and some of the new stuff as well) you will need the BOM number, which on yours will be DLE330RAW-PDLE330RAW. The link above is to Sears, because they seem to have the easiest pages to use as far as breakdowns. Would look into other places with the part numbers for better pricing. No service manual that I can find on the unit anymore, and can't find a tech sheet for it either. Parts list doesn't even show one, but you might have one under the console that was put there during manufacturing.
Nov 08, 2013 | Dryers
Need a wiring diagram for a whirlpool gas dryer model ggq8811lwo
If you open the control panel heading there should be a wiring diagram and a tech sheet inside. In some rare occasions these sheets may be inside the cavity of the dryer.
Jun 20, 2012 | Whirlpool Dryers
My frigidare affinity dryer is only starting on delicates and touch up, can you tell me why this is happening?
Hi.
If machine runs only in low heath cycles, then there is a problem with timer control, low heath selector, or heating assembly (cycling thermostat).
The first thing to do would be locating the tech sheet. The sheet is tucked inside an envelope located inside the control panel assembly. In the tech sheet you will find instructions to run a diagnostic cycle. The diagnostic cycle will return an error code that will help locating the fault.
With different Frigidaire Affinity dryers you need to press and hold Pause Cancel and SELECT for about ten seconds, then leave, put selector to NORMAL, temperature selector to HIGH HEAT and touch START to run the diagnostic cycle. The procedure for this specific model is described in the tech sheet.
Regards.
Ginko.
Nov 19, 2011 | Dryers
My frigidare affinity dryer is only starting on delicates and touch up, nothing above that
Hi.
With different Frigidaire Affinity dryers you need to press and hold Pause Cancel and SELECT for about ten seconds, then leave, put selector to NORMAL, temperature selector to HIGH HEAT and press START to run the diagnostic cycle. The procedure for this specific model is described in the tech sheet.
It seems the service manual for the Maytag Neptune dryer MDE4000AYE is out of print, I can't find one through Maytag. Any idea where I could find one? thanks, Ken
lift the consol you will find the tech sheet. inside the dryer. do you need a tech sheet? if yes you will find it inside the dryer.
Jan 05, 2010 | Maytag Neptune MDE4000 Electric Dryer
Amana Front Load Washing Machine Washer Soap Dispenser Nfw7200tw Logo
15 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
