Question about D-Link Dpr-1040 Wireless G Multifunction Print Server
I would like to use DPR-1040 at HP laserjet 1212MPF, do you have any driver for ??
2 Suggested Answers
SOURCE: HP laserjet P1005
Go to the printer properties, you can go from Start-->Printers and Faxes. Select the printer (it should say something like, HP LaserJet P1005 on DPR1260 ..... make a double click on there. Then select Printer -----> Properties. Then go to Ports, and DE-SELECT the box that says: Enable bydirectional compatibility. IT SHOULD BE NOT SELECTED. Then Select Apply, and then Acept. After doing this, the printer should start working.
Posted on Jun 25, 2009
DPR-1040 does not connet wirelessly
Wireless router must not use WPA2. Change to WEP or WPA or buy a more modern printer server,
Jan 05, 2014 | D-Link DPR-1040 wireless print server,...
Printing on HP Laserjet 1020 connected to the network through DLink DPR-1020 print server
did you resolve this issue , beacause have the same problem with a Toshiba e studio e223 ?
Jan 31, 2013 | D-Link Dpr-1020
D-Link DPR 140 doesn't work with Windows 8?
Windows 8 is still new and there are some companies like D-Link which might not have the firmware for their products which are compatible with Windows 8 yet. I tried searching for a firmware for your product and I can't find one.
I suggest that you contact D-Link regarding this issue, they should have the fix for this and I'm sure that a lot of people are experiencing this same issue. This happens when new operating system are produced in the market. http://www.dlink.com.au/corporate/contact/
I also suggest that you install RadarSync in your computer. It's a technician's software. What it does is it automatically updates all outdated drivers in your computer. It works great with Windows 7 and Windows 8.
I hope this helps!
Carlo
Nov 26, 2012 | D-Link Dpr-1040 Wireless G Multifunction...
Have a dlink print server dpr1040 and dlink wireless router how do i print wireless
DPR-1040 information - http://www.dlink.com.au/products/?pid=777
All of this is from the manual located at link above under the resources tab.
Wireless Setup
WPS (Push Button Configuration)
WPS simplifies the process of connecting to a wireless network to a touch of a button. To use WPS you must have a WPS compatible wireless router,if you do not then you will need to manually configure the wireless connection in the web configurator (see Web Configurator below).
1. After following the hardware installation steps in section 3, ensure your wireless network is operating normally. When ready, press the WPS button located on the side of the DPR-1040. The blue LED should start flashing repeatedly.
2. Within 120 seconds, press the WPS button located on the wireless router you will be connecting to. This button may also be located in the router's web configuration pages labeled "Push Button Configuration (PBC)".
3. If successful, a wireless connection will be established between the two devices.
This connection is secure and uses automatically generated encryption keys; you do not need to remember them.
Note: If you experience problems connecting to a device, please try again. If you still experience problems, the device you're connecting to may be incompatible with the DPR-1040. Also, make sure you are connecting to a router or access point (AP).
Web Configurator
1. After following the hardware installation steps in section 3, ensure your wireless network is operating normally. When ready, type the IP address of the DPR-1040 into your browser, the default IP address is 192.168.0.10. If this does not work, use the PS-Link utility to find out the IP address.
2. Upon accessing the web configurator, click Setup > Wireless Setup.
3. On the next screen, enter the wireless network settings as provided by your network administrator.
4. Click Apply Settings, the DPR-1040 will restart and the wireless setup is complete.
Note: If your wireless connection does not work, check that you have entered the correct network settings into the Wireless Setup screen.
May 18, 2012 | D-Link DIR-412 Mobile Broadband Wireless...
Is hp 1040 fax compatable with pcs
No it is not. You need an interface connector in order to uswe it with a computer.
Sep 14, 2009 | HP 1040 Plain Paper Inkjet Fax
HP laserjet P1005
Mar 04, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
I need a disassembly guide for the HP 1040 FAX (or 1010)
I have HP 1010 manual here : HP LaserJet 1010/1012/1015 Series Printer Service Manual
I do not have 1040, I have cleaning instructions for HP1040, if the printhead looks tuck, then clean the encoder strip, see cleaning instructions here.
Feb 01, 2009 | HP 1040 Plain Paper Inkjet Fax
D-Link Dpr-1040 Wireless G Multifunction Print Server Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
