Question about Huawei mediapad 7 s7 931w wifi tablet
Sky Go on huawei
Is it possibly to play sky Go on my Mediapad?
How do I turn off offline on my Huawei tablet
It's simple you have to switch off data or wifi
Apr 19, 2016 | Huawei mediapad 7 s7 931u tablet
How to unlock Huawei MediaPad 7 Lite locked after "too many patterns attemts" MediaPad, SpringBoard General. ... for this tablet s7-931w
First solution is to use Google account associated with mobile.You need to log in into your Google account and then you can disable or change the pattern lock.
Second solution is to boot into recovery mode and reset the tablet - you will loose all you data however.
The third solution is only for techies and involves using the Android debug bridge to reset the tablet - not for the faint hearted.
May 11, 2014 | Huawei mediapad 7 s7 931w wifi tablet
Huawei mediapad 7 is not charging when plugged in over a long period the battery gets hot however and the screen tends to flicker if it does come on
Hate to say this but it sounds like your battery is fried. It takes the charge but since the battery is no good it won't hold the charge.
Mar 16, 2014 | Huawei MediaPad 7 Lite 3G WIFI S7-931u IPS...
Huawei mediapad 7 not charging when plugged in, battery gets hot but doesn't charge
Hi Susan, did you solve your problem. I have the same with my Huawei. If yes please send me the solution - e-mail Georgi.Fotev@abv.bg
Thank you.
Mar 16, 2014 | Huawei mediapad 7 s7 931u tablet
From where i download OS update for S7-312u mediapad huawei google
check here...
http://forum.xda-developers.com/showthread.php?t=1671527
Feb 13, 2014 | Huawei S7-312U Mediapad 7" Android 3.2...
Password crack
hard reset press power and volume plus together when android gear appear release the power button and volume plus press volume down.wait if rebooting says ok
Jun 17, 2013 | Huawei mediapad 7 s7 931w wifi tablet
Error 7 when i try sky go movies
according to the sky help forums at http://helpforum.sky.com/t5/Using-Sky-Go/Sky-Go-Errors-5-7-amp-9-on-iPhone-iPad-amp-iPod-touch/td-p/208239/page/4
Try the following steps to resolve this issue:
  1. Locate the Sky Go app on your Mobile device.
  2. Hold down the icon until the app wobbles (You will see a White Circle with a Black Cross symbol, press on the cross to remove the app)
  3. You will then be asked to confirm you wish to delete the app - Press Delete the Sky Go App will then be removed
  4. Go back to the App Store and reinstall the Sky Go App. This can be found by searching for BSKYB
  5. Access the Sky Go app again and you should be able to view content after you sign back in using your Sky ID & password.
Hope this helps
Dec 25, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Huawei mediapad 7 s7 931w wifi tablet Logo
Top Huawei Tablets & eReaders Experts
Terry Hair
john smith
Shaukat Bhutto
Level 1 Expert
Are you a Huawei Tablet and eReader Expert? Answer questions, earn points and help others
