Question about Samsung Televison & Video
Samsung eu55f8000 pip - Samsung Televison & Video
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
Oct 19, 2014 | Samsung New 55"" Class 54.6"" Diag. Led...
TURN OFF PIP SAMSUNG LN32D403E4D
If there is no buttlon on your remote that says PIP, then go into your user menu and get into the picture settings. Look for PIP options and turn them off.
May 02, 2012 | Samsung Televison & Video
HOW TO ENABLE PIP ON SAMSUNG 530?
hello noni calipes,
To enable PIP on Samsung series 5 its easy.
But you should know Samsung spec first (read the manual book).
PIP can be enabled if :
1. Input must be higher or equal to componen. (Componen, PC , HDMI)
2. PIP only displayed inputs as the primary and RF and AV (SD) as secondary.
3. PIP on Samsung 530 can not swapped.
4. The higher inputs will displayed as primary.
If any questions , call samsung cervice center or you can read manual book.
I hope help you.
Thanks.
Mar 30, 2011 | Samsung Televison & Video
PIP function does not work, the settings is greyed out also! I have a wii, PS3 and freesat :)
Hi nikkicollier,
PiP for your TV works between two different sources. This means between a component source and an HDMI source or between an HDMI source and another HDMI source. PiP also works with a PC connection, e.g. when using the TV as a computer display. PiP does not work between two component sources. The setting will be grayed out when you don't have a configuration that is supported, as the Samsung TV's are usually able to automatically detect which sources are plugged in and available.
I'm not exactly sure what sort of configuration you want your PiP to work in, but try one of the following configurations.
  • TV Cable (through VCR or other via Component input) with Satellite in PiP (via HDMI input)
  • PS3 (via HDMI Input) with Satellite in PiP (via Component Input)
  • Wii via HDMI Input) with PS3 in PiP (via HDMI Input)
You can usually find an HDMI cable for much cheaper at an electronics supplies shop, Radio Shack, or on eBay or Gumtree.
To change your PiP settings:
  1. Press the MENU button on the remote control. Select Picture and press Enter.
  2. Select PIP and press Enter.
  3. Press the enter button again, and press up or down to change the setting to On and press enter again.
    Note:
    If PIP is activated the screen will display in widescreen (16:9 aspect ratio.)
  4. Press the up or down buttons to select the Source then press the Enter button.
    Select the source of the sub-picture by pressing the up and down arrows and then pressing the Enter button.
    Note: The sub-picture can serve different source selections based on the what the main source is set to.
    Note:
    You may notice that the picture in the PIP window becomes slightly unnatural when you use the main screen to view a game or karaoke.
You can download the full PDF manual for your TV here (large download at 26MB.) Much of the PIP information can be found on pages 13 and 14.
Good luck, I hope that helps.
Mar 01, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
How do I hook up PIP on my Samsung 60 inh Series 6 LED TV. Pictures and instructions please. Thank You!
The manual is here... http://downloadcenter.samsung.com/content/UM/201007/20100708133121375/BN68-02698Q-00Eng-0607.pdf The PIP instructions are on page 20.
The PIP will function using one source (thru Component, HDMI, etc.) and another being the TV tuner. THE PIP by default is thru the TV Tuner.
Oct 12, 2010 | Samsung Televison & Video
How too make work the small pip on a 52" LCD HD tv samsung
All pip or pop features must have 2 seperate and distinct video sources. With your tv you can choose to have cable split with a 2-way splitter and one feed to cable box and the other directly to a second ant connection on back of tv. If you only have 1 rf input on tv then your second source would have to be from a vcr or dvd etc. once you have 2 seperate sources going you select pip and choose what source you want and both main screen and pip screen will appear. obviously you will only have audio on main screen so if you want to hear pip you have to switch back and forth.
Dec 31, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Does the smt-h3270 cable box have pip
No it doesn't according to TWC. I have a 3270 and it doesn't support it. I got this info from the local TWC president. You can have PIP if your TV supports it by splitting the signal and watching it on another input.
Sep 26, 2009 | Samsung Televison & Video
How do you turn on pip
When using PIP on a Samsung TV, the main source you are viewing needs to be Component, HDMI or the PC Source before PIP can be used to view for example a digital cahnnels.
Jul 16, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
How to do PIP on a Samsung DLP tv
There is no PIP function described in the manual for the HL-67A510.
Jul 09, 2009 | Samsung HL-67A510 67" DLP HDTV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
