Question about GE Profile Prodigy WPSE4200A
My ge profile prodigy will not spin. model number wpse4200a0ww serial number rz142412g
vest6
  • 196 Answers
SOURCE: Spin and Agitate problem on GE Profile Prodigy WPSE4200A
This machine uses an electric water pump. I would check to motor. Remove the front panel and operate the machine to see if the motor is working. Check this by listening to the motor and watching the belt. If you hear the motor but the belt does'nt move then there may be a problem with the pulley or motor clutch assy.
As far as not draining or pumping water ? Check the wiring from the pump to the control panel. If these wires are alright then i suspect the pump.
Posted on Jan 12, 2008
SOURCE: GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Posted on Feb 01, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile Prodigy Machine not agitating
If the motor runs when it is suppose to be agitating, but the agitator does not move, pull the agitator straight up and out of the machine. Sometimes this is difficult, but you can slip a belt or similar object under the agitator, attach it to a broom handle and yank up on it. Now take the bolt out of the agitator drive collar and remove it. If you can not turn the splined transmission shaft with your fingers you are in luck and should be able to just replace the can shaped agitator drive spline. (part number WH49X10042 ) If you can turn that splined shaft with your fingers you are looking at a new transmission.
Posted on Nov 11, 2008
kram26
  • 544 Answers
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Posted on Mar 29, 2009
  • 151 Answers
SOURCE: GE Prodigy Washing machine making clunking noise
One common problem area is the clutch assembly. The clutch is built on top of the motor, the motor drives the clutch and the clutch assembly drives the rest of the washer. The clutch gets very noisy when parts inside are worn out. The shoes lining that drives the inner drum of the clutch wear off and you will get a metal on metal sound. Clutches often can be rebuilt, but sometimes they are too worn and replacing the whole clutch is the best repair. Please use this link here for clutch replace and repair info. The belt and pump may be the next items to check for noises. How to access the washer. Clutch repair help.
Posted on May 03, 2009
Why is agitator speed the same for all wash cycles on GE Profile WPSE4200A0WW
GE designed it that way. About the only difference is the agitation length of time.
Nov 28, 2012 | GE Profile Prodigy WPSE4200A
All wash cycles same on GE WPSE4200A0WW
Yes, just the agitation time is different.
My GE Profile Prodigy WPSE4200A Washer does not spinning for drying and it smells like burning rubber. But it does aggitate for washing. It is a belt issue or could be some electronic device issue?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 03, 2010 | GE Profile Prodigy WPSE4200A
Wont spin and makes alot of noise
You could check if its drum by removing the belt turn drum by hand if its okay no noise check motor pulley ....is motor ok ?
Nov 17, 2009 | GE Profile Prodigy WPSE4200A
I have a GE Profile Prodigy top load washing machine. Sometimes the spin cycle does not spin, sometimes it spins. It makes a clicking noise during gentle cycle
The gears maybe going out. Sometimes it is able to engage in the other direction which the spin, sometimes not. Washing machine have complex gears that in one way agitator works, and the other the gear locks to turn the whole tub. The clicking noise is probably the locking mechanism in the gears that has caused the whole intermittent problem.
Jul 01, 2009 | GE Profile Prodigy WPSE4200A
Washer only spins
Have you tried to unplug the machine, sometimes the control boards can get stuck and if you unplug it for say 30 seconds then plug it back in, it may reset itself. otherwise you may have to call someone these are very complicated machines.
Jun 19, 2009 | GE Profile Prodigy WPSE4200A
Ge profile prodigy make clunking before spin cycle
Is there a humming sound? Check you have the hot and cold water supply turned on. Check the water inlet hoses are not kinked.
May 03, 2009 | GE Profile Prodigy WPSE4200A
Nov 15, 2007 | GE Profile Prodigy WPSE4200A
Will not drain during spin???
Most likely your outlet filter of the machine is choked with dirt or something; clean out the filter & refit. Of course after taking of the wall plug & siphoning out the water from washer.
Sep 21, 2006 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
52 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
