Question about Landice L7 LTd Pro Sports Trainer Treadmill
Landice L7 blows the fuse
The fuse blows after a couple of hours of use
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: Landice L7 gives me a L5 reading on the screen
Your L7 error looks like L5 , but its really LS which mean lost signal. Unplug unit take motor shroud off then plug unit back in wall outlet. When looking in front unit you will see a Motor control board and there are LED lit up one of them should be an amber light this is you speed sensor which is attached to the top of your motor. Manually rotate the fly wheel and see if that light flickers if it does then your speed sensor is working properly if not replace speed sensor. The next thing to look at is the motor brushes to if they are worn unplug unit you should see slitted caps on both side of motor remove them if they are less than 3/8" they need replacing. That for the most parts should take of your problem. Call Landice @ 1800-526-3423 have the serial# handy their on all the components in the unit
Posted on Feb 28, 2010
What is the problem with the landice l7 when you the code CE
Communication Error between upper and lower board generally produced by a physical disconnection between harness and the the apparatus. Reseat the harness.
Jan 04, 2018 | Landice Exercise & Fitness
Will not come on. Has power to it. Is there a restart button? a fuse? What?
Hi Hannah.
The manual for this treadmill can be found here:
http://www.landice.com/sites/default/files/Landice_PST5_Manual%2372116_PDF%203-1-15.pdf
What stands out in these instructions is that there is a red, magnetic safety key that must be connected to the panel to run the treadmill (PDF page 4). Also there is a diagnostic mode covered on PDF page 19 that should let you find out if the treadmill thinks it has some other problem.
Hoping this helps
Good Luck
D
Nov 19, 2015 | Landice L7 LTd Pro Sports Trainer...
My landice L7 pro Trainer is not working when you press the start button the motor jolts a little the L5 shows is the display screen
It needs a lower board, does your machine have a life time warranty? Part should be covered just not the labor.
Apr 02, 2015 | Landice Exercise & Fitness
Treadmill speed is not correct for landice l7
Unit may be in kilometers. Switch to miles.
Dec 26, 2013 | Landice Exercise & Fitness
Landice L8 treadmill won't turn on
Check wall outlet for power , then if outlet is good unplug unit remove motor shroud you will see a charcoal or white ceramic fuse check it if open replace blows again immediately you have a shorted lower board. Here is the info Landice they help you with parts and get you in touch with a servicer if you need one.
Landice, Inc.
111 Canfield Avenue
Randolph, New Jersey USA 07869
(800) LANDICE
(973) 927-9010 - FAX: (973) 927-0630
service@landice.com
Apr 24, 2010 | Landice L8 LTD Cardio Trainer Treadmill
Feb 12, 2010 | Landice L7 LTd Pro Sports Trainer...
Landice L7 motor voltage in wet conditions
What do you think--what changes when something happens???
Sep 19, 2017 | Landice L8 LTD Cardio Trainer Treadmill
Landice L7 LTd Pro Sports Trainer Treadmill Logo
106 people viewed this question
Top Landice Exercise & Fitness Experts
Howard
Howard
lloyd cole
Sportsmith LLC
Sportsmith LLC
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
