Question about Advanced Fox Celerity 685 Athlon 64 Socket 939 Bare Bone Computer Configurator (ASBBCELERITY685) Motherboard
Set boot first device in 6150k8ma mb
Cant reset the boot disk order in the boot disk menu. the up /down arrows don't move and I need to install an os and high light cd rom wont work. thanks
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 64 Answers
Try to clear CMOS reset BIOS.
Posted on Feb 18, 2014
Reset my fujitsu laotop model M6210 back to factoy reset
RESTORING THE FACTORY IMAGE
The Restore Disc that came with your system contains
two utilities:
? The Recovery utility allows you to restore the original
contents of the C: drive.
? The Hard Disk Data Delete utility on this disc is used
to delete all data on your hard disk and prevent it from
being reused. Do not use the Hard Disk Data Delete
utility unless you are absolutely certain that you want
to erase your entire hard disk, including all partitions.
BOOT Priority Change
Before restoring an image, you must first verify that your
system is set up to boot from the DVD drive. To verify/
change the boot-up priority (rather than booting-up
from the hard drive or an external floppy disk drive),
perform the following steps:
1. Start your system and press the [F2] key when the
Fujitsu logo appears. You will enter the BIOS Setup
Utility.
2. Using the arrow keys, go to the Boot menu.
3. Arrow down to the Boot Device Priority submenu.
Press [Enter].
4. If "Optical Media Drive" or "CD-ROM Drive" is not
at the top of the list, arrow down to the drive in the
list, and press the space bar (or the + key) to move it
to the top of the list. (The system attempts to boot
from the devices in the order in which they are
listed.). Note that the BIOS for some systems will
indicate "CD-ROM Drive", even when a DVD drive
is connected. Then put in DVD restore disc that came with the computer and follow its instructions.
• This disc can only be used with the system with which it was purchased.
Fujitsu IT and Business Services IT Consulting IT and Business Solutions
Feb 19, 2015 | Fujitsu Computers & Internet
Change boot cd rom bios300
Your IBM 300 series desktop computer is normally set to boot its operating system directly from the installed hard disk drive.
There are some cases where you may want to boot from a different device, such as loading from the floppy drive to install a new operating system.
In order to change the boot order on the IBM computer you need to access the Basic Input Output System (BIOS) menu.
Close any applications that are still running.
Turn off the IBM 300PI computer and then turn it back on again.
Tap the "F1" key when the "Configuration/Setup Utility" prompt appears at the bottom of the screen.
Tap the down arrow key four times to highlight the "Start Options" entry.
Press the Enter key.
Highlight the "Startup Sequence" entry and then press Enter again.
Scroll down and highlight "First Startup Device."
Press Enter. Scroll through the list of available boot order devices.
Highlight the device you want to use, such as "CD Drive" or "Floppy Drive," and press Enter.
Press the "Escape" key twice.
Highlight "Save Settings" and then tap Enter.
Power off the IBM computer and then power it back on.
May 06, 2013 | IBM 300PL (PC 300 PL 733) PC Desktop
There are different methods for BIOS'es, but.........
Boot Order:
1) This method has it where you use the appropriate key (Down Arrow key?), and highlight the boot device you want, in the list.
Then you press the Enter key.
From there you use the appropriate Change value key, and move the boot device to the top of the Boot Order list.
(Page Up/Page Down, or +/- keys)
Then you press the Enter key again, and you are back to the main Boot Order menu.
Now press the appropriate key (Example - F6), and Save Changes.
Or there is a Y/N, or Yes/No to highlight, and then press the Enter key.
You MUST Save Changes, or it will be like you have done NOTHING at all.
2) This style has it where you highlight Boot Order, and then use the appropriate Change Value key, to move the boot order around.
For example you press the Change Value key, and after pressing enough times, the boot device you want will be at the top of the list.
The press the Enter key, and go through the procedure of Saving Changes.
The navigation guide is at the Bottom of each BIOS menu screen.
Does not state navigation guide, though.
Individual navigation comments are to the right side, for each submenu in Boot Order.
Read carefully, and see how to properly set HDD 0 / IDE 0, as the first boot device.
Regards,
joecoolvette
Cant find Windows Installer and my XP restore plus will not open
My suggestion would be to go into BIOS Setup, and in Boot Options; change the first boot device to CDROM.
Computer off. (Press the Power On button in for a count of 10 seconds, or until computer turns off)
AS SOON AS you press the Power On button, start tapping on the F10 key.
Tap in 2 second intervals.
If you hear beeps ignore them. They are Stuck Key Error Code beeps, and it is You that is doing it. (It's OK)
Takes a few seconds, then you should be looking at the Main menu, in BIOS Setup,
System Information
Standard CMOS Setup
Advanced BIOS Features
Advanced Chipset Features
Integrated Peripherals
Power Management Setup
PnP/PCI Configuration
PC Health Status
Load Optimized Defaults
Supervisor Password
Set User Password
Save and Exit Setup
Exit Without Saving
You CANNOT use your mouse anymore. You need to use the Keyboard.
Use the Down Arrow key, and highlight Advanced BIOS Features.
First Boot Device
Second Boot Device
Third Boot Device
Fourth Boot Device
You want CDROM as the First Boot Device.
This FORCES the computer to boot off of a disk in the optical drive.
(CD/DVD drive)
So you will want Optical Drive as the first boot device.
BIOS Setup changes. There are different versions.
The manual is unclear, of how to move Optical Drive to the top of the list, or also can be said as move to First Boot Device.
Let's see if this method is used;
Use the Down Arrow key, and highlight -> First Boot Device
Now press the Enter key.
Use the Down Arrow to highlight Optical Drive.
Now look at the navigation guide at the bottom. (Does NOT state navigation guide)
Use the appropriate keys to Change Value.
It should either be the + / - keys, or the Page Up/Page Down keys.
(If you can, I would use the Minus { - } key, and not use the Plus
{ + } key )
Tap the key until Optical Drive is at the top of the list, or across from First Boot Device.
Now use the Up or Down Arrow key to highlight -> Save and Exit, and press the Enter key.
Don't have your Restoration Disk in the optical drive?
That's OK. Open the drive, put it in.
Now press the CTRL, ALT, and DELete keys AT THE SAME TIME.
This will restart the computer.
For additional questions please post in a Comment.
Regards,
joecoolvette
HP Support > Service Reference Guide > HP Compaq DX2200 MT Desktop PC,
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00631987/c00631987.pdf
Feb 27, 2013 | HP Compaq Business Desktop dx2200 - P4 524...
I need to press a key on my keyboard to start factory recovery
Hi and welcome to Fixya!
In order to revert the machine back to its factory setting, you need to have the recovery disk (if you don't have it, call the warranty support line of e-machines so they can provide it to you).
To restore Windows from your recovery discs, you will need to
insert the first backup disc and enable the F12 Boot Menu via the BIOS Setup
Utility.
1 Turn on your computer and insert the first system recovery disc into the
optical disc drive. Restart your computer.
2 During startup when the eMachines logo shows, press the F2 key to enter
BIOS Setup, where you can set system parameters.
3 Use the left and right arrow keys to select the Main submenu.
4 Use the up and down arrow keys to select F12 Boot Menu.
5 Use the F5 or F6 key to change F12 Boot Menu to Enabled.
6 Press the ESC key to enter the Exit submenu, press the ENTER key to Exit
Saving Changes. Press the ENTER key again to select Yes. The system will
reboot.
7 After rebooting, when the eMachines logo shows, press the F12 key to
open the Boot Menu. Here you can select which device to boot from.
8 Use the arrow keys to select the IDE1*, then press the ENTER key. Windows
will be installed from the recovery disc.
9 Insert the second recovery disc when prompted, then follow the onscreen
prompts to complete the restore.
10 Remove the recovery disc from the optical drive once the restore is
complete. Do this before rebooting your computer.
Hope this helps!
Takasashi
Jul 25, 2011 | eMachines E620-5885 Notebook
Bought a Gateway model M465-E on Ebay only to find out the bios is pass-worded so I cant load Win XP because of The infamous "no hard drive error because of the Sata Driver,and i cant get to the...
I'm sorry but I don't know how to reset your BIOS. But to get around your problem, you should be able to enter the boot menu to boot to the optical drive to install your OS.
In order to access the boot options on this notebook computer, press the F10 key while the Gateway screen is displayed during the startup process. This opens a Boot menu with the option to start the computer to any of the available drives. Use the UP ARROW and DOWN ARROW keys to select a menu option, and then press the ENTER key to start to the selected device.
To "boot" (start) to a CD, DVD, or a floppy disk, the media must be in the drive when starting the computer.
Dec 21, 2010 | Gateway M465-E Notebook
I am trying to replace the hard drive in emachine 500is. Now the computer will not recoginize the cd rom to read the windows xp set up disk.
Go into BIOS Setup, and in Boot Order, change the first boot device to CDROM.
How?
To go into BIOS Setup you start tapping either the DELete key, or the F2 key, ->Right After you see the eMachines logo. If you miss this window of opportunity, simple press the CTRL, ALT, and DELete keys, At The ->Same Time.
This will restart your computer. Try again.
If you try the DELete key, and this wasn't the proper key, then use the above, restart your computer, and press the F2 key -> As Soon As You See the eMachines logo.
In the BIOS Setup main menu, look across the top for Boot Options. You cannot use your mouse to navigate around in BIOS Setup, you have to use your keyboard. Press the Right Arrow key to highlight Boot Options, then press the Enter key.
Your BIOS Setup may be different for this model. You may have to go down to Advanced BIOS Settings, in the main menu, and highlight it. Use the Down Arrow key to highlight Advanced BIOS Settings, then press the Enter key.
In the Advanced BIOS Settings sub-menu, look down the list for ->Boot Options. Use the Down Arrow key, and highlight it, then press the Enter key.
In the Boot Options sub-menu, you will see a list of boot devices. Floppy Disk drive, CDROM, HDD, (HarDDrive, or really -> HarDDisk), and perhaps a fourth one.
Use the Down Arrow key and highlight ->CDROM. Look down at the bottom of this menu, and see what the Navigation keys are. It won't state -> Navigation Guide, but that's what it is. You want the -> Change Value, keys.
It may be +/-, or Page Up/Page Down. (Plus + key, or Minus - key)
Using the Change Value key, move CDROM to the top of the list. (You have to hold the Shift key down in order to use the + key)
You may have to highlight the device on top of CDROM, and change value of it, in order to get CDROM to come to the top. Keep moving the boot devices, until CDROM is at the top of the list.
After CDROM is at the top, press the Enter key.
Now press the F10 key to save the changes you made. Now press the y key, and then the Enter key.
If you do not press the F10 key, and then the y key, it will be like you have done Nothing at all!
You haven't saved changes.
You may also have the words -> YES, and NO listed, instead of the Y key. (It's shown as a capital Y for clarity. Press the y key. Do Not hold the shift key down, and press the y key)
You can either use the appropriate side arrow key to highlight -> Yes, or just press the y key.
Now press the Enter key. Your computer will restart.
Your computer will now look in your CDROM drive for a boot disk. (It can be a CD drive, CD burner drive, or DVD drive, or burner)
IF, you do not have the Windows XP disk in your optical drive, or IF you did not get it in your optical drive before the computer booted up, don't sweat it.
Just make sure the disk is in the drive, and then press the CTRL, ALT, and DELete keys,
AT THE SAME TIME. Your computer will restart.
(Not 'shouting')
Jul 27, 2009 | Computers & Internet
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Computers & Internet Logo
Top Advanced Fox Computers & Internet Experts
David Payne
David Payne
Are you an Advanced Fox Computer and Internet Expert? Answer questions, earn points and help others
