Question about Canon LC-3175 Laser Fax
Printing the fax number at the top of the page
Faxing a docuement to China and they request that their copy has our fax number at the top of the page...how do I check that setting?
  • 76 Answers
SOURCE: Fax L200 Check paper size problem
This is due to the reg sensor being worn, item 26 in the photo
please order and replace
RB2-1700-030 - LEVER, REGISTRATION SENSOR
hope this helps
Posted on Oct 21, 2008
iservice
  • 318 Answers
SOURCE: Can not print the incoming fax as well as cannot copy a page
Hi
The scanner unit don't reach the scan possition.If you open the front cover,check and see if the is no obstruction in the scanner parth to flip down to the scan possition.Pull the scanner unit a few times foward down and backwards up.If that dont work the grease on the scanner clutch might cause the scanner not to go to scan possition.For service of that clutch you will have to take it to the Canon dealer.
Posted on Nov 12, 2008
  • 16 Answers
SOURCE: FAXING FACE UP OR DOWN
Face down.
Posted on Nov 15, 2008
iservice
  • 318 Answers
SOURCE: Page grabbing
Open the document feeder,you will see in the inside in the upper unit there is a rubber.Clean that rubber with a strong soap.
That rubber is normaly dirty and you have to clean it some times.
If that does not help,you will have to replace the rubber(Separation assy)
Posted on Nov 25, 2008
SOURCE: RECEIVED FAXES AND/OR COPIES PRINT ONLY HALF PAGE
Don't know that machine all that well, but it sounds like the laser filter glass may be dirty, or the laser unit. It seldom happens, but did you by any chance blow it out with compressed air?
Anyway, you may try taking out the toner cartridge, and if you tilt the machine upward you should see a sort of 'filter glass" above where the cartridge sits that allows the laser light to pass through from above. try cleaning this with a cloth, and hopefully that will solve your problem.
Posted on Mar 10, 2009
Prints all black page when faxing printing or copying
www.samsung.com/.../printers.../black...printers/.../index.idx?pagetype... - United States -
Aug 02, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
HP Printing, copying, faxing, scanning black pages
change the ink cartridge & get your printer serviced
Jul 18, 2010 | Office Equipment & Supplies
We had a power outage and are having trouble faxing to China....It rings, seems to connect then gives no error code and puts the fax out for re-dial...Any suggestions on how to fix this?
Plug a phone into this outlet and see if you get a dial tone. If you do not you will have to call the phone company. If you can use a phone at that outlet but not your fax, then you know that the power surge that came when the power turned back on damaged a fuse in your machine. Joe
Mar 18, 2010 | Panasonic Panafax UF-550 Plain Paper Laser...
HP Office Jet 630 will not print
please check whether the data cable rx232 which is used to connect the printer to pc is fine. try someone else's cable(e.g friend) and check whether it is able to print .re install the software that is provided along with the printer in the form og cd or dvd. hope your problem will be tackled then
May 25, 2009 | Office Equipment & Supplies
Vertical line on page when scanning/faxing
Clean the scanner glass. You probably have some dirt or whiteout on it. Open up the top feeder and look at the narrow glass and you'll probably find it.
Mar 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Faxing up or down
Look at the hopper. It will almost certainly have a little graphic on it to tell you which way up the document goes.
If it looks like a sheet of paper with lines of writing on, the paper goes in print side up.
If it looks like a sheet of paper with one corner folded over, and lines of writing visible only on the turned over corner, then it goes in print side down.
If you can't find the graphic, then experiment: Take a blank sheet of paper. Write "Up" on one side and "Down" on the other then stick it into the machine so the writing is telling the truth. Most fax machines have a copy mode - use this to see which side of the paper the machine reads (if you can't get it to copy, fax your page to somebody and get them to phone back to tell you which side of the page they've received).
A.
Jan 18, 2009 | Brother Office Equipment & Supplies
Faxing multiple pages
If it's only one page.. just place it on the glass face down.
When faxing muliple pages you must place them in the automatic document feeder located on top of the machine.
Place all originals print side up (up to 35 pages). A message will show up in the display letting you know original were loaded up properly. Let me know it this helps.
Apr 02, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Faxes only top of page center is blank
change your resolution from fine to super fine and make a copy to verify your fax machine"s scanner operation.
Mar 21, 2008 | Brother IntelliFAX 1840C Plain Paper...
Double shadow image
YOU NEED TO CLEAN THE LASER UNIT happy faxing omnipresent
Oct 01, 2007 | Canon FAXPHONE L170 Plain Paper Laser
Canon LC-3175 Laser Fax Logo
15 people viewed this question
old marine
old marine
