Question about Xerox DocuColor 2045 2060 5252 6060 Cyan Toner 006R90290
Press subsystem fault: 009-343 - Xerox DocuColor 2045 2060 5252 6060 Cyan Toner 006R90290
What is the fix for Audi Fault code P1723
Trouble Code:
System:
Subsystem:
P1723 - (Manufacturer Specific)
Powertrain
Transmission Controls
DTC Description: Starter Interlock Circuit Open
Analysis:
Likely Cause:
Open Circuit
Possible clutch switch if manual transmission.
Sep 20, 2016 | Audi Cars & Trucks
What is the bmw code 2056 ?
if it start's with a P2056
Fault Code P2056 - Reductant Injector Circuit / Open (Bank 2) Unit 2
Trouble Code:
System:
Subsystem: P2056 - (ASE)
Powertrain
Fuel & Air metering, Auxiliary emission controls
Jul 25, 2014 | BMW X3 Series Cars & Trucks
I can not get the printer to stop printing ...what do i do?
Hi please turn off the printer and restart it after five minutes if you still have the problem please uninstall and reinstall the drivers for your printer.
Jun 13, 2010 | HP Office Equipment & Supplies
I Have a subsystem fault 004-332 on a xerox 2045. Any ideas?
4.332 belt position failre as you can see the belt edge sensor sa detected that the drive belt is out of its position.
Jun 03, 2009 | Xerox DocuColor 12 Printer
When i am trying to use c++ on my system it is giving me message the NTVDM cpu has encountered an illegal operation
Here is an explanation of what NTVDM is: The NT Virtual DOS Machine (a.k.a WOW, or Windows on Windows), is a Win16 subsystem that runs under Windows NT, which allows 16-bit applications to run as if they were being executed on a DOS machine, with that machine's multitasking and segmented memory model. Because the system is multitasked 16-bit DOS and Windows applications cannot crash NT. However, 16-bit apps within a Win16 subsystem run the exact same way as they do on a DOS/Win 3.x machine; therefore, 16-bit apps within the subsystem can crash one another, or the subsystem. To prevent this, you can launch multiple WOW subsystems as long as your program does not communicate using shared memory. Windows NT will not allow NTVDM to execute instructions that try to directly manipulate hardware or memory locations. As a result, some DOS and Windows 3.x applications (such as games) may not run under Windows NT.
Feb 02, 2009 | Computers & Internet
Error 062-380
That is an imaging subsystem fault.
You can try turning the machine off, disconnceting and reconnecting the document feeder and scanner cables, then reconnect them to be sure they are properly seated.
Other than that, it would really need a service call.
Aug 14, 2008 | Xerox Office Equipment & Supplies
Spooler subsystem has stopped working
if u not getting print due to " Spooler subsystem app has stopped working " Error then go to Run---->type "services.msc"------->u get services console----------->select "Print Spooler"go to propriety ---------->check start-up type ------>if it is disable select automatic &press start for get start (if it is alredy started then get service stop & after get start with automatic )
if there is problem in printing due to Spooler it should be resolved
if this information is useful for u please Rate me..........
Jun 22, 2008 | HP Color LaserJet 2600n Printer
Printing error
when i send for print i et
PCL XL error
subsystem: KERNEL
Error: IllegalTag
Operator: 0x1b
Posittion: 7
Jun 15, 2008 | HP LaserJet 6p Printer
Xerox DocuColor 2045 2060 5252 6060 Cyan Toner 006R90290 Logo
65 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
