Question about Acer Aspire 3000 Notebook
Scroll zone is active but webpages can't be scrolled
When I use the scrolling zones of my Acer 3003 touchpad, cursor's appearance switches to "scroll look" and works perfectly under Windows XP and MS office or other apps but not when I surf on webpages using Mozzilla Firefox (works under IE...)
    Master:
  • Acer Master
  • 788 Answers
It is obvious that the problem is a compatibility problem. You need to post the problem in the Firefox community to get help.
Posted on Feb 18, 2014
babes_ganda0
  • 381 Answers
SOURCE: My touchpad's left button is not working. I cant
install again the drivers or make a update the driver installer..good luck
Posted on Jun 26, 2009
  • 32 Answers
SOURCE: Acer touchpad scroll is not working
Most likely you need to install the driver for your touchpad. The default windows driver allows the touchpad to function but does not give it the extra features such as scrolling. If you go to Acers support site http://support.acer.com/ , you can download the driver for the touchpad. I looked on the site and did not see a 6903 model, did you mean 6930?
Once installed you can go to the control panel, mouse, and see the extra features.
Posted on Sep 12, 2009
Testimonial: "i mean Acer Aspire 6930 series"
SOURCE: scroll feature on touchpad no longer works
i did a system restore to take the laptop back to how it was before some automatic updates had taken place and now its working again.
ok, not the best solution i know, but at least its resolved the problem for now.
thank you.
kind regards
jackie
Posted on Oct 18, 2009
djtatty
  • 417 Answers
SOURCE: Acer Extensa TouchPad Won't Scroll!?
Go to the control pannel witch is in your start menu right hand side, then switch the view to large icons if you use (windows 7) or classic view for (windows vista) find the mouse properties then in there click on the hardware tab at the top then click on the properties box or it could say settings then you'll see all the settings in a box click on them & they will highlight & give you a little + symbol click on these to show all the settings. good look if you get stuck giz a bell free LAND LINE:01228 523603
Posted on Jun 17, 2010
igor106
  • 277 Answers
SOURCE: the touchpad and scroll on my acer aspire 5734z
It sounds like you've accidentally locked the touchpad. To unlock it hit the Fn key (lower left corner, between the CTRL and WIN buttons, it should be labeled with blue Fn label) and F7. That's Fn+F7, press and hold the Fn key, and then hit and release the F7 key, and then release the Fn key. On my Aspire this is the combination to toggle on and off the touchpad. It may be a different combination on your laptop but the rule of thumb is that you need the Fn key and one of the F1-F12 keys. The correct Function key will be labeled with a rectangle and a hand over it, illustrating a touchpad. Once you locate the key, press it and the Fn key as I explained above, and that should be it.
Posted on Jan 15, 2011
Touchpad won't scroll
hi there.
this is all i could find.
Why my TouchPad is not working in laptop Acer? Enable/disable your touchpad - Many systems allow you to turn the touchpad On or Off by pressing the FN and F7 keys at the same time. ... Reinstall touchpad drivers - Missing or incorrect drivers may cause your touchpad to not work properly. Check in device manager to make sure your touchpad is reporting properly.27 Oct 2014
Touchpad troubleshooting - Acer Community - 307854
community.acer.com/t5/Knowledge-Base/Touchpad-troubleshooting/ta-p/307854 Search for: Why my TouchPad is not working in laptop Acer?
or go to this link and read up some more if you need to.
Acer Aspire Notebook PC Touchpad won scroll Google Search
Nov 27, 2017 | Acer Aspire E1-571-6492 15.6" Notebook PC...
The touch mouse will scroll and move but won't click.
you might have to reset it
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
b>
Feb 15, 2013 | HEWLETT-PACKARD Hewlett Packard HP 6730b...
My scrollbar will not work. I can use my touchpad just right and right click and left click, but I cannot scroll on a page I have to use my arrow keys, how do I fix this?
b>
Feb 03, 2013 | Acer Aspire 5750-6438 - 25519
Scroll bar
Feb 03, 2013 | Acer Aspire Computers & Internet
I have a HP pavillion DV6-1250us Windows vista home premium and i cannot get my mouse to scroll up or down? how do i fix this?
To move the pointer, slide your finger across the TouchPad surface in the direction you want the pointer to go. Use the TouchPad buttons like the corresponding buttons on an external mouse. To scroll up and down using the TouchPad vertical scroll zone (right edge of the touchpad), slide your finger up or down over the lines.
NOTE: If you are using the TouchPad to move the pointer, you must lift your finger off the TouchPad
before moving it to the scroll zone.
Mar 03, 2011 | Computers & Internet
Touchpad Scroll zones not working
we can uninstall the drivers from device mgr and then reinstall from HP.COM.
do a BIOS update
Dec 13, 2009 | HP Pavilion dv4000 Notebook
On my hp 6735b laptop I would like to turn off the scroll zone on the touch pad if possible.
You don't specify what system are you using. In Windows you have to go to Control Panel, Mouse and Pointing Device properties, and find your touchpad options there, including the scroll areas.
If it's not there, chances are there is a separate application, either in Control Panel, or in the Start Menu, for setting up the touchpad. You can also look in the system tray beside the clock - often there's an icon there for the pointing device.
Nov 25, 2009 | HP Compaq 6735b Notebook
The scroll zone in my touchpad is not working
You need to go to the Dell website and download the driver for your touchpad for the version of Windows that you are using. Depending on the age of your laptop and the version of Windows there may not be a driver for your touchpad. In that case you might need to use an external mouse instead.
Aug 14, 2009 | Dell F3534 Touchpad
On a hp compaq 6710b where/ how do i switch wifi on?
The wireless button should be located on the top left part of your laptop. It will be the 3rd button from the left.
11bffdfe321d68aa11aa600332bfe03c.png e8721ff914fb66ee83d789398c8a2a31.png e8721ff914fb66ee83d789398c8a2a31.png d44fad740e4749adb4fe5f87725dd44f.png 1. Volume mute button with LED indicator
2. Volume scroll zone with up/down LED indicators
3. Integrated microphone 4. RJ-11/modem port
5. Optical drive 6. Media Card Reader 7. 2 USB 2.0 ports 8. HP Fingerprint Sensor 9. Integrated stereo speakers 10. Touchpad with scroll zone 11. Touchpad Buttons 12. Hard drive activity / HP 3D DriveGuard LED 13. Battery charging LED
14. Power/standby LED
15. Wireless on/off LED
16. Power button with LED
17. HP Info / HP QuickLook button with LED indicator
18. Wireless on/off button with LED indicator
19. HP Presentation button with LED indicator
20. WLAN antennas (with WLAN option)
21. WWAN antennas (with WWAN option
Jul 11, 2009 | HP Smart Buy Notebook
Touchpad Vertical Scroll zone not functioning
you can activate this by
1. going to the control panel on your vista machine, make sure you are in classic view
(2) double click the mouse icon.
(3) From here you will select the "Device Settings" tab,
(4) make sure your Synaptic Pointing device is highlighted and then click the settings button located directly below the "port" column, this will bring up properties for this device.
(5) With all categories in the left hand column collapsed, select "Virtual Scrolling" here is where you will find the box that needs to be checked to enable vertical and/or horizontal scrolling.
(6) make sure the "Enable Vertical Scrolling" box is checked.
(7) don't forget to hit apply!
I hope this helped some people. I am using a HP dv7 so your menu may look a little different. Happy holidays.
Jun 07, 2008 | HP Pavilion dv4000 Notebook
Acer Aspire 3000 Notebook Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
