Question about Aiwa Televison & Video
My aiwa tv sx2150 A/V 1 AND 2 INPUT NOT WORKING,MEANS OTHER DEVICE CONNCT NOT COME SOUND IN SPEAKER.SOUND ALSO COME IN TV MODE PLS ANY ADVICE?
    New Friend:
    Problem Solver:
  • 11 Answers
The EEPROM can be defected
Posted on Feb 13, 2014
2 Suggested Answers
gopakumarg43
  • 75304 Answers
SOURCE: Dear Sir, In my aiwa tv there is no audio sound
Hello
You just check whether its speaker has damaged or not. You can check it easly. Just place your ear very near to the speaker side of your TV, and switch on the TV with its panel on-off switch, not by remote hanset. If you hear a "thumb" sound from that side of the speaker, you can make sure that the speaker is OK, and the fault is inside the circuit board of Tv.
If there is no "thumb" sound, open the TV and check the speakers for continuity. You can check the speaker with a troch cell, by touching its poles to the leads of the speaker, with attaching a pice of wire to the cell. If it is found faulty, replace them with an identical type and resistance, Its impedence [resistance] will be marked on its magnet. Choose an exact one.
If speakers are found Ok, and still there is no sound, if your TV is equipped with an earphone socket in front panel, push in an earphone pin into it, and check whether there is sound output from it or not. If there is sound output from it, and you can't get it through speakers, the earphone socket is faulty, and replace it.
if there is no sound from the earphone socket also, just goto the sound output section of the circuitboard of your TV. You can locate that section by following the speaker wire. Look for any loose soderings first. I advice you to resolder all the soldering points of sound output Ic, before replacing it. After resoldering, still there is no sound, check the input supply voltage of that Ic. If it is not there, check for the reason. if it is there and still no sound, sound output Ic is faulty, and replace it with same type and number.
If you need anymore assistance, get me through Fixya. OK.
Posted on Dec 13, 2010
A/V INPUT NOT WORKING
To me in my experience with those set if no loose connection which need to be solder, then that is your EEprom
Feb 12, 2014 | Aiwa Televison & Video
A/V INPUT FONT AND BACK NOT WORKING
check for poor solder connection
Unable to get TV sound and dvd sound through the surround sound speakers with samsung compatible tv and blu ray player
Hi,Even though you have not mentioned about the cabling connections you have done, for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care
Aug 17, 2011 | Televison & Video
MY TV ONLY HAS SOUND WHEN IT IS HOOKEDUP TO THE DVD PLAYER AND A SURROND SOUND SPEAKER BUT NOT FROM THE TV OR WHEN HOOKED UP TO THE SPEAKER ON TV OR XBOX
Hi,here is the solution......
Since you successfully connected your
DVD /Receiver to play video on TV (one way only ) ,here is the second reverse action to listen your TV on DVD /Receiver
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV ,
** to "TV input "or "AUX input" or "Optic Cable input"
of your DVD /Receiver (whichever you want based on the necessary cables on your hand )
** than just switch to respective mode on
DVD /Receiver corresponding the connector you have used on the back of DVD /Receiver ..
There you go..Both Tv and Xbox sound are on the
DVD /Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your DVD /Receiver SURROUNDING SOUND .
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 03, 2011 | RCA L46WD22 Television
Samsung ps wx30 surround sound system. speakers are plugged in to dvd player. dvd player is connected to tv via hdmi cable. speakers only work when using dvd player and not tv/sky etc.. am i missing some...
Hi,here is my simple solution...
To listen your TV on your
samsung ps wx30 surround sound system ,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out " of your TV unit
** to "AUX input " or "TV" OR "Any input" of your
dvd player or "Optic Cable input" or "HDMI input"
dvd player corresponding your RCA or Optic connection or HDMI ..
There you go..Your TV sound is on the
dvd player By this means whatever you watch on the
TV (
tuner, satellite , Xbox , etc..) ,it's sound will come thru your
dvd player.
Hope this helps!..if more he?p requires pls let me know..
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
Jun 25, 2011 | Audio Players & Recorders
Do i need a record turntable with a biult in amp for my aiea Z-L30
Do you mean AiWa Z-L30?
Generally speaking, if a device doesn't have an input specifically marked "PHONO" it does not have the requisite PHONO preamp for an old-school turntable.
Aiwa plays a word-game on this device and labels an input "Phono" while specifying on page 20 of the manual that you should use a turntable with a built-in EQ Amplifier. In other words, the input should have been labeled a second "AUX IN' as it will accept any sound device that has a Line Level output, not just Phono.
So yes, you need a self-PRE-amplified TT with this product.
http://www.retrevo.com/support/Aiwa-Z-L30-manual/id/1076ci560/t/2/
Feb 13, 2011 | Aiwa Z-L30 Shelf System
Dear Sir, In my aiwa tv there is no audio sound (,two speakers ) how can i rectify the problem, Pls any one help me to sort out the issue. Rgds, Jayaprakash.
Hello
Dec 13, 2010 | Aiwa F2000 20" TV
How do i connect aiwa speakers with 26
LG does not have direct speaker connectors. You will have to use the audio out RCA jacks on the set through RCA cables into a seperate amplifier. Hope this helps.
Oct 14, 2009 | LG 26LH20 LCD TV
I have a aiwa cx-na77, how do I connect it to a tv so that I hear the tv sound on the aiwa speakers
If it has an "AUX" input or any other type of RCA jacks for an input, you can connect the TV RCA audio jacks output to the input RCA jacks of the Aiwa.
That's what you would need.
RCA audio outputs on the TV
RCA audio input on the Aiwa
Just look at the back of each unit and see if it has them. RCA audio jacks are the small circular red and white jacks. They will be labed on each unit what they are for. You need output jacks on the TV and input jacks (but not for phono) on the Aiwa.
Aug 08, 2008 | Aiwa Audio Players & Recorders
Televison & Video Logo
Top Aiwa Televison & Video Experts
romy sibug
romy sibug
 Grubhead
Grubhead
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
