Question about BAK 2002 Nissan Frontier - King Cab, short bed - ProCap Bed Caps
Changing headlight and had to disconnect battery to pull bulb. reconnected battery and car will not turn over
All other DC power is working
Need to replace headlights
Open the hood of your SRX and disconnect the connector from rear of headlight by squeeaing the tabs. Pull off rubber dust cover. Rotate the collar on the headlight counterclockwise and pull it out of the headlight assembly. Insert new light and turn clockwise to lock it in place, DO NOT TOUCH THE BULB WITH YOUR FINGERS, THE OIL DEPOSITED FROM DOING THIS WILL CAUSE THE BULB TO OVERHEAT, LOWERING THE LIFE OF THE BULB CONSIDERABLY! use paper or something that is oil and dirt free. Replace dust cover and reconnect the power connector.
Dec 05, 2013 | 2010 Cadillac SRX
How to replace headlight assembly
  • 1
    Open the hood of the vehicle to disconnect the cable from the negative battery terminal and expose the headlight assembly.
  • 2
    Remove the headlight retainer clips by pulling toward the engine compartment.
  • 3
    Turn the bulb holder counterclockwise to pull the bulb from the headlight assembly and disconnect the electrical connection.
  • 4
    Install the new headlight. Do not touch the glass of the headlight -- oil from your fingers can cause the bulb to overheat and fail.
  • 5
    Replace bulb holder into headlight assembly and turn clockwise to secure it. Fasten the the retainer clips to secure the headlight assembly.
  • The retainer clips look like this :
    Jul 30, 2011 | 2004 Chevrolet Blazer
    How to change head light lamp on a Saturn S-Series SC2
    Purchase the replacement light you need from an auto parts store. Give them the year and particular Saturn S Series model number to acquire the right part. Also indicate whether you need the high or low beam light bulb, as some S Series models require separate bulbs.
  • Turn off the engine. Pop the hood and secure it open. Disconnect the battery cables from the battery by grasping the cable and pulling it straight off of the positive and negative battery terminals.
  • Position yourself in front of the headlight you wish to repair. Look behind the headlight assembly to find the wiring harness for the headlight assembly. Lift the locking tab, grab the wiring harness and pull the wiring directly away from the assembly.
  • Grab the old headlight bulb, twist it counterclockwise and pull it out of the headlight assembly. Replace it with a new bulb and secure it by turning it clockwise.
  • Reconnect the wiring harness to the headlight assembly and reconnect the battery cables. Test the lights to see if they work properly.
  • Thanks
    May 22, 2011 | 2000 Saturn SC
    How to change the headlights?
    Hi there, here are some few tips to assist you:
    • Remove the center cover and the screws attached to the radiator grille. Pull the radiator grille out of the engine compartment and set it on the ground.
    • Use a T30 Torx screwdriver to remove the two primary retaining screws from the headlight assembly. Make a note of each screw's original location--they're not interchangeable, so you'll need to put them back in the right slot to reassemble the light.
    • Draw the headlamp assembly away from the car and then disconnect the electrical wiring connector.
    • Release the wire clip on the back of the headlight assembly and remove the cover.
    • Disconnect headlight electrical connector and turn the bulb socket counterclockwise to remove it from the assembly. Install the new bulb, replace the cover and reattach the electrical connector.
    • Reconnect the headlight assembly wiring connector. Test the new bulb to make sure it works before replacing the retaining screws and radiator grille.
    Hope these help. Please rate me if they do.
    Jan 08, 2011 | 1999 Mercury Cougar
    Need to replace headlight lens on a 1996 dodge avenger
    Usually, one has to get the entire headlight assembly to replace the lens.
    Is it cracked?
    If it is just faded, try some anti-haze polish for headlights. This can save you some money compared to restoring the headlamp by replacing the assembly (which may be available from a salvage yard).
    REMOVAL & INSTALLATION
    CAUTION
    Halogen bulbs contain gas which is under
    pressure. Handling the bulbs incorrectly could cause it to shatter into flying
    glass fragments. Do NOT leave the light switch ON. Always allow the bulb to cool
    before removal. Handle the bulb only by the base; avoid touching the glass
    itself. Whenever handling a halogen bulb, ALWAYS follow these precautions:
    • Turn the headlight switch OFF and allow the bulb to cool before
      changing it. Leave the switch OFF until the change is complete.
    • ALWAYS wear eye protection when changing a halogen bulb.
    • Handle the bulb only by its base. Avoid touching the glass.
    • DO NOT drop or scratch the bulb.
    • Keep dirt and moisture away from the bulb.
    • Place the used bulb in the new bulb's package and dispose of it properly.
    Cirrus, Stratus, Sebring Convertible and Breeze
    1. Open the vehicle's hood and secure it in an upright position.
    2. Disconnect the negative battery cable.
    3. Remove the 2 screws securing the headlight module to the radiator closure
      panel.
    4. Pull out the headlight module from the vehicle.
      Fig. 1: Using a Torxhead screwdriver, remove the 2 headlight
      module retaining screws
      Fig. 2: Pull the headlight module straight out of the front of
      the vehicle to remove the bulbs
      Fig. 3: Disconnect the wiring harness for the headlight bulb
      Fig. 4: Turn the light bulb retaining ring counterclockwise,
      and remove it from the back of the module
      Fig. 5: Pull the light bulb out from behind the module. Never
      touch the glass of the light bulb
    5. Detach the headlight electrical connector.
    6. Remove the retaining ring holding the bulb to the back of the headlight
      module.
    7. Pull the bulb from the back of the headlight module. Hold the bulb by its
      base only; try not to touch the glass itself.
      To install:
    8. Holding the bulb by the base, place it in the headlight module, then secure
      with the retaining ring.
    9. Attach the electrical connector to the bulb.
    10. Install the headlight module into the vehicle and tighten the 2 retaining
      screws.
    11. Connect the negative battery cable and check the headlight operation.
    Sebring Coupe and Avenger
    3. Remove the sealing cover by rotating it counterclockwise.
    4. Remove the bulb attaching spring and pull out the light bulb.
      Fig. 6: Remove the headlight sealing cover(s)
      Fig. 7: Remove the attaching spring and pull out the bulb
      To install:
    5. Install the bulb into the headlight module.
    6. Install the bulb attaching spring.
    7. Install the sealing cover.
    8. Connect the negative battery cable and check the headlight operation.
    Oct 07, 2010 | 1996 Dodge Avenger
    How to put in a headlight on a 2003 Chevy Trailblazer
    Please follow the stepwise solution carefully.
    1.Open the hood and disconnect the truck's negative battery cable.
    2.
    Remove the grille. Unbolt and remove the plastic panel over the radiator, then use a flat screwdriver to release the clips securing the grille at the bottom to the headlight panel and lift the grill off.
    3.
    Pull up the retaining tabs for the headlight housing, which are on opposite ends, and carefully pull the housing out. Remove the park/turn signal bulb socket from the housing by detaching the holders and electrical connectors and disconnect the side marker socket.
    4.
    Take off the circular access cover from the rear of the headlight housing. Twist the bulb in a counterclockwise direction, withdraw the bulb with its electrical connector from the housing and disconnect the electrical connector.
    5.
    Hold the new bulb by the holder--do not touch the glass--as you connect the electrical connector. Place the bulb in the housing and twist it clockwise to lock it in place. Close the access cover.
    6.
    Install the headlight housing into the panel, connecting the electrical connectors, signal bulb socket and side marker socket. Push the retaining tabs in place.
    7.Reinstall the grille and plastic radiator panel and reconnect the negative battery cable.
    Problem solved.
    Take care.
    Aug 06, 2010 | 2003 Chevrolet TrailBlazer
    How do i replace my headlight for my 2003 acura 3.2 tl?
    HID Bulb Removal
    WARNING: A transient high tension (25,000 V) occurs at the bulb sockets of the high intensity discharge (HID) lamps when the combination light switch is turned ON. It may cause serious electrical shock or electrocution if you do not observe the cautions below .
    CAUTION:
    • Never turn on the combination light switch before fitting the HID bulbs to their bulb sockets and completing the reassembly of the headlight assembly.
    • Do not service the headlights assembly in wet conditions, such as rain or snow, near a sprinkler system, or when your hands are wet to prevent electrocution.
    • Do not touch the surface of the HID bulbs with your bare hands and do not stain it with any oils and fats.
    • Do not disassemble the inverter unit and the ignitor unit.
    • Do not turn on the HID bulb by using a power source other than the battery mounted on your vehicle.
    1. Make sure you have the anti-theft code for the radio and the navigation system, then write down the frequencies for the radio's preset buttons.
    2. Combination light switch OFF.
    3. Disconnect the battery negative cable, then disconnect the positive cable.
    4. Disconnect the headlight assembly 2P connector.
      1. Remove the Torx bolt (A) using a Torx T20 bit.
      2. Turn the cover (B) 45 ° counterclockwise to remove it from the headlight assembly.Turn the socket (A) 45 ° counterclockwise to remove it from the bulb (B).
        1. Pull the retaining spring (A) away from the bulb (B), then remove the bulb (B).
        2. Install the new bulb in the reverse order of removal.
        3. After reconnecting the battery, enter the anti-theft code for the radio and the navigation system, then enter the customer's radio station presets.
    Dec 09, 2009 | 2003 Acura 3.2TL
    How do I change the headlight bulb in a 2002 Jeep Grand Cherokee?
    For bulb replacement:
    1. Disconnect negative side of battery2_bing.gif.
    2. Open hood.
    3. Reach behind the neadlight assembly and disconnect the wiring connectors.
    4. There is a locking ring2_bing.gif around the back of the headlight assembly. Turn this counterclockwise.
    5. Gently pull out the bulb.
    6. Insert new bulb into the locking ring.
    7. Place these back onto back opening and turn clockwise making sure it is flush and totally engaged.
    8. Replug wiring connector.
    9. Reconnect negative side of battery.
    10. LIGHTS!!
    Nov 26, 2009 | 2002 Jeep Grand Cherokee
    Looking for instructions on how to replace headlights on a 1996 Jeep Grand Cherokee; purchased replacement fixtures, but can't figure out how to remove/replace.
    Is this the headlight bulb replacement or headlight (assembly) replacement? For bulb replacement:
    1. Disconnect negative side of battery.
    2. Open hood.
    4. There is a locking ring around the back of the headlight assembly. Turn this counterclockwise.
    10. LIGHTS!!
    Nov 25, 2009 | 1996 Jeep Grand Cherokee
    Replacing HID headlight in 2004 Acura TL
    HID Bulb Replacement
    A transient high tension (25,000 V ) occurs at the bulb sockets of the high intensity discharge (HID) lamps when the combination light switch is turned ON, it may cause serious electrical shock or electrocution if you do not observe the cautions below.
    CAUTION:
    1. Make sure you have the anti-theft codes for the radio and the navigation system, then write down the XM radio channel preset. Make sure the ignition switch is OFF.
    2. Turn the combination light switch OFF.
    4. Remove the headlight assembly.
    1. Remove the Torx bolt using a Torx T20 bit.
    2. Turn the cover (A) 45 ° counterclockwise to remove it from the headlight assembly.
    1. Turn the socket (A) 45 ° counterclockwise to remove it from the bulb (B).
    2. Pull the retaining spring (C) away from the bulb then remove the bulb.
    3. Make sure the bulb harness (D) is routed correctly so it does not contact the reflector (E).
    4. Install the new bulb in the reverse order of removal. Make sure the notches in the bulb align with the tabs in the headlight.
    5. After reconnecting the battery, enter the anti-theft codes for the radio and the navigation system, then enter the customer's XM radio channel presets.
    Feb 13, 2009 | 2004 Acura TL
    BAK 2002 Nissan Frontier - King Cab, short bed - ProCap Bed Caps Logo
    20 people viewed this question
    Top BAK Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you a BAK Air Tool and Compressor Expert? Answer questions, earn points and help others
