Question about KitchenAid KFC3100 Chef's Chopper Food Processor
How do i turn it on?
Help! I don't have an owners manual and when I secure the top properly, it won't go on!
Cuisinart will not run
unplug it take the blades off then see if ther is something stopping it other wise the gear box is shot need to replace with new one don,t get it fixed cost more then what it,s worth
Jul 29, 2014 | Food Processors
Have lost iinstructions for tefal optima pressure cooker, do not know what positions 1 & 2 indicate
http://www.tefal.co.uk/Consumer+service/Use+instructions/use-instructions_home.htm
go to this site select and download the manual you will know it all.
regards.
PLZ. RATE
Jul 03, 2011 | Tefal Food Processors
I can't get the food bowl off the processing unit. i have removed the cover as the manual says. I have left the blade in as the manual says. The picture looks as thought you should just lift it...
On page 8 of the manual that I will give you the link to: leave the cover in place on the container. Use the cover to help remove the container. Rotate the cover clockwise 180 degrees until the two tabs on the cover meet the two container tabs. Continue to turn the cover, but do not press down as you turn, using your thumb against the tabs until the container is released. Empty the remaining food from the container.
http://kitchen.manualsonline.com/mdownloads/c44fa16e-225f-49e2-84e5-348ee18b9c1b.pdf
Jul 15, 2010 | Sunbeam 4817 Oskar Food Processor
Where can I order a new ring collar for Rival 2275WP food grinder
After an extended period of searching small appliance parts sources I totally understand your question here. Even the user manual does not list a replacement parts source. I was unable to locate any OEM source for the ring collar.
You can try calling Rival at this number
1-800-557-4825
or email here: (500 Char limit)
https://secure.rivalproducts.com/ContactUs.aspx
Thanks for giving Fixya a chance to help you.
Kelly
Apr 27, 2010 | Rival 2275WP Food Processor
Owner's Manual
http://www.focuselectrics.com/supportdata/L5685-3-Cup%20Food%20Chopper_ALL.pdf
i believe this may be the owners manual you are looking for.
thank you,
Lee
Nov 11, 2009 | Food Processors
FOLLOWED MANUAL INSTRUCTIONS BUT MACHINE DOES NOT START. WHEN OWNER USED IT LAST IT WORKED. ATTEMPTED TO REFIT BUT COULD NOT GET IT STARTED. MACHINE WAS PLUGGED INTO GOOD POWER SOURCE, NOTHING WRONG WITH...
One of the major problems I have seen with food processors is the safety switch, which will not allow the motor to turn on if the bowl and top are not properly seated. The lever and/or switch sometimes wear to the point that they no longer work (easily). I'd do a bit more checking before I discarded the machine.
Oct 23, 2009 | Cuisinart Food Processors
My food processor light is on but i need to press and hold the black button please help
Use a ball-point pen to depress the button - your finger simply will not do.
This is only to test the motor.
Once it makes the proper sound, you are ready to assemble the workbowl - once properly assembled, the workbowl, lid, and pusher itself will push the button for you. On the DLC-2011, the proper assembly is for the work bowl handle to be locked toward the front of the processor. If you are still having trouble or you have a model other than the DLC-2011, call Cuisinart at 1-800-726-0190 and they will help you with the assembly.
Aug 18, 2009 | Cuisinart DLC-2011 PowerPrep Plus Food...
Can not get it to work
You definetly have to make sure the food cup holder is placed correctly in the bottom, and also have to make sure the top is turned securely until it cant go anymore so it will start spinning when you hit the button.
Nov 19, 2008 | Wolfgang Puck Bistro 620 Food Processor
KitchenAid KFC3100 Chef's Chopper Food Processor Logo
48 people viewed this question
Top KitchenAid Food Processors Experts
xalint1
xalint1
Shehu Pro
Shehu Pro
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
