Question about Dell 5100cn Laser Printer
Dell 5100cn won't print yellow - Dell 5100cn Laser Printer
jaylex
  • 417 Answers
SOURCE: Horizontal Striping Problem on a Dell 5100cn
As you have just replaced the drum you may have a faulty drum unit put old one back in a test if lines go way then return drum to store and get a replacement. If they do not go the check the toners and the fuser unit.
Thanks J
Posted on Jan 21, 2008
SOURCE: Prints only blue and pink
I had the same problem. I popped off the right side panel and wiggled all the wires and the yellow started working again. It seemed to be a connection problem.
Posted on Aug 01, 2008
Corysf62
  • 188 Answers
SOURCE: dell 5100cn leaving line only on full color pages
There is more then likely damage to one of the photo developers. This is what transfers the toner to the imaging unit. The Developer frame assembly has to be totally removed in order to change one or all of the developers.
The only other posibility is that the printhead needs to be cleaned, however, in order to clean the printhead you would still need to remove the developer frame assembly to access the front of the printhead.
Posted on Sep 28, 2008
  • 3 Answers
SOURCE: Dell 5100cn Paper Tray Won't Feed
i think you need to look your pc maybe something wrong inside your pc..try to do something for your dell..
Posted on Jan 19, 2009
kakee
  • 1269 Answers
SOURCE: dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
Posted on Jul 16, 2009
My dell 5100cn printer is not printing red tones at all. Everything comes out in green tones. Has new toner cartridges and drum. What can I do?
The M6090 Magenta Developer is failing. It has lost it's magnetism. So the toner isn't ready to be transferred.
The Cyan Developer G6593 or Yellow Developer H6682 may be failing too, because it can't dependably hold all it's toner. One of those is probably bad too.
Whit
Item, Inc
Aug 17, 2010 | Dell 5100cn Laser Printer
Dell 5100cn printer printing yellow lines across the page.
This can be any of rthe following depending on the position iof the lines on the page. You need to establishe the position of the lines relative to the top of each page and this determines which of the following component will cause the problem
Dirty or damaged developer roller.
Dirty or damaged charging roller.
Dirty or damaged cleaning roller.
Dirty or damaged developer DSD wheels. These wheels are located on the outer ends of the color toner cartridge and appear as a black bushing.
Dirty or damaged transfer roller.
Dirty or damaged transfer drum.
All of them need inspecting and cleaning
Sep 23, 2009 | Dell 5100cn Laser Printer
Dell 5100cn
How do I remove a job history page from printing on a Dell 5100cn printer?
Aug 06, 2008 | Dell 5100cn Laser Printer
There seems to be an electrical problem with the yellow toner. Check all the electrical contacts that make contact with the yellow toner. They may be just dirty or they may be bent. If they look good then the could be a problem with the power supply of the printer or the engine board.
Jun 16, 2008 | Dell 5100cn Laser Printer
Dell 5100CN Color laser printer - full page wash
Hello from france !!
Your mistake come from the fuser.
Change it and all be fun
See xerox phaser 6300 fuser is most cheaper and it's compatible !!
Jun 08, 2008 | Dell 5100cn Laser Printer
Dell 5100CN Not printing magenta
Dell 5100cn won't print yellow. No error messages except "replace imaging drum soon". Replaced yellow cartridge, cleaned yellow, etc. Still not working
May 13, 2008 | Office Equipment & Supplies
Thanks J
Jan 21, 2008 | Dell 5100cn Laser Printer
Dell 5100cn Laser Printer Problem
My Dell 1600n suddenly stopped printing. It keeps saying "No paper," and even though I've changed papers, fanned it, squared it, changed how much, how little.............it still says "no paper."
Dec 27, 2007 | Dell 5100cn Laser Printer
Dell 5100cn Laser Printer Logo
14 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
