Question about GPX HM3817DTBLK Shelf System
I have a GPX models7694 CD player. Everthing works but theCD player.There is no sound and the disk does not turn. Why?
The player was working fine. I went to move it just around the corner and I went to play it the CD made no sound. The radio, phono.,& cassett all work but no sound on the CD. I took the back off and the CD does not move. What would cause this.
  • 223 Answers
SOURCE: The CD player does not work
It sounds like a mis-aligned laser or faulty laser unit. Either way unless you have experience of fixings cd players yourself its a job for the technicians. Good luck.
Posted on Sep 26, 2008
SOURCE: Need owner's manual for GPX under-cabinet radio CD player
http://www.gpx.com/
then go to support
Posted on Dec 26, 2008
smarthome2
  • 1114 Answers
SOURCE: CD player in 00 Volvo S70 not working
Try a "Laser Lens Cleaner" one that uses fluid, you can find them at just about any electronics retailer for 15-20. Run it thru a couple times and try your cd again. If it plays, make sure you clean it 3 or 4 times a year. It's the only preventative maintanance you can do. If it still won't play, it need service, if it's just an am/fm/cd without a changer etc. your better off replacing the unit. The repair will run from 125-175 on average. They just replace th cd transport. Hope this helps
Posted on Jun 25, 2009
  • 66 Answers
SOURCE: Th cd are getting stuck in my gpx kccd6316dt, I
Is it still under warrenty?
Either it is worn out or it has a manufacturing defect.
Posted on Mar 24, 2010
  • 252 Answers
SOURCE: I have a GPX model
Your Electric motors are not getting enough power from your power suppy go in and make sure all the wires are plugged securly into their connection. This should solve your problem.
Posted on Aug 18, 2010
I have avolvos40 and the cd player jammed bought another one but i need a code to calibrate it
Alot of oem cd players require being programmed to the vehicle vin only a dealer can do this.
Aug 27, 2016 | 2005 Volvo S40
No sound from CD player. The turntable, radio & cassette work fine.
Can't get video to work so bose works with tv sound
Can't get video to work so bose works with tv sound I needed to reset the power on my bose and instead of unplugging the power cord, I unplugged the audio/video jacks because I couldn't see behind the
Oct 03, 2015 | GPX S7694 CD Shelf System
I put a after market cd player in my 2003 Olds Alero and now it didn't even work so I found out I had to have a adapter for the wire harnes so it whould power on the amp and safety dig still worked so I...
did you have battery disconnected when doing this ? if not you've blown a few fuses there is one on the back of the unit itself and check the fuse box for other blown fuses , when working on electrical system always disconnect battery when at the connection stage
Apr 23, 2014 | Cars & Trucks
My computer need system disk. how can i have that symtem disk. i want to install window xp
If you want o keep things simple and avoid all the headaches and woes of legacy computing then just get a bootable Windows XP CD ROM and make sure that your Computer hard disk is detected and working properly. Now insert the bootable Windows XP CD in theCD drive and reboot. Windows XP will start setup will turn on and the rest will be simple usual installation.
Jul 13, 2011 | Microsoft Computers & Internet
I have a cd stuck in my GPX KCCD3817DP CD player. How can I get it back? Will my cd player ever work again?
I had a gpx that did that to me. I tipped it forward at about a 45 degree angle and then tapped on the back of it and the door came ope. After this, it worked fine, so I just assumed it was a fluke thing that had happened???????
Feb 10, 2011 | GPX Audio Players & Recorders
My gpx karoke machine will not play at all power is on, shows cd number but no sound at all
Here are some things to try:
  1. Take the cd out, turn off the power, unplug the machine, plug it back in, turn on the power, put cd back in and try again.
  2. Check whether other cds play in it or if is it just this disc. Perhaps the disc is not compatible with the player. Might wanna check on that.
  3. Is the volume knob turned up?
  4. Does the mic work or is it just the cd? This will tell you if it is the disc or the machine that is not functioning properly.
  5. If no compatible disc works and the mic doesn't work and the volume is turned up, it "sounds" like the machine is defective.
Hope this helps. I'm a singer, so I wanna get you singing! Good luck.
Nov 04, 2009 | GPX Karaoke Party Machine CD+G Portable...
Dvd player
My worked fine for a 6 months then started reading bad disk even it the disk wasn't.
My solution to problem, buying a more reliable brand.
Apr 01, 2008 | GPX D1816 DVD Player
Memory loss
you need to remove the radio and swap the red wire for the yellow wire and vice versa, they have bullet connectors to allow you to do this, basically the permanent live and the ignition live are the wrong way round.
Nov 27, 2007 | Sony CDX-GT300 CD Player
Blinking MP3
is it an mp3 disk some cd players like this one I think does not sopport mp3 disks. (Try it another disk see if that works) ~Grim
Dec 09, 2006 | GPX CDPM5004 Personal CD Player
CD player not working
Insert Lens cleaning Disk, after cleaning the disk If the CD is reading change the lens.
Nov 10, 2006 | GPX C984 Boombox
GPX HM3817DTBLK Shelf System Logo
43 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
