Question about Home
Bunn airpot I took my airpot apart to clean it and the bellow doesn't seem to be working - not sure if I reassembled correctly.
5 Suggested Answers
SOURCE: Tripping BreakerS
I have the same problem with a new lg unit...it will trip the breaker after a few minutes of being on.
Posted on Oct 31, 2008
  • 131 Answers
SOURCE: Bunn CWTF15 Airpot brewer
If the unit does this constantly, it's probably seeping past the solenoid valve. you can try taking it off and check for dirt or corrosion that is stopping it from closing properly, or replace it. the solenoid valve is located under the front panel, and is silver in colour with 2 wires & 2 copper tubes coming to it. as always, please be sure there is no power coming to the unit before servicing!!
Posted on Feb 12, 2009
SOURCE: I just bought a bunn
on the inside of the lid there are 4 tabs. Take a small thin screw drive, like one used for a watch. Insert it between the inside lid and outside lip of the lid. Do this at all 4 tabs. and the lid will separate. For more help call (800) 286-6070 Bunn's customer service
Posted on Oct 10, 2012
  • 31 Answers
SOURCE: How much coffee per hour does the Bunn VPR-APS Pourover Airpot Coffee Brewer brew??
Bunn's pourover airpot coffee brewer brews 3.8 gallons of coffee per hour.
Posted on May 09, 2013
Bunn CW Coffee Brewer not brewing enough coffee - amount is half
Have you cleaned lately, put in an empty filter and fill with cold water with a tablespoon of white/clear vinegar. Run the brew cycle, empty pot and while still worm fill with cold water again with out vinegar. Than check filter to see how much hard water chunks are in the filter. Repeat with and without vinegar tell filter is clean. One question though is there a lot of steam coming out of the top during the brewing cycle if so inside there is a tube that may be cracked, broken or came loose, have to look inside. requires opening or disassembling unit to check. REMEMBER when taking apart UNPLUG unit first.
Nov 17, 2015 | Bunn CW Aps Single Airpot Coffee Brewer,...
Brewer stops @ halfway thru airpot, will not let me adjust brew level
take front panel off and on timer board is a little switch. move it from on to 1 then hold breww switch till you hear 3 clicks
Mar 31, 2014 | Bunn CDBCF 15 Coffee Maker
May 09, 2013 | Home
Coffee maker continues hot water flow even after making 2.5l of coffee. Randomly some days it makes the correct amount and other days it makes anywhere from 6oz to 30oz more causing the airpot to overflow...
definitely clean out the sprayhead. also, you may need to reset the dispense time on the board behind the front panel. the instructions are on the panel itself. make sure the switch is on "lock" after you are done.
Jan 27, 2011 | Bunn CDBCF 15 APS Coffee Maker
I just bought a bunn airpot. they give instructions for cleaning bellows and cap. how do i remove them from cover
Dec 24, 2010 | Microwave Ovens
Not enough water in airpot
Remove the front panel there are instructions on resetting the level.
Feb 25, 2010 | Bunn GMB-PS Coffee Maker
Can you turn a CWTF15-APS Airpot Coffee Brewer to a pour thru
Yes, most Bunn CW models have the ablilty to be used as a pour over. There should be a lid on top.
www.kaldi.com
Jul 20, 2009 | Coffee Makers & Espresso Machines
Water between the walls of the pot. How do we get it out?
I suggest contancting them directly for advise. Some of these types had a fluid for insulating, but i dont think Bunn did. Please Contact 1 800 637 8606 Bunn-o-matic
Jun 26, 2009 | Bunn 32125.0100 Airpot Stainless Steel...
Oct 25, 2008 | Bunn NHB Coffee Maker
Home Logo
740 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
