Question about McCulloch Garden
Wont turn off on stop switch - McCulloch Garden
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
Squirt some Wd40 type oil around the stop switch, will most times help it to make contact with the wires. Some corrosion may be present on those contact points on switch.
Posted on Jul 03, 2016
Kia hazard lights stay lashing even when the vehicle is not running and wont stop flashing
Has the HAZARD switch been activated? If the switch is off then there may be a problem with the switch or the flasher module.
Feb 20, 2015 | 2014 Kia Sorento
The blinker wont stop bleking when turning
Sounds like you have a bad turn signal switch, unless you ahve the emergency flashers on and one side is not working. turn on the emergenvcy flasher and make sure both sides work. if they do, you have a bad switch
Mar 21, 2014 | Subaru Outback Cars & Trucks
Flymo trimmer 700 wont switch on
if you can disconnect the switch wires and it starts you will have to choke to stop machine . but you will know if switch is faulty , sometimes it just dust in the switch itself , try blowing switch with compressed air first .
Mar 11, 2014 | Garden
1996 ford f 250 wont shift in to gear and brakes lights dont work
It would help to know a specific model, but a generic F250 answer is as follows. 15A fuse 13 in the fuse panel feeds power to the brake on/off switch which, when closed, turns on the high mount stop lamp. Power from the closed switch also is applied to the multifunction switch to turn on the stop filaments of the combination park/stop/turn lamps. If the fuse is OK and the high mount stop lamp turns on when you step on the brakes, all that remains is the multifunction switch or possibly burned out stop lamp filaments
Oct 09, 2012 | Cars & Trucks
Wont stop filling with water
You need to replace the fill switch its not sensing or stopping the w ater. It is fairly simple. Remove the plastic molding on the ends. Remove two screws holding down the control panel. The fill switch is over to the left, and has a clear tube attached to it. Remove tube and wires, lift tab keeping it from turning, turn 45 degrees and remove switch. Replace and test in all positions. Good luck whirlpool is a good brand.
Jul 12, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Windscreen wiper wont turn off
pull the fuse if it wont stop, faulty switch or relay sticking. get it from the junk yard. more likely it the wiper switch is faulty.
Aug 28, 2009 | 1996 Honda Civic
1998 chevy blazer
Unplug the turnsignal switch. If it stops then replace the switch. This is a common problem. Alot of times it is the hazard button that melts and causes it because all the turn signal functions go though the hazard switch but you have to replace the whole switch to fix it. Let me know what you find or if I can help you further. Please rate.
Dec 27, 2008 | 1998 Chevrolet Blazer
Winsheild wipers wont park or work properly
hi you have a short your favourite place to look is the wipers relay they are more likley to short than the switch and there cheaper if no joy remove your steering wheel cowls so you can get at the switch find out which wire feeds the relay to turn the wipers on see if its permenantly live when you turn the switch off if so replace switch if the switch works as it should and the relays ok then the motors faulty yates210456
Oct 10, 2008 | 1998 Honda Accord
Brake lights wont turn on
check the turn signal switch
Aug 02, 2008 | 1997 Chevrolet K1500
Tv wont stop changing channels
ok, Sony had this issue on their early production. The problem you are having is called a leaky switch. The volume down switch on the TV is leaky. To fix this you must replace the switch. This part is called the switch block. Part number 1-473-549-21
Average cost $26
Best regards
Circuitcity
Dec 18, 2006 | Sony KV-27V42 27" TV
Garden Logo
51 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
