Question about Motorola Mobility Tundra VA76r Cell Phone
Turns off unexpectedly
My phone turns off and reboots sometimes while I am talking to someone. It also sometimes works on vibrate and ring, and sometimes it don't do anything, you will open it up and see you missed a text. Other times it will work. I think there is justa problem with the vibrate part of the phone. But need it for my work when in place that needs te ringer to be quiet.
  • Official Brand Answer
  • 3,100 Answers
Check out Motorola Owners Forum. There may be a solution there. https://forums.motorola.com
Posted on Jul 25, 2014
SOURCE: loud key sounds
with your v3 press <<
>> select <<>> select <<>> in <<>> you must choose a ring style exemple:<<>> then goto <<>> and move to <<>> and change 7,6,5,4,3,2,1. Normaly, i put number 3 it's loud enought.
Posted on Aug 22, 2007
SOURCE: no sound when phone rings
I called Verizon Wireless and the said, if you go to “My Sounds” or “My Ringtones” select the song that you want to hear and press the play button. While the ringtone is playing press the button on the side of the phone to raise the volume…you should be able to hear the ringtone. Hope this helps!
Posted on Dec 12, 2007
SOURCE: RAZR ringer (speaker) doesn't work
the speaker inside the phone is in mis contact or it is dead .. try changing the new speakers into it ... it will work ...
if u are not gud at servicing then visit the technician........
Posted on Feb 11, 2008
  • 21 Answers
SOURCE: Pebble ringer inop
1 try this go setting initial/setup/master clear
password 000000 (6time) or full up 0 .
Posted on Mar 10, 2008
SOURCE: No ringer volume or speaker phone.
Posted on Nov 02, 2008
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
Aug 02, 2012 | Apple iPhone 3G
My phone will not vibrate at all anymore
Hi
Make sure your ringer is not in vibrate mode. Try These this thing first
Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls.
Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.)
Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option.
Press OK to assign a ringer. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not. Make sure the increase the volume using keys on side of your phone.
If none of these works the ******** motor needs to be cheked for loose connections inside the phone.
Thanks for using Fixya
Mar 24, 2011 | LG Ally Cell Phone
Phone will only vibrate and not ring
a. Make sure your ringer is not in vibrate mode.
1. Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls. 2. Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.) 3. Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option. 4. Press OK to assign a ringer.
b. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not.
c.Make sure the increase the volume using keys on side of your phone.
Mar 14, 2011 | LG RUMOR Cellular Phone
Hi, i can't get the ring tones to even play now...I've been doing some stuff on my blackberry and I wonder if I've turned something off that should be on now. When I set the volume, I did set it to tone...
This has happened to be before. Sometimes, the speaker just stops working. So dont get stressed out. To me it seems like you went through all the steps to fix it. You didnt do anything wrong. What I would do is call your phone carrier and ask if you could get your phone checked out. They will go inside the phone and check all the insides to make sure it works. That is what I had to do and it turns out that my speaker broke and I needed to get a new phone. So dont worry.
Mar 01, 2011 | RIM BlackBerry Curve 8310 Smartphone
My alarm won't ring or vibrate, but both work when someone calls me. I have it set for vibrate/ring but the screen just lights up when the alarm goes off, doesnt vibrate or ring
Reboot the HH,restart the HH and follow the follwing steps Press Menu,Select Clock-press menu-select alert type as tone-select the tone from the given list and save it.Check whether if you are able to listen to the tone.
Aug 04, 2009 | RIM BlackBerry Pearl 8100
When I recieve text messages my Lg xenon ''talks'' . For instance it will say ''message from ...'' I can not figure out how to turn this message alert setting off, I have looked everywhere on the phone but...
You need to disable Call Alert in your Voice Command settings...go into menu - settings - more - application settings - voice command. The last option on the list will be Call Alert, change to ring only.
Jul 31, 2009 | LG Xenon GR500 Cell Phone
The iPhone does not ring, only vibrates
There's a switch on the left side at the top of the iphone that turns the ringer on and off. Make sure this is towards the front of the phone to enable the ringer
Jul 26, 2009 | Apple iPhone 3GS Black (16 GB)
Samsung T629 does not ring when someone calls
your ringing style is either set to only vibrate or you made the phone silent. (hold the # key to off and on silence)
Please Don't Forget To Rate "FIXYA" Me For The Help
Dec 21, 2008 | Samsung SGH-t629 Cellular Phone
I can't get incomming calls
When I press talk to make a call, it just beeps and turns off, there is no ring tone? There is a new battery and the charge light is lit when the phone is on the base. Please advise.
Dec 05, 2008 | GE Telephone pr521w
Motorola Mobility Tundra VA76r Cell Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
