Question about Farberware 4-Slice Waffle Maker with locking lid, Stainless Steel
Waffle maker doesn't brown on bottom
Top side browns ok
How long do i keep the waffle batter in
Shortly after closing the waffle iron it will start to steam, Watch when the steam stops and open the iron. The waffle should be golden brown.
After you get the hang if it you can adjust the cooking time for lighter or darker waffles. There are videos on Youtube that may help too.
Jul 03, 2014 | Black & Decker WMB505 Waffle Maker
I made some yummy waffles in my kitchen waffle maker and forgot about the one waffle. Several months later, I went to make waffles again and found a terrible black powder in the appliance. The waffle had...
Unfortunately you have ruined a perfectly good waffle maker...
The coating in there is a teflon coating that needs to be applied properly for it to work...if you try to use it in the condition it is in then the waffle will stick to the plate...
Best thing to do is to trash the old one and then buy a new one...
heatman101
Jun 24, 2011 | KitchenAid Kitchen Appliances - Others
The waffle only browns on one side. Just bought the waffle maker today.
check the users manual.the unit may have a switch the will turn the upper and lower heating element on.
Mar 14, 2011 | Bella Kitchen Appliances - Others
When using a toastmaster waffled maker do you have to use an oil or butter pan spray?
Normally you mix oil in with the batter, but this doesn't keep the waffles from sticking. Even non-stick waffle makers stick some. Use a light spray of Pam (or similar) on the bottom tray, add your batter than spray the top pan and close. This gives you your best shot at a perfect waffle!
Enjoy!
--W/D--
Jan 17, 2011 | Toastmaster 217 Cool Touch Belgian Waffle...
How do you know when a waffle is finished cooking
It should be light brown on the outside and have a hard cover. It only takes several minutes at the correct heat setting.
hardrocko
Jan 31, 2010 | Krups 65475 WaffleChef Waffle Maker
Waffle maker won't heat
There is a thermal fuse inside the bottom half of the unit, enclosed in a white insulating sleeve. A replacement can be found on Amazon.com at the following URL:
http://www.amazon.com/Thermodisc-Degrees-Celsius-Thermal-Fuse/dp/B000T9VEV6/ref=wl_it_dp_o?ie=UTF8&coliid=I2M3QCVRS1C1IV&colid=2LRN9SBBQ2MW7
Aug 24, 2009 | Waring WMK300 Professional Belgian Waffle...
How do you know when it is done cooking?
Usually there is steam rising from the waffle maker when cooking, if there is no light on it to tell you when it is done watch the seam and as it is getting done there will be less steam than when it first started, if there is a light watch when it goes off or when the steam stops and then count minutes to when you open it to see how browned toasted you prefer
May 17, 2009 | Krups 65475 WaffleChef Waffle Maker
Waffle stickes
The question is! Was this waffle maker brought into the home new or used?
Jul 12, 2008 | Waring WMK300 Professional Belgian Waffle...
Farberware 4-Slice Waffle Maker with locking lid, Stainless Steel Logo
361 people viewed this question
Top Farberware Home Experts
Donni Steen
Tom Chichester
Are you a Farberware Home Expert? Answer questions, earn points and help others
