Question about Sendec Tachometer And Hour Meter
Reset oil sendec
Flashing change oil how do you reset it?
Tip
Pontiac service light 1983-01
Firebird
1998-01
To reset the "CHANGE OIL" light, press and hold the "TRIP/OIL RESET" button on the instrument panel for 12 seconds. When the light flashes and goes out, the system is reset.
Grand Am
1999 -01
To reset the Change Oil light, open the driver's side instrument fuse panel and turn the ignition on. Press the "RESET" button and release. The light will flash. Press the button again and the system will be reset.
Grand Prix
1999-01
Driver Information Center If Equipped). Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three times within five seconds. If the CHANGE OIL SOON indicator flashes two times, the system is resetting. Turn the ignition key to OFF, then start the vehicle. If the CHANGE OIL SOON indicator comes on and stays on, repeat the procedure. To reset the OIL LIFE indictor if equipped with a Trip Computer: Press the trip MODE button until the light appears next to OIL LIFE. Press and hold the trip RESET button until the oil life percentage changes to be 99 percent.
Grand Prix
1997-98
To reset the oil life indicator, press the "MODE" button until the light next to "OIL LIFE" is lit. Press and hold "RESET" for 3 seconds until oil life percentage is 100%.
Grand Prix SE
1997
Turn the ignition on, but do not start the vehicle. Within 5 seconds, push the accelerator to the floor 3 times. Turn the ignition off. Start the car and the Change Oil Soon indicator light will be reset.
Grand Prix
w/ Trip Computer
1988-93
To reset "CHANGE OIL", "CHANGE OIL FILTER", or the mileage of either on the Trip Compute, continually press the "SERVICE" or "SYSTEMS CHECK" button until the item appears with the mileage below it. Then press the "RESET" button and the mileage will be reset to the maximum value. If you want to reduce this value, hold the "RESET" button down and the mileage will count down. Release the button at the mileage you would like to observe.
Bonneville,
6000
w/ Driver Information Center
1983-91
To reset "CHANGE OIL SOON" or "OIL FILTER" or to adjust the mileage on the Driver Information Center, continually press the "DIC" button until either message appears with the mileage below it. At this point, hold down the button. In 5 to 10 seconds, the mileage will count down. When it passes 0, it will cycle back to a maximum figure. Release the button when the mileage gets to the service interval you'd like to observe. If "CHANGE OIL" or "OIL FILTER" already appears, just hold the button down to reset the mileage. "CHANGE OIL" and "OIL FILTER" are reset separately.
on Dec 07, 2009 | Pontiac Grand Prix Cars & Trucks
Tip
Oldsmobile service light 1991-01
Alero
2000-01
Turn the ignition to the ON position, engine OFF. Press the RESET button and release. The CHANGE OIL indicator will start flashing
2000: Press and release the RESET button again.
1999: Press and hold the RESET button until an audible chime is heard and then release the button.
Intrigue
2000-01
Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three times within five seconds. If the CHANGE OIL SOON indicator flashes two times, the system is resetting. Turn the key off after the the light has finished flashing, then start the vehicle. If the CHANGE OIL SOON indictor comes back on, the engine oil life monitor has not reset. Repeat the procedure again. If the vehicle is equipped with the U20 option code, the vehicle as an oil life low indicator. The oil life low indicator shows an estimate of the oil's remaining useful life. When the oil life index is less than 10 percent, the display will show OIL LIFE LOW. To reset the oil life monitor, press and hold the MODE button until the light appears next to OIL LIFE. Press and hold the trip RESET button until the oil life percentage changes to 99 percent.
Alero,
Intrigue,
Cutlass Supreme
1999,
1998,
1996-9
To reset the "CHANGE OIL" light, turn the ignition switch to the "RUN" position with the engine off. Fully depress and release the accelerator pedal three times in five seconds. The light will flash twice and go out.
Aurora
1995-99
To reset the "OIL LIFE" message, press the "ENG" button with the ignition on until "OIL LIFE PERCENTAGE" is shown. Press the "RESET" button for 5 seconds. "RESET" will appear and then "OIL LIFE" will show 100%
Eighty-Eight,
Ninety-Eight,
Regency
1994-97
When "CHANGE OIL NOW" is displayed, press the "RESET" button. Press "SEL" to display "OIL". Press "SEL" to display oil life. Press and hold "RESET" for 5 seconds. A "RESET" message should display with oil life changed to 100%.
Eighty-Eight,
Ninety-Eight
1992-93,
1991-93
Press and release the "TEST" button on the Driver Information Center. This will illuminate "CHANGE OIL NOW" if it is not already illuminated. Press and release the "OIL" or "OIL INDEX" button. Next, press the "RESET" button and hold for at least 7 seconds.
Toronado,
Trofeo
w/o CRT Display
1991
To reset "OIL LIFE INDEX", press the "2 OPTIONS" button: three times if the vehicle is equipped with a phone and compass, once if equipped with neither. While "OIL LIFE INDEX" is displayed, press and hold the "RESET/ENTER" key at the bottom right of the 15 button switch for 5 seconds.
on Dec 07, 2009 | Oldsmobile Alero Cars & Trucks
How to reset the oil change light?
super easy. gm did 2 things. in the fuse panel drivers door. there is a reset button. this resets for oil change light and low tire pressure. with key on hit the button, one of these light will be flashing, keep hitting it til change oil light is flashing. once it is flashing hold reset button til car dings and light stops flashing. done. if you have no reset button then turn key on press gas pedal fully down three times within three seconds of eachother light will flash and go out. good luck. these procedures are also in your owners manual.
Feb 22, 2011 | 2002 Pontiac Grand Am
Reset change oil light
To reset the system, you must do the following:
  1. With the ignition key to ON, push the RESET button located in the driver's side instrument panel fuse block.
  2. When the CHANGE OIL light starts to flash, press and hold the RESET button again. The reset is complete when you hear the chimes sound and the CHANGE OIL light goes out.
Dec 05, 2010 | 2001 Pontiac Grand Am SE
How do i reset the change oil light?
Nov 28, 2010 | 2000 Oldsmobile Intrigue
I had the oil changed but the change oil light is still on, how do i reset the computer? 2000 oldsmobile alero
How to Reset the Change Oil Light
After changing the engine oil, the system must be reset.
located in the driver's side instrument panel fuse block. The
CHANGE OIL light will start to flash, press and hold the
Oct 25, 2010 | 2000 Oldsmobile Alero
How to turn change oil light
iI you mean 'how to turn change oil light off" go to fuse panel. Open drivers door there is a panel cover on the side of dash board, remove cover there is a red RESET button that resets oil pressure and tire pressure. Turn the ignition key to the on position but don't start the car. Now press and release the reset button the change oil light should start to flash, now press and hold the reset button until you hear chimming hold until chimming stops then release, the change oil light should go off. If you need to reset tire pressure press reset button twice, the first push will make the change oil light flash the second press will make the tire pressure light flash then hold untill chimming stops, light should go out . Hope this helps.
Sep 30, 2010 | 2000 Pontiac Grand Am GT
Oil change light stays on after oil change
1. Turn ignition switch on but don't start the engine. Push ENG MET button on the trip monitor ONE time.
2. Press ENG MET one more time within 5 seconds. Within 5 seconds press and hold the RANGE button (90-94) or the GUAGE button on 95 Vettes, you will see the light start to flash
3. When light stops flashing the CHANGE OIL LIGHT has been reset
Apr 21, 2009 | Chevrolet Corvette Cars & Trucks
Change oil light reset?
Hi Shady, here is the procedure for resetting the light.
Resetting Procedure
Follow this procedure to reset the GM Oil Life System™
  1. Turn the ignition to RUN, with the engine off.
  2. Fully press and release the accelerator pedal three times within five seconds.
  3. If the CHANGE OIL SOON light flashes, the system is resetting.
  4. Turn the key to OFF after the light has finished flashing, then start the vehicle.
  5. If the CHANGE OIL SOON light comes back on, the engine oil life system did not reset. Repeat the procedure.
With Trip Computer
  1. Press the MODE button until the light appears next to OIL LIFE.
  2. Press and hold the RESET button for three seconds. The oil life percentage should change to 100 percent.
Nov 02, 2008 | 2002 Pontiac Grand Prix
Sendec Tachometer And Hour Meter Logo
864 people viewed this question
Top Sendec Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Sendec Measuring Tool and Sensor Expert? Answer questions, earn points and help others
