Question about HP Firebird with VoodooDNA 802 PC Desktop
Cmos battery clock not working
Clock stopped working on desktop how do i change the clock battery
There is no "Clock Battery" The only battery on a PC is the CMOS (BIOS) battery and it is a small "penny" battery. Just turn off the power and replace the battery.
Sep 03, 2013 | Packard Bell Computers & Internet
Inspiron laptop clock occasionally reverts to July 2008
There is a small 3 volt battery on the motherboard which is the backup for the circuit clock .So if the battery has gone low in voltage the clock will be reset as the CMOS setting will be reset. The clock will then go back to the time of the laptop set-up which is in july 2008.
Replacing and then correcting the CMOS set- up on booting will set the clock to work to the current time/date.
Sep 16, 2011 | Dell Computers & Internet
Hi, I have a dell studio 1535 and the bios clock runs very fast. In one hour the clock pass few days. I try updating the bios, set to default values and nothing changes. This is a CMOS...
I dont think it is a cmos issue because i replaced the cmos battery and it did not help my clock. I also had dell fix the motherboard and it worked for bout 7 months unfortunately after my warranty was up. Til this day my clock last no longer then a few hours until it reverts back to the time i changed it to.
Dec 27, 2010 | Dell Studio 15 Laptop
Dell inspiron 1545 laptop (Time- of- date clock
This could mean two things: a problem with the cmos battery or the motherboard itself. Try to remove the cmos battery first and install. If not,then replace the cmos battery.
Oct 12, 2010 | Dell Inspiron 1545 Notebook
Is the cmos battery on a vaio vgn-fe31m on the
Yes the cmos battery is on the motherboard.
Every motherboard that runs a computer has a backup battery to run the circuit while turned off. This battery runs the real-time clock (RTC) and is referred to as the CMOS battery. By keeping the clock active and running even when the computer is switched off, power up/down cycles can be logged and before the internet, your computer could keep dates accurately. It also serves to maintain the system configuration settings in BIOS memory based on RAM or FLASH RAM.
Jun 24, 2010 | Sony VAIO FX150K Notebook
Bios clock has stopped on Fujitsu T4215 tablet pc. Have tried: 1) updating bios 2) re-installing cmos clock Clock starts again once in Windows (but from static date in bios) and can synchronize clock from...
I thik your CMOS clock (HH:MM:SS ) SS digit not moving forward. If it is then just unplug your CMOS Battery and 5 min later reassemble it ...your problem will be solved.if your BIOS whole setup reset including clock and SSS digit moving forward then replace your CMOS battery...if your not expert to open laptop then take a expart help to open it and run this procedure..
May 14, 2010 | Fujitsu LifeBook T4215 Tablet PC
Clock not keeping correct time
The CMOS battery keeps the laptop configuration stored in the CMOS chip and the main battery has no effect on the CMOS.
If the date and time drift off, it indicates the CMOS battery is nearly flat and needs to be replaced.
If you had ticked the Daylight saving box in the Time Zone tab in Control Panel - Date and Time setting then the time would automatically adjust for Daylight saving.
Apr 05, 2009 | IBM ThinkPad T40 2373 Notebook
CMOS BATTERY
Gateway 450ROG CMOS BatterySmall internal battery that maintains calendar and clock settings.
PLEASE NOTE: This is not the battery that powers your laptop; it only maintains certain internal settings. If you need a main battery, please refer to the page on our web site for your laptop model.
CMOS batteries are located on the motherboard; if you are not comfortable with the inner workings of your laptop, you may want to consider having the battery installed by a qualified technician.
Here is the link to their site for your cmos battery
http://www.gatewaylaptopparts.com/shopexd.asp?id=1082
Feb 25, 2008 | Gateway 450ROG Notebook
HP Firebird with VoodooDNA 802  PC Desktop Logo
16 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
