Question about Manitowoc QM30 Under Counter Ice Maker
My Icemaker won't keep the ice once it makes it
My ice maker makes the ice, but it keeps melting in the bin.
What make and model of ice maker do you have?
Is the unit making ice? If so, about how much?
Most commercial bin type ice makers are not engineered to maintain the ice once it drops into the bin. Older ice is intended to melt and the water should drain out of the bin as new ice is deposited on top.
It may be that you are consuming ice at a rate greater than the unit is designed to produce ice, or that the unit is not set to the highest ice production rate (if adjustable).
Alternatively, if the inside of the bin is hot (warm) you may have another problem with the unit (e.g., gasket leak). Was the unit previously working? If so, are you aware of any events that took place just prior to the change?
Some units have a defrost or a cleaning mode, which will actually generate heat inside the unit. Make sure the unit is set to the correct mode.
Posted on Apr 14, 2014
  • 3 more comments
  • Bob V
    Bob V Apr 14, 2014
    Sorry I see you did specify the type of unit. I looked at the ice maker specs. the bin is only insulated, it is not refrigerated. The ice is suppose to melt down as new ice is made. See link:
  • Bob V
    Bob V Apr 14, 2014
    Add a Commenthttp://www.air-n-water.com/product/qm30.htm?utm_source=bing&utm_medium=comparisonshopping&utm_term=Manitowoc&utm_campaign=Ice%20Maker&utm_content=QM30
  • Bob V
    Bob V Apr 14, 2014
    Here is a link to your operating manual:
  • Bob V
    Bob V Apr 14, 2014
  • Bob V
    Bob V Apr 14, 2014
    http://cache.air-n-water.com/manuals/man...
Icemaker not making ice
sometimes when the icemaker is not used,,water will thaw, drip/pool around the auger,,this will keep it from dispensing.
take the bin out, inspect all the parts for ice...ck that the on/off wire is in the correct position
Apr 15, 2014 | Kitchen Appliances - Others
How do I get my my GE refrigerator model no. GSS201EPJWW to stop making ice? Bin fills with ice but don't know how to turn off icemaker. Thanks
slide the panel out from in front of the icemaker,there is a slide switch on the icemaker marked on/off
Jan 11, 2013 | Refrigerators
Scotsman icemaker dce33 is making ice, but it is melting
Yes it could and also check dump valve it should not let water through during freeze cycle.
Oct 03, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
The icemaker is not making ice as fast as it would before. It dumps a tray of ice about every 4 hours.
Make sure that there are no kinks in the water line.
Next, inspect the feeler arm of the ice maker and make sure that it is down and not blocked by any ice cubes. If it's raised, it has turned the ice maker off. This arm needs to be in the lowered position to activate the ice maker An over-abundance of ice in the bin will make the arm stay up as a safety feature to keep the ice maker from making more ice than the bin can hold.
Jul 30, 2011 | Refrigerators
Seems to make ice but will not keep it cold therefore it melts. It does this about 3 or 4 times a year but after staying off it will start working again
The only thing that keeps the ice cold is the ice itself. If the icemaker isn't making ice fast enough then the ice will melt before more ice drops to keep it cold. In other words the motor ice the slower the ice melts. Now if the door gasket isn't sealing properly then the ice could melt to fast. Also the ice is going to melt some and when it does the water has got to drain out the bottom. If the water doesn't drain the ice will be sitting in water and will speed up the melting process dramatically. I hope this helps!
Sep 28, 2010 | Scotsman DCE33PA1BC 15in Built-in...
Melting/refreezing ice in the ice makes
If the ice is the only item that appears to be melting or defrosting. I would believe the most possible issue. The icemaker is leaking intermittantly into the bin and freezing the cubes inplace.
Ric
Mar 09, 2010 | Amana ABB2527DES Stainless Steel Bottom...
My icemaker is making huge chunks of ice in bin
You will need to replace the termination thermostat. What sounds like is happening is. Every 8 to 10 hr. your freezer goes into defrost for a set period of time. There is a termination thermostat that senses the temp at you evaporator coil in you freezer. When you heaters come on they defrost the ice from your coil. once the termination thermostat senses the temp has gotten to a preset degree, it cuts the power to the heaters. This keeps the heaters from staying on the whole period and making your freezer warm. After the pre set time period the timer turns the compressor back on. What it sounds like is happening is the termination thermostat is not opening, cutting the heaters off. By not doing so, it's letting your freezer get above freezing, melting your ice some. When the timer advances into cooling again it freezes your ice together. I would say it's your water valve leaking but that would make large pieces of ice that the ice maker has trouble dumping and also sometimes a large chunk that does not look like cubs. That would also eventually freeze the inlet tube closed..
Please rate solution
Aug 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Monogram Ice Maker makes ice, unit doesn't cool enough
This model Icemaker makes ice by flowing water across a freeze plate. It is located in the top of the unit behind the white cover directly below the ON/OFF/CLEAN switches. After freezing a sheet of ice it releases and slides to the cutting grid. It then drops into the ice bin and begins to melt and the whole process starts over again. The level of ice in the bin is controlled by the high level sensor on the right side of the ice bin. It is a whit tube with two wires coming out of the top. Without this sensor it can overrun the bin capacity. Bottom line this unit does not freeze ice, it only holds it like cooler does.
Jun 03, 2009 | GE Monogram ZDI15C Automatic Icemaker
Manitowoc QM30 Under Counter Ice Maker Logo
85 people viewed this question
Top Manitowoc Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Manitowoc Heating and Cooling Expert? Answer questions, earn points and help others
