Question about Maytag Neptune MAH5500B Front Load Washer
Warm rinse washing machine - Maytag Neptune MAH5500B Front Load Washer
When I take my clothes out after washing them they are quite warm?? The final rinse is a cold rinse. So how is it that my clothes are warm when I take them out? Is this normal? never used to do it?
Without knowing what your machine is, I can only guess. Perhaps your machine has clogged cold input, and it's using hot because that's all it can get?
Maybe it always uses a little hot, and the cold is clogged or just not opening... Does it seem to be taking longer to fill than it used to?
Jun 17, 2015 | Washing Machines
EW1200 is rinsing in hot water how do we change that
Hot wash, hot rinse is for 'whites'. Cold wash, cold rinse is for 'colors'. Warm wash, cold or warm rinse is for 'permanent press'. Check your settings to see if you have these options. Double check the hoses, put the machine on cold fill and feel the hoses.
Has someone worked on the machine and possibly put the wires on the solenoids wrong? Easy mistake to make.
Mar 10, 2012 | Electrolux EW1200i Front Load Washer /...
Warm Wash: Force it to be cold?
you will need to put a "Y" in the cold water line and remove the hot water hose otherwise the hot water solenoid will open up and let in hot water,if you have cold water to both solenoids then you can get done what you want to accomplish,wash and rinse in cold water on all cycles
Dec 24, 2009 | Washing Machines
When my machine goes through the rinse cycle it will only fill with hot water. It fills with warm water during the wash cycle.
Your hoses are reversed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 30, 2009 | Washing Machines
Washing machine not rinsing
Set your machine for warm wash warm rinse.
If it works OK.
Replace the water inlet valve.
Feb 14, 2009 | Kenmore 22422 Top Load Washer
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
ZANUSSI ZWD162701 washing always comes out cold - WHY?
Washers are meant to rinse in cold water, so clothes should come out cold.
If you are not sure if it is getting hot, then select a very hot wash, and feel the door glass periodically, it should gradually get hotter, if it does not , then it is washing in cold water only.
This could mean that the heater element has gone.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Zanussi ZWD1270 Front Load Washer / Dryer
Washing machine
Try reversing the water fill hoses
Jan 05, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Maytag Neptune MAH5500B Front Load Washer Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
