Question about Winter Sports
Snowmobile troubleshooting 2004 polaris xc 500 liquid With electric reverse. Runs great in reverse, lacking power while motor is running in foward. Temperature light stays on with cold engine, stays on even if unplugged or crossed
    Problem Solver:
  • 14 Answers
Most newer machines derate (reduce power) when the temp light comes on unplugging it may not change anything because the ECM still senses a problem with the temp maybe a sensor problem
Posted on Feb 13, 2014
1999 XC SP 500 ,1,500 miles only----starts and runs - then at different occurences the sled will just die. SIt for awhile (minute of two) starts again and dies and then wait a few minutes, starts and...
WHEN THIS HAPPENS, CHECK FOR SPARK. IF IT HAS NO SPARK THAN IT IS AN ELECTRICAL FAULT. IF IT HAS SPARK IT COULD BE FUEL DELIVERY PROBLEM OR A INTERNAL ENGINE PROBLE.
Dec 28, 2010 | Polaris New Genuine Polaris Snowmobile...
Polaris xc 500 twin one cylinder not running right
DOES THE CYLINDER HAVE LOW COMPRESSION. IT SHOULD BE SOMEWHERE AROUNT 100-130 PSI AND NO MORE THAN 15% DIFFERENCE BETWEEN THE TWO CYLINDERS. IF IT IS LOW, A REBUILD IS GOING TO BE REQUIRED. IF IT IS OK THAN CHANGE THE PLUGS AND DO A CARB CLEANING AND SYNC THEM.
HOPE THIS HELPS
Dec 26, 2010 | Polaris New Genuine Polaris Snowmobile...
1999 500 xc head light goes out every once and a wile but comes back on for no apparent reason
THIS IS USUALLY CAUSED BY THE VOLTAGE REGULATOR OR BAD CONNECTION IN THE WIRRING SYSTEM
Dec 23, 2010 | Polaris New Genuine Polaris Snowmobile...
On a 2002 polaris 325 magnum when going in reverse motor cuts out but runs fine if push reverse override. runs fine in foward gears
That is called a REV LIMITER. Its there to make sure you dont go too fast in reverse due to it being slightly more complicated to steer. They put the override button on there in case you DO want to go faster. Its pretty much standard on all quads. Similar to how low a regualr car is geared when in reverse. I hope this helped!
Nov 13, 2010 | Polaris ATV
I have a 2004 polaris prox2600 snowmobile with perc reverse and every time i engage the reverse button the sled shuts off any ideas would be greatly appreciated
did you let the sled warm up first? If the sled is'nt warmed up flip the choke lever while its running and quickley press the reverse button make sure you shut choke back off or you can load up your sled. Good luck let me know
Jan 20, 2010 | Polaris New Genuine Polaris Snowmobile...
Reverse issues
i believe that your reverse gear is a kit. Now they are not gear driven, they actually run the motor in reverse to back you up, anyways, if you look down from your reverse lever, you will see a adjuster nut or guide bolt. try adjusting that some. you definitely don't want to keep grinding those gears!! reverse kits are around 500 bucks. Good luck
Jan 23, 2009 | Polaris New Genuine Polaris Snowmobile...
Winter Sports Logo
409 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
