Question about Jura Capresso Impressa F7 Espresso Machine
Drawer won't close - Jura Capresso Impressa F7 Espresso Machine
Hitachi ax-m71 cd door won't stay closed. Unable
if it opens back up when you close it the drawer mechanism is probably out of alignment. Most players have a slot on the bottom of the drawer that a pin must slide in. Look under the drawer and see if there is a pin sticking up that maybe should be in that slot.
Jul 09, 2013 | Audio Players & Recorders
Sharp CD-BA2100 cd drawer won't turn or close.
Take the 4 screws out of the top, lift the CD drawer out, disconnect the two wire harnesses, take the top off, lift the 3 disc tray out, then force the drawer open and closed a few times until it slides freely. Put it back together and it may or may not work. Worked for me.
Mar 28, 2013 | Sharp CD-BA2100 CD Shelf System
Dishwasher beeps but won't run
There could be several reasons for the beeping. The dishwasher checks for sensor to make sure it is in good health before it starts. Most likely the drawer close sensor is detecting fault. This is to ensure the drawer is closed fully to avoid water leaks when dishwasher is on. Sometimes sensor itself has failed and has nothing to do with position of drawer. Open top cover carefully to make sure the drawer is travelling ok on the rails. TAKE MAINS POWER CABLE OUT BEFORE WORKING ON DISHWASHER.
Mar 17, 2013 | Fisher and Paykel DD24DCTB6 Builtin...
Top drawer won't close
After completing a cycle the top drawer feels like it will not open or the top of the drawer has fallen down. I've since forced it open but, now it feels like it will not close. I did not force it to close. How do I remedy this problem?
Mar 02, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
The cd drawer won't stay closed
the cd drawer will probably use infra-red to sense when the drawer is open or closed or maybe just a gear mechanism, either way these must be clean, I'd take it apart and lean it all with cotton buds and isopropyl alcohol
Feb 07, 2013 | Audio Players & Recorders
I have a Minolta CSPro 3050.. legal paper drawer won't close..and it won't copy
To the rear cover located one hole before waste toner box.Introduction one long screwdriver and push the unlock button.
Jan 18, 2013 | Konica Minolta Copier Toner EP6001 CS Pro...
Drawer door won't stay close
Hi Paul Lehto - I understand that the drawer will not close, however may you please provide me the model number so I can assist you better in pinpointing you the information.
Dec 19, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
Cd drawer won't close
Check its loading belt. Replace it.
Jun 18, 2012 | Kenwood XD-A900 Shelf System
POT AND PAN DRAWER WON'T CLOSE PROPERLY
Take out the drawer. Lift it out. Make sure nothing is in the tracks. Take everything out of the drawer. Put it back and watch the tracks. If it closes properly you've over loaded it, otherwise you have bad tracks.
Jan 23, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
Jura Capresso Impressa F7 Espresso Machine Logo
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
