Question about FreeMotion Treadmill t7.3
Controller comm error - FreeMotion Treadmill t7.3
Bad Controller Comm Error. I swapped out Controller but still get same error, any suggestions?
i recommend to replace the control board. This is very critical matter for the electronic machine. see the diagram attached, How the controller motor hast the 80 of control of machine.
go to www.fitnessrepairparts.com and get it
Sep 23, 2013 | Life Fitness LifeFitness 9500HR Treadmill...
Aquqsmart Error 105
105. (01101001) Comms Error Time Out
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Tertiary Source: Rotor Position Sensor
Action: Replace Rotor position Sensor. If this corrects the fault refit the
original Display Module and/or Motor Control Module.
Jan 26, 2012 | Fisher and Paykel Washing Machines
My dodge journeys cd player say
My cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix this
Jan 03, 2012 | 2010 Dodge Journey
I have error codes flashing on my thermostat..it is an american standard model the manual for the therm. has ACOT900AC43UA on front..says to find addedum 18-HD32D2-1/69-2009 for codes i cannot find it...
Error codes from American Standard Pub 18-HD32D2-8, which is a one-sheet document that came with my American Standard air-conditioner:
29 = not listed
129 = not listed
80 = HPCO Fault - problem is in outdoor unit - Desscription: High Pressure Monitor Fault (hard lock out, cycle power to reset)
91 = Communication Inactive Fault - problem is in air handler - Descriptions - COMM Bit Master Clock Error, COMM Heat/Cool Demand Error, Serial Motor Communication Inactive Error
91 = Communication Fault - problem is in furnace - Descriptions: Blower motor no COMM response, Inducer motor no COMM response, Loss of heat/cool demand, Loss of clock signal
91 = Communication Fault - problem is in outdoor unit - Descriptions: Loss of Heat/Cool Demand Message (COMM), Loss of Bit Master (Clock Signal)
91 = Communication Fault - Description: Comm line is dead and no bits have been received.
By the way, I do not recommend American Standard. I've had mine 14 months and it just blew up - the entire control panel blew. My advice to you - think about a different brand.
Nancy
Scottsdale, Arizona
Aug 22, 2010 | American Standard Heating & Cooling
Fax comm error 232 problem
Hello sir ; Why don't try to replace a phone cable or check the wall jack.
Aug 28, 2009 | HP LaserJet 3050 All-In-One Printer
HP 3050 Engine Comm error
I have a HP 3050 three in one and I keep getting a engine comm error
Aug 02, 2009 | HP LaserJet 3050 All-In-One Printer
ERROR MESSAGES
nthemba- all the error codes you see indicates phone line condition or error at reciving fax's end. For more details you can refer to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&lc=en&dlc=en&cc=us&product=79477&rule=17804&lang=en
Sep 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Canon MF6500 Error Code E197
Error
E197 0000 is a Printer engine communication error.
A erroneous comm's error occured between the DC controller PCB and
image processor PCB was detected.
Prnter needs servicing
Check cabling connections on theDC controller PCB and image
processor PCB.
If still same then you have to replace DC controller pcb.
If still fials then you have to replace the image processor pcb.
Aug 05, 2008 | Canon imageCLASS MF8170C All-In-One Laser...
FreeMotion Treadmill t7.3 Logo
60 people viewed this question
Top FreeMotion Exercise & Fitness Experts
Howard
Howard
ray gallant
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
