Question about Panasonic DMR-EZ47V DVD Recorder/VCR
No read problem - Panasonic DMR-EZ47V DVD Recorder/VCR
SO184 able to read of82b?SO184 able to read of82b?SO184 able to read of82b?SO184 able to read of82b?SO184 able to read of82b?SO184 able to read of82b?SO184 able to read of82b?SO184 able to read of82b?SO184...
so184 just an adapter that he did not read the chip function so184 long as the customer can get him on the chip package on it. TSOP 32 is thought that this type of chip packaging can be placed inside the adapter.
May 17, 2014 | obd2-scanner Car Diagnostic Fault Code...
. In town of 500
real problems not jokes please:0
Sep 23, 2010 | Computers & Internet
Alina read 56 pags in 3 hours. At the same rate, find the number of hours it will take her to read the remaining 40 pages
> Alina reads 56 pages in 3 hours.
Alina reads 56/3 pages in 3/3 hours.
Alina reads 18 pages in 1 hour.
Alina reads 18 pages in 60 minutes.
Alina reads 40 pages in (40/18)*(60) minutes.
Alina reads 40 pages in (40*60)/18 minutes.
Alina reads 40 pages in 2400/18 minutes.
Alina reads 40 pages in 400/3 minutes.
Alina reads 40 pages in [about] 133 minutes.
Aug 02, 2010 | Computers & Internet
Change time
Hey here is something you can use to adjust the time on your T7206.To Change the Time:
1. Press the CHANGE softkey Display will read: "Hour:
2. Press the CHANGE softkey Display will read: "Hour: _ "
3. Enter the new HOUR. (in 24-hour format - Ex.: 5:00pm = 17:00. Display will then read the new Hour programmed.
4. Press NEXT Display will read: "Minutes: # # "
5. Press the CHANGE softkey Display will read: "Minutes": _ "
6. Enter the new MINUTES.
To Change the Date:
1. Press NEXT Display will read: "Date DD MM YY"
2. Press the CHANGE softkey Display will read: "Year: # # "
3. Press the CHANGE softkey, (If the year is incorrect) Display will read: "Year: _ "
4. Enter the new YEAR Display will then read the new Year programmed.
5. Press NEXT Display will read: "Month: # # "
6. Press the CHANGE softkey, (If the month is incorrect) Display will read: "Month: _ "
7. Enter the new MONTH Display will then read the new Month programmed
8. Press NEXT Display will read: "Month: # # "
9. Press the CHANGE softkey, (If the day is incorrect) Display will read: "Day: _ "
10. Enter the new DAY Display will then read the new Day programmed
Let me know how that turns out and good luck
Oct 03, 2008 | NorStar T7208 Corded Phone
Comdo fail to read DVDs'
  1. Check its DVD reading speed
  2. Try reading a prerecorded or original DVD disk for a movie for example, if it can read this then it means the DVD you are tryng to read were burnt at speed faster than what your DVD can read.
Mar 25, 2008 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Dvd writer doesn't read or burn dvd/ but only read CD-R plz reply to ka_s5@hotmail.com
have you installed the softwares to burn DV/CDs? maybe you hadn't installed the softwares yet. normally samsung uses NERO. check the installation kits.
Oct 31, 2007 | Computers & Internet
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
