Question about Activision Call of Duty: Ghosts Hardened Edition - Xbox One
Unable to verify rights
When i try to start the game, it says unable to verify rights. Then the screen goes black
I click play, screen goes black
The first thing I would try is to update your video card drivers.
Then run windows update and make sure that all critical updates are applied.
Then I would download the update patches for the game and apply them to see if that had cured the problem.
Feb 14, 2014 | Activision Wolfenstein
Have all the requirments on windows7 on launching the game the screen goes black and does nothing tried patches it then comes up with unable to find serial key which it doesnt have or cant enter as this...
Right-Click on the icon, hit properties then goto the combatability tab. check 'run as administrator' if that doesn't work.. goto the same place.. check 'run in compatability mode' and select a previous version of windows.
Mar 25, 2011 | Enemy Engaged 2 for Windows
Have video issues on my Acer Z5600 23 inch touch screen. can anyone help? Ever since this thing updated I have not been able to play any games. if it goes to a full screen res then it goes to flashing from...
hi i have an aspire z5600 when trying to play an installed game the game starts then the screen goes black but i can hear the game behind the black screen ! hope you can help thanks .
Stu
Nov 26, 2010 | Acer Aspire Z5600 PC Desktop
I can hear the game, but screen goes black.
I believe your game needs higher version of CPU, i.e. at least P4, apart from this directx cannot work unless you have a proper graphic card available on your motherboard to support the game video.
Sep 04, 2009 | Activision Wonder Pets:Save Puppy-PC for...
Startup screen goes black.
I would try having the firmware reloaded or updated. Sounds like a problem there. Try going to xbox.com and downloading the update for playing older xbox games. This also updates the firmware.
Joe
May 20, 2009 | Microsoft Xbox 360 Console
My screen goes black whenever i try to start starcraft.
Right click on the game icon, select properties and select the compatibility tab. From there check the "Run this program in compatibility mode for:" box and select Windows XP (Service Pack 2). It might be good to also check "Disable visual themes" and "Disable desktop composition" Hope it helps.
-- WykidTECH
Mar 15, 2009 | Blizzard Entertainment StarCraft Battle...
Unable to play missile command
Have you defragged the computer within 30 days?
if not, do so.
Does your "C" drive (HDD) have more than 15% of disc space left? if not, get it back to a minimun of 15%.
Do not use the computer while defragging.
Mastersage......................
Feb 15, 2009 | Hasbro Interactive Missile Command for...
It wont open
Because your window instol is not right so the game not start and your pc is not bigger to start this game
Feb 08, 2009 | Electronic Arts Counter-Strike: Source for...
Monitor
are you sure that its your screen? try another screen if it does it. if not, then try using a differant res and refresh rate.
beings that your screen freezes and then goes black on exit.
I would say, your game is heating up your computer by useing stuff that usually dont get used. try removing the cover and carefully cleaning all heat sync's so it can breath.
if the problem continues, please report back, with more info, on what game and what model system you have with operating system. also if you added a video card.
Apr 09, 2008 | Computers & Internet
Games are unable to play
try pressing the reset button.not the power. it might not work but just try it
Jan 17, 2008 | Nintendo Wii Console
Activision Call of Duty: Ghosts Hardened Edition - Xbox One Logo
457 people viewed this question
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
dj ese
Level 1 Expert
James Wishart
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
