Question about Dell Precision T5500 Computer Workstation PC Desktop
BIOS checksum failure - Dell Precision T5500 Computer Workstation PC Desktop
3 short beep continou when startup dell inspiron 5010
Beep Code
Possible Problems
  1. Possible system board failure - BIOS ROM checksum failure
  2. Two. No RAM detected
    NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
  3. Possible system board failure - Chipset error
  4. RAM read/write failure
  5. Real Time Clock failure
  6. Video card or chip failure
  7. Processor failure
  8. Display failure
Jan 23, 2014 | Dell Computers & Internet
Dell studio 1749 has 4 short beeps when trying to start
One Beep (Possible system board failure - BIOS ROM checksum failure)
Two Beep (No RAM detected)
Three Beep (Possible system board failure - Chipset error)
Four Beep (RAM read/write failure)
Five Beep (Real Time Clock failure)
Six Beep (Video card or chip failure)
Seven Beep (Processor failure)
Eight Beep (Display failure)
Feb 12, 2013 | Dell Studio 17 (1749) Laptop black -...
Cmos beep codes
do you know which bios your computer is running ?
AMI BIOS beep codes 1 beep - DRAM refresh failure
2 beeps - Parity Circuit Failure
3 beeps - Base 64K RAM failure
4 beeps - System Timer Failure
5 beeps - Processor Failure
6 beeps - Keyboard Controller / Gate A20 Failure
7 beeps - Virtual Mode Exception Error
8 beeps - Display Memory Read/Write Failure
9 beeps - ROM BIOS Checksum Failure
10 beeps - CMOS Shutdown Register Read/Write Error
Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
1-1-4 BIOS ROM checksum error.
1-2-1 System timer failure. (Programmable Interval Timer PIT)
1-2-2 DMA (direct Memory Access) failure.
1-2-3 DMA page register failure.
1-3-1 RAM refresh failure.
1-3-3 64K RAM chip or data line failure.
1-3-4 64K RAM odd/even logic failure.
1-4-1 64K RAM address line failure.
1-4-2 64K RAM parity error.
2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
3-1-1 Master DMA register test.
3-1-2 Mslave DMA register failure.
3-1-3 Master interrupt mask register failure.
3-1-4 Slave interrupt mask register failure.
3-2-4 Keyboard controller failure.
3-3-4 Screen (video) memory failure.
3-4-1 Screen initialization failure.
3-4-2 Screen retrace failure.
4-2-1 Timer tick interrupt test failure.
4-2-2 Shutdown test failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure above address 0FFFFh (64K +)
4-3-3 Interval timer channel 2 test failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port test failure.
4-4-2 Parallel port test failure.
4-4-3 Math Co-processor failure.
BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
hope this helps
Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
Long beeps not booting up
problem....the beeps are beep beep beep beep..........contiues...........plus the computer will then not recieve signal????
May 25, 2011 | MSI K9VGM-V Motherboard
Laptop beeps continuously on startup until "fn"
Number of Beeps: Failure Coverage 1) BIOS ROM checksum inprogress or failure. BIOS Chip 2) No RAM Detected No Memory Detected NoMemory Detected 3) Chipset Error (North and South Bridge Chipset,DMA/IMR/Timer Error for Intel platform); Chipset Error Motherboard FailureTime-Of-Day Clock test failure. Gate A20 Failure Super I/O Chip Failure KeyboardController Test Failure Motherboard Failure 4 )RAM Read/Write Failure Memory Failure 5 )RTC Power Fail. COMS Battery Failure 6 )Video BIOS Test Failure Video Card Failure 7 )CPU Cache test failure CPU Failure 8 )LCD LCD Failure
Apr 20, 2011 | Dell Alienware M11x (Intel Core 2 Duo...
I have a gateway desktop that is beeping before post. It beeps and will not post.
It depends on the motherboard model, but here is an example of the error codes for a gateway:
Beeps Error Message Description 1 Refresh Failure The memory refresh circuitry on the motherboard is faulty. 2 ECC Error Error Checking and Correction (ECC) is supported on this product. 3 Base 64 KB Memory Failure Memory Failure in the first 64 kilobytes (KB). 4 Timer Not Operational Memory Failure in the first 64 KB, or Timer 1 on the motherboard is not functioning. 5 Processor Error Ther processor on the motherboard generated an error. 6 8042 - Gate A20 Failure The keyboard controller, 8042, may be bad. The basic input/output system (BIOS) cannot switch to protected mode. 7 Processor Exception Interrupt Error The processor generated an exception interrupt. 8 Display Memory Read/Write Error The computer video adapter is either missing or its memory is faulty. This is not a fatal error. 9 ROM Checksum Error Read-only memory (ROM) checksum value does not match the value encoded in BIOS. 10 CMOS Shutdown Register Rd/Wrt Error The shutdown register for complementary metal-oxide semiconductor (CMOS) random access memory (RAM) failed.
Nov 10, 2010 | Computers & Internet
I have an HP NetServer E800 when i power on it beeps 4 times then no signal on screen???
Code Beeps POST Routine Description
16h 1-2-2-3 BIOS ROM checksum
20h 1-3-1-1 Test DRAM refresh
22h 1-3-1-3 Test 8742 Keyboard Controller
2Ch 1-3-4-1 RAM failure on address line xxxx*
2Eh 1-3-4-3 RAM failure on data bits xxxx* of low byte of memory bus
46h 2-1-2-3 Check ROM copyright notice
58h 2-2-3-1 Test for unexpected interrupts
98h 1-2 Search for option ROMs. One long, two short beeps on checksum failure.
B4h 1 One short beep before boot
Jul 29, 2010 | HP NetServer E800
What does a AMI bios beep code of one long and 9 short
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code
Descriptions
1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed
Jun 01, 2010 | Asrock 939SLI32-eSATA2 (939SLIESATA2)...
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
Dell Precision T5500 Computer Workstation   PC Desktop Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
