Weld not detect see user manual
It prints and stops but when i clear it will start printing again.
  • kakima Feb 12, 2014
    What make and model printer?
  • 5 Answers
SOURCE: hp designjet 110 is not printing. paper is spooling then stops, retracts. orange error light is blinking. can't find users manual
check ur orange cartredge
& check ur orange printer head & clean ur printer head
ur problem is solve
because this problem is only cartredge & prinater head
Posted on May 13, 2009
  • 17 Answers
SOURCE: printing starts..then stops when paper is just appearing.
Replace the exit sensor clipped into the moulding above the fuser. (Very Common)
Posted on Aug 31, 2009
pineworks
  • 4041 Answers
SOURCE: Service error 5100
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 22, 2010
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: Lexmark x75 all in one. Started with
    Hi. That's quite a problem you have there. Have your attention first on the power supply. It does get hot but it's unusual if it gets very hot. Take out the power supply (the black box behind the printer where the power cord is attached). Check the power specifications. Most of the Lexmark power supply has input ranging from 120-240 Volts and an output of 30 Volts. Make sure you're plugging it in the right voltage range. Check if you're using power surge protectors or power strip, disconnect it and plug directly into a properly grounded wall outlet. Power surge protectors can also draw power away from the printer. When everything's well, try printing again. Hope this helps.
    Posted on Mar 18, 2010
    • 492 Answers
    SOURCE: how to cancel old print orders ; after clearing
    click on ur printer icon in ur taskbar and cancel all documents and if ur using win xp restart computer after canceling all docs
    Posted on Jan 12, 2011
    What is Full Inbox at the Brother machine printer and copier
    Hi You've tried printing to many thing at once and clogged up your inbox, Now you need to clear your inbox before you can start printing again..... Just check your user manual and if you don't have one just google-> USER MANUAL FOR BROTHER PRINTERS & COPIERS(plus model number)a web page opens and you'll find a free download on that page, I hope this helps.....CHEERS..
    Apr 24, 2016 | Brother Office Equipment & Supplies
    How do I clear the general message: See your printer documentation for information about clearing the error?
    Give this a try
    ***Manually clear the print queue***
    1) Open the "Services" panel. The easiest way to do this is click "Start" and type "Services.msc" (no quotes) in the search box.
    2) Scroll down the list of services to find and select "Print Spooler". Click "Stop" in the left panel.
    3) Open Windows Explorer ("Computer" in the Start menu). Navigate to the spooler directory (typically "C:\Windows\System32\spool\PRINTERS") .
    4) Delete the files in the directory.
    5) Go back to the Services panel and click "Start".
    Dec 13, 2015 | Epson Stylus Photo 925 InkJet Printer
    Weld not detect
    Hi
    The cartridge weld was not detected.
    1.Clear the fault message.
    2.If message persists, replace the cartridge.
    3.If necessary, replace the weld sensor.
    Feb 15, 2014 | Printronix P7220 Matrix Printer
    PCR-T470 clearing out grand total sales to zero
    Hi. It is a non re-settable total to stop fraudulent activity. You would have to RAM clear the whole machine and start from scratch to clear it. You can stop it from printing if you like. There is a setting to turn of grand total printing. Use the machine features tables on your book to set the grand total to not print if it annoys you. If you need a manual, one of the users has it here:
    http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T470_users_and_programming_manual.html
    Dec 16, 2013 | Casio Parts Cash Register PC Desktop
    I cant get a print job to delete from the queue and its holding up all the other jobs
    To delete print jobs stuck in the print queue on Windows:
    1. Click Start ? click Control Panel ? click Printers and Faxes.
    2. Right-click on the Lexmark print object and select Cancel All Documents.
    3. If that doesn't clear the queue, restart your computer.
    If print job(s) still remain in the queue even after doing the steps above:
    Stop the Print Spooler service from the Services console
    1. Click Start ? click Run ? type cmd ? click OK.
    2. Type net stop spooler at the command prompt ? hit Enter on the keyboard.
    Clear the SPOOL folder
    1. Click Start ? click Run ? type spool ? click OK.
    2. Open PRINTERS folder ? delete all files in the folder.
    Start the Print Spooler service from the Services console
    2. Type net start spooler at the command prompt ? hit Enter on the keyboard.
    Try to print again after clearing the print queue.
    Nov 24, 2010 | Lexmark Z611 InkJet Photo Printer
    Mp250 canon user intervention required problem
    Clear pause printing
    1. From the Windows Desktop, select Start , Settings , and Printers .
    2. Right-click the HP LaserJet printer icon that is being used.
    3. Select the Work Offline or Pause Printing option (if enabled) to remove the check.
    4. Print the document again.
    Establish parallel connection
    1. Turn off the printer or remove the printer from the network.
    2. Connect the printer to the PC using a parallel cable.
    3. Power on the printer.
    4. Print the document again. NOTE: If the User Intervention Required message reappears, disable or remove any HP LaserJet software utilities loaded on the system (for example, Status Window, HP Toolbox, etc.). Prove printer functionality and troubleshoot communications; try printing again.
    Uninstall and reinstall the driver After performing a cold reset on a product installed with USB, a higher DOT4_00x port is created, causing the printer to hang while printing. NOTE: This is required with products installed on a USB port only.
    1. Uninstall the USB printer driver.
    2. Remove the HP folder and AIO folder from the hard drive.
    3. Reinstall the USB printer driver.
    CAUSE: This error can occur if when using a network or printing from a laptop. When the print job goes into a pending status, the printer is either in Work Offline or Pause Printing mode. Hope this helps. Please rate my response.
    Thanks.
    Have a good day.
    Mar 17, 2010 | Office Equipment & Supplies
    How do you clear que on a c6300 photosmart
    Windows XP Operating System
    Restart the Print Spooler device
    1. Open Administrative Tools.
    2. On the Windows taskbar, click Start , and then click Control Panel .
    3. Click Performance and Maintenance . NOTE: This step is not necessary in XP Classic View.
    4. Click Administrative Tools .
    5. Double-click Services .
    6. Click Print Spooler .
    7. Click Stop to stop the Print Spooler.
    8. Click Start to restart the Print Spooler.
    9. Click OK .
    10. Restart the computer.
    11. Try the print job again.
    1. Return to the Printers and Faxes folder that you opened in the previous steps.
    2. Right-click the name of the product, and then click Open .
    3. Click Printer , and then click Cancel All Documents .
    4. Click Yes to confirm the action.
    5. If documents remain in the print queue, restart the computer.
    6. Try printing again.
    Windows Vista Operating System
    1. Return to the Printers folder that you opened earlier in this document.
    If the issue continues, proceed to the next step. Restart the Print Spooler device
    1. On the Windows taskbar, click the Windows icon (c01319360.gif ), click Control Panel , and then click Administrative Tools .
    2. Double-click Services .
    3. On the User Account Control window, click Continue .
    4. Click Print Spooler .
    5. Click Stop to stop the Print Spooler.
    6. Click Start to restart the Print Spooler.
    7. Click OK .
    8. Restart the computer.
    9. Try the print job again.
    Oct 03, 2009 | HP Office Equipment & Supplies
    Xerox 4150 continues to jam on first print - "print engine jam"
    Chances are you have a buildup of toner on the charge corotron. This is a part of the copier that charges the drum to accept toner. If there's buildup of toner inside or on the grid of the corotron then the charge will be erratic or excessive and cause the paper to jam as it passes by the drum.
    Check your user manual on how to properly remove and clean/replace the corotron.
    Aug 21, 2009 | Xerox 4150V_P Printer
    Starts beeping and F31 ERR flashes
    Any F code error indicates a fault has been detected . Press Clear/Off to clear display and stop beeping then reprogram the oven. If the fault reoccurs record the fault number press Clear/Off and contact an authorized service agent. If you have access to the internet you can download a manual for this appliance go to www.frigidaire.com/support/support.asp
    On the customer services page click on product manuals and you will be abe to download the manual and print it off.
    Apr 21, 2009 | Frigidaire FEF352 Electric Kitchen Range
    Need to reset prevented maintenance code on Panasonic 7735 copier
    okay, you need to press these three keys simultaniously
    "user preset, ledger, and the number 3" you will enter the service F mode, then press 7 then the print button, then enter 22 then print then press 000 print, 000 print again and a wrench will lite up which means you just reset the maintenance counter. you then must press user preset and clear/stop key simultaniously to exit.
    Thank You,
    Mikey
    Apr 04, 2008 | Office Equipment & Supplies
    jasbo
    jasbo
