Question about Bissell 9200 Upright Vacuum
Bissel upright vaccum model 6594
Vaccum has no suction.Replaced all filters and belts. Hoses are not clogged anywhere. Motor runs but blows out hot air at the filter above the headlight.
  • ashsin Apr 17, 2008
    i have exactly the same problem. my vacuum cleaner is bissell upright too. i think the solution is right. i will try it and repost with the result.
  • Anonymous Mar 30, 2014
    When trying to use as uprite vaccum it has no suction, only in the hose
    Problem Solver:
  • 7 Answers
Try pushing brromstick or long pieceof conduit thru hose youmight think you have everything out of the hose
Posted on Aug 22, 2008
  • 1,673 Answers
Did you check the inlet hose down by the brush roll, it may be clogged there. Your system says that that must be a clog. Did you drop something like a big marble down thru the hose and have go all the way thru?
Posted on Feb 14, 2008
My Bissell has been new filters, belt and had the hoses cleaned. Still blows dirt out the back onto my feet and has no suction.
The first place to look is to see if you have a clog where the dirt flows into the vacuum down by the brush roll. This is a very common place for clog, it may be back in deep where it is hard to see.
Mar 15, 2014 | Bissell Upright Vacuum - The Pet Hair...
Vaccum problem
No sound at all? or the motor runs but no vaccuum?
did it stop while using it? might have overheated due to dirty filters... strange that the light comes on but no motor at all... that would suggest to me that the motor is shot...
Here is a link the the manual.. there is no reference to any user accessable fuse or breaker...
Mar 07, 2010 | Bissell 6594 PowerForce Bagless Upright...
Bissell 3750-T Bagless Upright Vacuum motor is hot, noisy, and smells like it is burned out, but still working. Can I replace the motor?
There are threee filters inside this unit. Be sure all three are clean. You can't clean the Hepa filter. You can only replace it. You may even try pluging it in and running it (not while vacuuming the carpet) without the filters to see if it is clogged up anywhere. It's not uncommon to **** up an object that doesn't fit though the vaccum hose very well and for that item to cause hair etc to catch on it and plug that hose. Before you know it you have a big plug in that hose. The hose detaches easily. Look through it.
Feb 24, 2010 | Bissell 3750 Lift Off Bagless Upright...
I have a bisell vacuum but no suction The spinner at the bottom is not spinning how do i reset
You have a clog somewhere in the hose. You may have a belt off. You MIGHT have a air driven brush, if that is the case, dont look for the belt ... look for the clog. You may want to use a shop vac to help you remove the clog. Loosen what ever you have to to assure the hoses are CLEAR.
Good luck
Oct 14, 2009 | Bissell 6594 PowerForce Bagless Upright...
No suction on Bissell Powerforce Bagless. Have thoroughly cleaned
Make sure you unplug before cleaning turn vaccum upside down check roller
for hair and strings wrapped around brush if this does not help clean out cylinder gently knocking dust out or use a duster to stick up inside lightly cleaning and check filter
Sep 30, 2009 | Bissell 6594 PowerForce Bagless Upright...
My bissel upright vaccum cleaner belt got damaged and i replaced it with a new one , but it got damaged immd after replacing
In the area where you replace the belt, see if you can remove the beater bar, and check that there is nothing stuck in the area that is causing the damage, like a small screw or similar item.
Sep 11, 2009 | Bissell 6594 PowerForce Bagless Upright...
Vacuum Does Not Have any Suction
it could be clogged somewhere inside the hose. try unclogging it with a thin pole or rod.
Mar 30, 2009 | Bissell 6594 PowerForce Bagless Upright...
Check all filters, hoses for clogs. If sucking and still not picking up you may need a new belt.
Aug 24, 2008 | Bissell 6594 PowerForce Bagless Upright...
When the vaccum is running the motor gets hot & smells & is very noisy.
Sounds like yu may have a clog, either in the inlet by the brush roll, or the hose. If the hose comes loose, see if there is suction there. If no suction then it is clogged. If suction, then the inlet maybe clogged.
Jul 22, 2008 | Dirt Devil Reaction Twin Cyclone Upright...
Bissell 9200 Upright Vacuum Logo
145 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
