Question about KitchenAid KFFS20EYMS French Door Refrigerator 30"""
Defroster fan noise
Very loud noise from the fridge, ice formed behind the freezer drawers. Up plugged till all ice melted, plugged back in and it was fine. Do I need to do more? will the noise come back?
  • 1122 Answers
SOURCE: water inside bottom of freezer after defrost cycle
your freezer drain is either frozen or clogged,remove stuff from bottom of freezer and you should be able to see the drainhole..if frozen use a hair dryer to melt,then to make sure it 's not clogged use a wire hanger to clear it out and you should be ok,let me know-mike
Posted on Oct 31, 2008
freetek
  • 5568 Answers
SOURCE: Kitchen Aid bottom freezer has frost/ice buildup
Do you know for certain that the automatic defrost cycle is running at all?
Depending on the model, it should be entering the defrost mode every 12 or 24 hours. If the defrost timer is not easy to see (because of the drawer construction), you should be able to catch it by checking the walls of the freezer at random to see if they are still 'ice' cold or more temperate.
You may definitely have a leak, no argument there, but the defrost cycle may have been masking it while it was still happening by sending the ice/water down to the pan.
Posted on Jan 18, 2009
peyton32034
  • 410 Answers
SOURCE: Superba fridge 1992 occasonal water under bottom freezer drawer
you have a frozen defrost drain. in order to fix this you will need to remove all shelves and basket out of the freezer. then remove rear evap cover. one youve gained access to this area you will see at the bottom of the coil an aluminum pan that most likely wil be iced over. clear away this ice then try to flush out the drain line with warm water. sometimes its neccessary to force water into drain line with a large syringe or turkey baster. this should fix ya up.
good luck and thx for using fixya Peyton
Posted on Jan 28, 2009
  • 172 Answers
SOURCE: Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Posted on Feb 17, 2009
  • 9 Answers
SOURCE: Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
Posted on May 01, 2009
Refrigerator not cooling
The self defrosting mechanism is fubar. Check out the defrost timer and defrost element for proper operation. Chances are that the element is open.
Jun 25, 2016 | Samsung RF266ABRS Bottom Freezer...
The cooling coil in the back interior of the fridge forms frost and then melts to form a lake in the bottom of the fridge, and then it freezes. The produce drawers freeze shut from the buildup every weeks...
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 29, 2011 | Samsung RF26VAB (25.5 cu. ft.)...
I have a sub zero 650. Anything I put in my fruit/veggie drawer freezes and there is ice behind the drawer. It seems to be freezing around the tube behind the drawer and spreads up and out.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer(fridge) will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Mar 30, 2011 | Sub-Zero 650 / O Bottom Freezer...
Ice is forming on the back wall of my freezer
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
Jul 06, 2010 | Haier Convertible Bottom Drawer French...
Ice forms around fan and makes a loud humming noise
It's probablly caused by air leakage through the ice room fan electrical connection inside the freezer. Behind the back wall inside the freezer, the icd fan is the fan that blows air up to the in-door icemaker. The plug on that, into a molded plug on the back of the feezer compartment, is a red plastic part with three wires in it. Try filling in around the wires and the red plastic with a bit of silicone. (if you replace the ice room fan, the new plug comes with a rubber filler which seals this spot). (PS. Next time, avoid Sears)
Mar 31, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
Ice is forming in my Freezer and the roof is forming drops
Unplug it and let it defrost. wile it is defrosting pull the botum front cover off and vacum out all of the acumulated lint off the tub on the bottum. after about 2 -3 hours plug it back in and listen for the fan running on the inside if you feel air coming out of the vents then you should be OK. If no fan replace it.
Sep 11, 2009 | Kelvinator 24 in. MDB421RF Built-in...
Model 550, the iside is getting a layer of ice
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Aug 22, 2009 | Refrigerators
Ice is forming around fan in back of freezer compartment
The defrost system is not doing it's job. I bet if you took the panel off below the fan you will see more ice on the cooling coils. There should be a light coat of frost on the coils but not a heavy ice build up. There is a heating element at the bottom area of these coils which should be defrosting all this ice.
1. A defrost timer turns this heating element on.
2. The heating element melts the ice.
3. A thermo disc attached to the coils will turn the heater off.
One or more of these are not doing it's job.
Dec 16, 2008 | Frigidaire Refrigerators
Ice forming on freezer
The drain is plugged. This fridge will defrost every 8 hrs or so. When it does , it will melt the frost that has built up on the evaporator. This melted frost will run down a drain under the evaporator to a drain in the bottom directly under the evaporator. When the drain gets plugged the water cannot drain out of the freezer compartment. After several defrost cycles the melted frost will overflow onto the freezer floor. When the fridge starts back up it will freez this water is the bottom of the fridge. sometimes this water that is now ice will melt on the next defrost cycle and actually run out into the floor. You will have to unplug the fridge or turn it off, then remove the cover to the evaporator. Get a hair dryer and melt the ice aruond the evaporator and drain. Once the ice is removed, check the drain and try to clear it. Once clear, replace everything but the shelves. Plug the fridge back in or turn it back on. Observe and listen for the evaporator fan. It should be running now. When working on the ice on the evaporator always be carefull. The defrost heater can be damaged if up push or pull on it too much.
Nov 15, 2008 | Samsung RF265AA Bottom Freezer French Door...
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
KitchenAid KFFS20EYMS French Door Refrigerator 30""" Logo
67 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
