Question about Music
Peavey xr696f PEAVEY 696F POWER AMP NOT WORKING WELL BUT MIXER SECTION SHOWING SIGNAL INPUT
  • 5603 Answers
SOURCE: How to remove amp from cabinet? reverb doesn't work.
SOMETIMES the handle screws must be removed as well.
I have taken a lot of these out and the key is to figure out which direction it comes out... MOST are out the back and sometimes a board across the back has to be taken off with four screws to clear a transformer.
FIGHTING getting the thing out when it catches on the Tolex covering is the USUAL problem. Takes patience and sometimes a blade to hold the Tolex back.
USUALLY the speaker baffle stays in place.
Posted on Nov 12, 2009
  • 2468 Answers
SOURCE: I own a Peavey XR696F
check any and all filter,cross-over,and de-coupling capacitors in every circuit especially on the left channel side,but check all capacitors anyway on both channels,as one channel can affect both left and right channels, also a capacitor can heal itself over time and do the same thing again later,"Cold-Solder" joints can do this also, on a printed-circuit board, HINT:heat and cold can cause problems so,try heating, joints,caps,etc. or buy a can of freeze mist(to cool components) at an electronic parts store and gently heat or cool each suspect component waiting for the outcome,or wait till the condition starts and then try the cooling,because the component has already been thermally warmed up by the circuitry power
Posted on Jan 31, 2011
  • 17 Answers
SOURCE: i have the peavey xr
That's easily done. Simply connect the left(or right) output of your mixer to one of the channels on the peavey. Use any line input. Since the peavey is a mono system, there's no need sending a stereo mix to it.
Posted on Mar 09, 2011
bobhifi
  • 635 Answers
SOURCE: Useing a Peavey XR 800F
First of all confirm if the speaker impedance is not lower then the recommended Ohms at the back of the Mixer speaker socket.You can use an 8 Ohms speaker on a 4 Ohms amplifier but not vise versa .
Next see if the fan on the mixer works. If not the Amp is getting very hot and this will lead to unwanted distortion. You can confirm if its a heat related issue by playing the mixer at low volumes for more than an hour and see if it distorts.
Posted on Apr 26, 2011
  • 5603 Answers
SOURCE: How do i hook a
You CAN drive the power amps from the main amp inout jacks BUT the rest of the inout of the 8600 would be dead then. You can connect the L and R from the FX24 to either the media RCA jacks or into the channel9/10 jacks. FOr the latter, use TRS cables. Leave the two selection buttons in the up position.
Posted on Sep 22, 2011
I want to use theMackie as a sub mixer into a powered "all in one" Peavy mixer, where do I come out of the Mackie into one of my powered mixer line inputs?
Take the main outputs into a stereo input (or a pair of mono inputs) on the Peavey - without knowing which Peavey I cannot tell you further info re set-up but as you'll be sending line level signal you'll need to back off the gain on the channels you input to on the Peavey
Nov 17, 2016 | Mackie Music
Hello, I am new to forums, this is my first time. I have a Peavey 696f power mixer, last night the left speaker channel stopped working, what do you think is causing this problem?
the pa1 or the pa2 input jack on the front of the unit is dirty, or you have a cracked solder somewhere, as these units are gettting old.
Jun 18, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Schaller pickup wont work
This is a high output piezo pickup but won't give line level signals expected by some inputs so I would guess you may be going into a line input. If so try a mic input (XLR) instead and see if that works.
Mar 30, 2014 | Peavey XR 8600D Class D Powered Mixer
I want to know how to connect a powered subwoofer to the peavey 10 mixer
Connection is hooking up from mixer's main outputs (L,R) to
Subwoofer amp inputs.
Oct 10, 2013 | Peavey Electronics Peavey PV10 Mixer
I am not getting no output from peavey 16fx mixer. if i trun it off on & on i get signal for 2 sec
Theres a little switch next to where it says media in on your front panel just above the group sliders.This little button needs to be pressed down otherwise your cd won't come thru.
Feb 13, 2013 | Peavey 16FX 16 Channel Mixer
Using Behringer PMP3000 to power monitors??
Using the mon out and the proper balanced cable follow the instrcutions found in the manual section 61.
Here is a link to the manual.
http://www.behringer.com/EN/downloads/pdf/PMP1000_P0566_M_EN.pdf
Oct 04, 2008 | Behringer Pmp3000 16 Channel Audio Mixer
Music Logo
29 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
