Dth6100e safe message safe on display .. all locked. only eject botton is ok
"Card Locked" message comes up periodically and
Switch of the camera and eject the memory card. carefully take a look @ d side of the memory, u'll find a botton with an indication of Lock and Unlock. Move the botton to the Unlock indication.return the memory card back into the camera carefully and dats all.
Oct 10, 2011 | Polaroid i633 Digital Camera
The door is jammed so I cant get the disc out. Am I better buying a new camcorder as it will cost to repair.
I had this problem myself Push eject botton and open door by hand. Should be done together as the eject botton moves the door lock for it to open.
Apr 28, 2011 | Cameras
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
Hi, my thomson DTH6100E dvd player does not open anymore to put in a dvd. it says "safe" ore "disc" on the screen all the time...
it happens the same on mine, I think it's a special mode used on shop to avoid people using it. I don't know how to remove it but it works using the remote controller.
bye
Alberto
Jan 16, 2010 | Thomson Televison & Video
I want to eject Have Cruzer Titanium 2.0 USB memory plugged into computer. No programs or files from it are currently in use. After clicking on Safely Remove hardware, the message Problem Ejecting USB Mass...
Make sure you have all programs and folders closed. Then try stopping usb mass storage, there should be more then one option so try removing the drive itself on the list. If that doesn't work. I myself would probably just restart the computer. Then try again.
Thanks,
Lee
Sep 08, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cant eject, display says safe, cant even get menu
I can help with your locked dvd player.
To get the word SAFE to disappear, follow these steps.
I hope that helps.
Apr 29, 2009 | Califone International DVDVCR200 DVD...
I have a xv n330 dvd player and it says lock when I try to take out the dvd in the player and it says lock.
When you press the eject botton while pressing down the stop botton on the unit in
standby mode, the tray lock function is activated. The disc tray
cannot be opened or closed in this status. To release this
status, press the eject botton while pressing down the stop botton on the unit in standby
mode.
Mar 01, 2009 | JVC XV-N330
Power botton not responding
If it's not ejecting or responding to any of the buttons on the unit, or the remote, but is able to play a DVD, the display microprocessor(computer) within your Harman is damaged. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 22, 2008 | Harman Multimedia HS 300 System
Eject lock
try holding down the stop botton down for about 10-15 secs or less it should turn off
Jun 26, 2008 | LG LFD790 System
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
