Question about LG Microwave Ovens
LG SOLARDOM MP9488S SOLARDOM DOOR HANDLE
Replace door on lg solardom microwave
You need to be carefull. You need a tester to use to check aroud the door after installing door. You should have a qualified tech. check it.
Jul 09, 2016 | LG Microwave Ovens
LG Solardom MP-9483SLA bought 2 yrs ago,
Idont understand the problem pls write the main problem
Sep 15, 2014 | Microwave Ovens
I have an LG solardom microwave and when I want to heat a small amount of liquid, it sparks and the base(not the turntable) of the microwave gets hot.
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
It may also be in the area of the turntable support, coupler, or motor.
Nov 24, 2013 | LG Microwave Ovens
Lg solardom oven innerdoor replacement
go to www.repairclinic.com or www.appliancepartspros.com and buy it
GOD BLESS YOU
Jul 16, 2012 | Microwave Ovens
LG LMVM2055ST Microwave. went completely dead, completely
I replaced outer door with key panel on my LG MICRO MODEL LMVM2055ST which solved my problem but when I went to put the handle back on it did not fit. The tophole in new panel for the handle is round and the old one is rectangle. LG says I have right part can not help me.A new handle comes rectangle shape. What now?
Mar 15, 2010 | LG LMVM1935 Convection/Microwave Oven
How do I replace a LG LMV1630ST microwave oven door handle?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Nov 23, 2009 | LG LMV1630ST Microwave Oven
How to take the door handle off?
the handle screws into position. one screw at the top and one at the bottom. you may have to take the door all apart to find those screws.
it may be easier for you to tape off the parts you do not want to paint and just paint the handle.
Jun 26, 2009 | LG LMV1630ST Microwave Oven
LG LMV1650ST handle falling off and needs to be replaced
The lower door handle bracket broke and I'm trying to find out how to replace it. I already have the new bracket.
Jun 23, 2009 | LG LMV1650ST Microwave Oven
I would like to know if it is possible to change a light bulb in the LG solardom Microwave without calling an electrician?
If your owner's manual doesn't cover lamp replacement, you will have to take the oven apart to do it.
If you don't have your manual, you should be able to download it from here.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's here.
You can find helpful exploded view diagrams and for many brands by entering your full model number here: http://tinyurl.com/gv383
Otherwise, please reply back with your model number so we can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 24, 2008 | LG Microwave Ovens
Microwave Ovens Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
