<p>In general, the audio devices use audio cables such as RCA
stereo headphones, or telephone cables, connection to other devices. In case
you need a USB device to a stereo phone plug, you should use a single adapter
cable to connect the USB cable will convert to a stereo phone. <br />
<p><br />
<p>1. Connect the USB end of the headphone adapter to the USB
port of your audio device. <br />
<p><br />
<p>2. Connect one end of the headset to your male cable to the
headphone port of the headset USB adapter. <br />
<p><br />
<p>3. Connect the other end of your headphone male to male
cable to the headphone port of your stereo plug. Now you can connect to any
port to connect to stereo. <br />
How Wireless Headphones Work and How to Connect Them
Wireless headphones are headphones that connect to a device, such as a smartphone, stereo speaker, television, gaming console, computer, or other electronic devices without using a wire or cable. Wireless headphones work by transmitting audio signals through either radio or IR (infrared) signals, depending on the device.
From call centers to fitness centers, wireless headphones are used by millions of people every day for work and play. For example, wireless headphones are popular with gamers, since it frees you to move around without having to worry about a cord. People doing a workout at the gym or in front of their TV in the living room love the freedom of wireless headphones. They are also perfect for people who want to watch late-night television without disturbing others.
Wireless headphones work by connecting, or pairing, with the device you want to use, through a radio or infrared signal. Many devices use Bluetooth technology to make connecting easier for the user. Devices with Bluetooth technology can connect and exchange data over very short distances using radio transmissions.
A product with Bluetooth technology has a tiny computer chip inside that contains the Bluetooth radio, and software that makes connectivity between devices possible. So when Bluetooth-enabled products, such as a cell phone and headphones, are in close proximity to each other, they connect, or pair. This enables you to talk on the phone or listen to music without wires.
Connecting a wireless headphone differs depending on the device you are using, but it's easy once you know how. Here is a list of the most popular devices that people use with wireless headphones and how to connect them.
Connect Wireless Headphones to a TV
First, make sure that your base is plugged in and the headphone batteries are fully charged. Ensure that the headphones and television are in close proximity to one another. Turn the headset on. Go into setting on your TV and turn on Bluetooth. Find the headphones under Bluetooth devices in your TV and you should be able to hear the television.
Connect Wireless Headphones to an xBox 360
The xBox 360 supports two different types of wireless headphones, ones that have Bluetooth capability and ones that do not. The first method explains wireless headphones with Bluetooth capability.
Xbox 360: Headphones with Bluetooth
Plug your wireless headset into the console to install the latest headphone drivers. You will need to be connected to xBox Live in order to do this step.
Make sure that your headset is charged, which can be done by simply plugging it into the unit. If you charge your headset through the console, it will connect automatically most of the time. If they don't connect automatically, turn on your console first and switch the headset so that it is in xBox mode.
Press the power button for two seconds until it flashes green. You should then hear a start-up sound, and when you hear that, press the connect button for two seconds.
After you release that button, press and release the connect button on the console within 20 seconds or the connection will not be made. The green lights will flash three times to let you know the connection was a success.
XBOX 360: Headphones without Bluetooth Capability
Make sure that your headphones are charged, which can be done by plugging them into the USB port of the console.
Turn on the console and the headphones. After they are powered up, push and release the connect button on your console.
Within 20 seconds, press the connect button on your wireless headphones for two seconds. You should now hear sound from your headphones.
Connect Wireless Headphones to the iPhone
Setting up your wireless headphones with Bluetooth technology is easy on the iPhone. Here's how:
Find the "Settings" icon on your iPhone, which is normally on the home screen.
Open and click on the "General" button.
Then, hit the "Bluetooth" button and slide it over to turn the function on.
Your iPhone should find the device once this is enabled and should show the device name on screen. When it does that, you will need to hit the "Pair" button in order for the devices to sync. You may need to enter a four digit password, which is provided with your wireless device.
Once that is entered, hit "Connect" on your iPhone to complete the setup. Your headphones should now be working properly.
Connect Wireless Headphones to the PS3
You will first need to register the headphones to the PS3 through the Bluetooth settings. Here's how:
Go to the XMB home menu and select the "Settings" icon.
From there, select the "Accessory Settings" icon, and from that menu, find the option that says "Manage Bluetooth Devices."
If there is no current Bluetooth device registered on the PS3, there will be an option that says "The Bluetooth device has not been registered. Do you want to register?" You will need to highlight the "Yes" option and click the "X" button on your controller. If the pairing was successful, the device will show up on the screen.
Next, you will see a screen that says "To register (pair), you will need to prepare the Bluetooth device. For information on preparing the device, refer to the instructions supplied with the Bluetooth device."
Click on "Start Scanning" on the screen with your "X" button so that the PS3 can start to scan. Also, you need to make sure your headphones are in pair mode so that the PS3 will recognize the device. If the pairing was successful, it will show you on the screen and you just need to hit the "X" button to continue.
You will then be asked to enter the pass code or security key that was provided with your wireless device. Use the keyboard that is provided on the screen to enter the pass code. Once everything is entered properly, a message tells you that the device has been registered.
Next, go back to the "Accessory Settings" menu to access the "Audio Device Settings" menu. Select the "Input Device" option by clicking "X" on the controller. When the new menu opens, look for the proper microphone input that corresponds with your device. Once you find the right one, click the "X" button.
Select the "Output Device" option to select the headphones. Once you search through the options that the system recognizes, click "X" on your wireless headphones to select them. You should now be set up and ready to use the wireless headphones and microphone.
Connect Wireless Headphones to an iPod
Make sure that your wireless headphones have Bluetooth capability.
Access the "Settings" icon on the home screen of your iPod. Select the "General" option once you are in that screen.
You will then see an option that says "Bluetooth", which you can slide over to enable Bluetooth on the iPod.
Be sure that your wireless device is in discovery mode so that the iPod can recognize it.
Once you enable the Bluetooth on the iPod, it will list any devices that is recognizes. Simply click on your wireless device when the iPod shows it and click the "Connect" button. Your headphones should now be paired and working properly.
Wireless head phones works on principle of wireless technology.
The phone has a reciver and tv or Audio system has a transmitter ,.
WiFi/blue tooth are examples.
1 Turn on your phone’s or device’s Bluetooth® feature. 2 With the headphones powered off, press and hold the Power/Pairing button until the LED indicator flashes blue and red. 3 Use the phone or device menu to search for the Bluetooth headphones and select 9xxBackBeat. See your phone’s or device’s user guide for more information. 4 If prompted, enter 0000 for the PIN code/passkey. Some phones also require that you accept the connection. Pairing is successful when the LED indicator flashes blue.
nstall the USB dongle as the manufacturer
instructs you and make sure it’s switched on. Next, fire up your
headphones (don’t forget to charge them first). Now remember that most
headphones have two different start-up modes. The first time you switch
them on you’ll need to pair them with the USB computer. This is done by
holding the power button on for at least 4 or 5 seconds (you should
read the instructions manual to find out exactly how to do it).
After
this is done, you’ll need to scan for Bluetooth devices from your PC.
Just start up the software and use it to see what Bluetooth devices you
have around. The scan should take a few seconds and after finishing,
the software should display a list containing your headphones. Remember
that other devices such as mobile phones may be detected if their
Bluetooth modules are activated during the scanning process.
Select the headphones and go on to the next step. The software should
provide you with two choices. You should be able to pair the device as
Stereo Headphones or Headset. Choose headset and go to the next step. A
pin will be required in order to pair the device. Most default pins are
0000, but you should check the manual in order to be sure.
The
headphones will start ringing and you will be required to press the
Call/Answer/Power button (do it). Also, a name should be provided for
this connection. You can name it anything you like. My software also
allows me to place an icon on the desktop and just double click it when
I need to connect my headphones with my laptop.
These should be
the basic steps when pairing a device for the first time. Now, if I
want to connect my headphones with my laptop I can just activate them
(in non-pairing mode) and double click my desktop icon to establish a
connection.
You can also repeat the steps above in order to pair
your device as stereo headphones. After switching on the device, just
double click the connection you desire and everything will work
flawlessly.
First go to control panel, sounds and audio devices
go to the audio tab and make sure that your usb device is selected for audio playback
then, unconnect the headphones and restart your computer
after restarting, connect the headphones and Speakers , it should work
Hi, If you have lost the pairing on your phone with the headset follow these simple steps below: • Setting the headset into pairing mode 1) Ensure the headset is fully charged 2) The headset must be switch off 3) Press and hold the on button for +- 8 seconds until the light flashes red-blue 4) The headset is now in pairing mode • Searching for the headset on the phone 1) Go to “settings” or “connections” 2) Select Bluetooth, then options 3) Select Devices and click add 4) The phone should search for any available Bluetooth devices and display what was found 5) Select the Motorola device and click add 6) You will be required to enter in a pass code which is standard ‘0000’. 7) If successful then the headset will start flashing BLUE every few seconds. 8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device. • The headset is now paired with the phone
