Question about Canon DR9050C
Auto detect page length create extra space and cut off
When turn on auto detect page length scaner creates extra space width on right side. If turn off auto dectect it will cut off the bottom of image by 0.25 in.
5 Suggested Answers
SOURCE: display the date on the picture
You can use Timetophoto program.
Posted on Nov 27, 2007
Cogz
  • 1326 Answers
SOURCE: 7x9 copies getting cut off on right side of page.
Have you tried to make a copy by using the by-pass tray or manual feed tray. If the copies come out OK then the problem may be that the paper tray guides are not alined crrectly for the paper you are tring to use.
Posted on Apr 02, 2009
MalKontent68
  • 748 Answers
SOURCE: Canon i560 prints a black smudge pattern on left side of page
There must be some small piece of paper or paper dust buildup near the left side of the paper feed/press mechanism under the printheads.
Open the cover and inspect the far left area along the line of head travel - there often is a metal plate with small wheels that stabilize the paper, and under that plate look for some foreign objects. Try gently removing them with a toothpick - it is soft enough not to cause any damage, and also will soak in any ink residue that might be left there.
Posted on Dec 29, 2009
jerryg50
  • 1689 Answers
SOURCE: When I got to download images to my computer a
This sounds like your hard drive is too full. You have to clean up old or unused files to make hard drive space. Or, change the drive in your computer for a bigger one, or add a second drive to the computer to allow for more storage space.
Jerry G.
Posted on Mar 19, 2010
Easiest way to make a buttonhole...manual does not tell much info
Easiest way is to create a bar tack at one end of the buttonhole (widest stitch width and stitch length set to 0). Stitch maybe 4 or 5 stitches.
Then move needle all the way to the left, set stitch length to very short (maybe somewhere between 0 & 1), width to slightly less than half, stitch forward to the end of the buttonhole.
Then make another bar tack (as above). Move needle all the way to the right, set to less than half width, short stitch length, and stitch in REVERSE to first bar tack. To tie off, set width to 0 and length to 0 and stitch 2-3 times in place. Raise presser foot, pull gently on fabric and clip threads.
Mar 12, 2015 | Sewing Machines
My bt extras
check is your extras now under the manage your extras in the my package section of the page
Mar 23, 2017 | Computers & Internet
Water damage to ceiling
Cut off the loose make flat tape and drywall mud
Mar 06, 2014 | Drywall
I can not draw a table in microsoft word
hi ermelitacapa,
To create a table in Microsoft Word please do the following:
1. Go to the Table menu and select 'Insert Table'. The Insert Table window will open.
2. Select the number of rows and columns you want in your table.
3. Select the column width (up to 22 inches) or choose 'Auto' to have the column with adjust automatically, making the table extend across the width of the page.
4. Select the AutoFormat button to select one of Word's pre-formatted table styles. The Table AutoFormat window opens.
5. Click one of the styles in the Formats box in the upper left side of the window.
6. Preview each format, after selecting it, in the Preview box in the upper right side of window.
7. To customize a pre-selected format, select or de-select the borders, shading, font, color, heading rows, first column, last row and last column boxes.
8. Select AutoFit, and Word will automatically fit the table to your page.
(To manually change the width of a table or column after you have created it, use the mouse to place the pointer over the vertical line you want to move. When the pointer turns into a double-headed arrow, drag the line to the position you want it in the table.)'
I hope this helps!
** If you find this information helpful please leave feedback to help us help others **
Feb 24, 2011 | Microsoft Windows 7 Home Premium 64BIT...
How can i create a partition in my hard disk without deleting my files
Creating a new partition in your hard drive may be achieve in three ways. If you're installing a fresh Operating System into your PC, you can setup extra drives such as drive D: or drive E: for backup purposes. But if there's already a ready OS, you can right click the My Computer icon in your Desktop and select Manage then hit Disk Management. If you have seen Unallocated Space, you can right click it then hit Create New Partition, and if none it means that your hard drive has no more space to create another extra drive. If you find the two preceding ways quite complicated, you can also use software such as Partition Magic.
May 19, 2010 | Microsoft Windows Vista Ultimate Edition
No laser light, no open or close function, power
Absolutely! The flex cable needs to be smooth and flat. It is made of plastic and tin or copper. Sharp bends and any attempt to straighten the cable breaks it easy. If you find a similar cable with too many traces, you can cut the extra traces off the cable and if the EXACT trace width and spacing and length is long enough, it will work. Electronic repair shops usually have a zillion cables if you don't mind sorting through them or buying a bunch at a time.
Mar 20, 2010 | Televison & Video
Parts of page being scanned are cut off
Whcih version of CapturePerfect you are using?
I use ver 2.0. In the settings page select scanners maximum. In the 'advanced' select auto detection. Then whatever size of the paper guides you choose, that will will be the width and ofcourse the length is automatic. There is a sensor under the paper guide, and it detects the paper width. Any rotation chosen will be after scanning the required size.
S. Mohan, Chennai, India
Jul 20, 2009 | Canon DR-5010C Scanner
Hp laserjet 1320 printing blank pages
check printer door, there is a small plastic piece wich pushed down (to open) lasser scaner cover. if this piece is broken you can get blank page
Jun 30, 2009 | HP LaserJet 1320 Printer
Blade length problem
Hedge trimmers cut using either a single-action, where only the top blade oscillates, cutting against the stationary lower blade, or a double-action where a pair of double-sided toothed blades that slide back and forth at a high speed so you can sweep across hedges in both directions. The latter are more efficient. Blade length Consider the size of the hedge you will be cutting to get the right length blade. The longer the blade length, the more area it can cover and the quicker it will get the job done. However longer blades also require more power and larger heavier motors so weigh up blade size versus ease of use. Blade lengths range from 14 to 30 inches with long blades of 22 to 30 inches providing extended reach for taller or wider hedges. Blade width The blade width indicates the space between teeth and the maximum thickness the trimmer can cut through, eg. 20mm blade width will be able to cut through a maximum 20mm branch.
Aug 27, 2008 | Bond Manufacturing 6-pieceUltimate Pruning...
Canon DR9050C Logo
old marine
old marine
