Question about Panasonic KX-T7633 Corded Phone
How can I simulate an outside call?
I have a TES824 PBX, and a TVM50 Voicemail / custom menu system. One of the options is to call a whole group. Currently this is done using an unused extension (number 42) connected to an unused CO line (8). If that option is selected, the TVM50 dials 42, which then rings back in at CO8. It sort-of works. The PT phones don't always ring - I'm guessing this is a lack of voltage issue due to the loop-round, and, as it's done twice, to deal with multiple lines coming in at the same time, we have two extension ports, and two CO lines used up just to do this flip round. Is there anyway the same could be achieved without the loopround?
SOURCE: Panasonic Kx-T123230 extension to ring
hope this help...
with a handset on hook...press PROGRAM and press 3 (number 3 button) this should give you a choice of which extention you want the phone to ring.. ie 1or 2 or three... Then finally press STORE
Posted on Feb 17, 2008
  • 1894 Answers
SOURCE: no dial tone and "line in use " message
the wire that is used to connect the line to the telephone is not proper...
Posted on Mar 02, 2008
hemacom31
  • 11 Answers
SOURCE: When a call comes in from on outside line and the
you can press the message botton
Posted on Oct 03, 2009
cnavarro
  • 2460 Answers
SOURCE: Two phonelines no longer accessible. Using
This is most likely a service provider issue. If these are analog lines, take a regular phone, not a Panasonic system phone, and plug it into wherever the CO1 CO2 CO3 lines go into the cabinet. If they work there, you have a system fault (not likely). If they don't you have a line problem.
Make sure that you plug the phone into the lines coming in, not into the cabinet :-)
Carl
Posted on Oct 09, 2009
greg411
  • 45 Answers
SOURCE: phone won't transfer to next free line when a second call comes
If you are not getting a dial tone then something is holding the line off hook. Disconnect any other device you have on your lines and check to see if you get your dial tone back. If you still have no dial tone unplug each phone and check again. You may have to disconnect everything for a minute or two so the phone company will reset its equipment. Plug in your phones one at a time and check your dial tone every time you add something new.
If you add something and you loose your dial tone immediately you may have a crossed connection in the wall socket, any splitters or in the phone plug. Check to make sure all of the wires in those sockets are straight before you plug in your phone wire.
If you add your CC machine and everything is good but it fails after you run a transaction you will have to contact the supplier of your CC machine. It is not hanging up the line.
Posted on Apr 17, 2010
The phone is diverting to voicemail after 1 ring and I haven't changed anything. Does anyone know how to fix this as the manual does not appear to offer a solution.
You have most likely inadvertently changed it to voicemail only. That happens frequently with my phone (hate it!). Had to contact the vendor to find out how to correct it by inputting a special code.
Mar 07, 2016 | Panasonic KX-T7630 Corded Phone
How to change viocemail for the 2110
IP Phones do not provide voicemail, that is a function of the PBX it is connected to, either a premise IP PBX or a cloud-based (hosted) PBX. If you are using an Asterisk-based PBX system, the usual way to access the voicemail system is to dial 98 from the phone, however you will need to know the voicemail password.
Jul 07, 2014 | Grandstream GXP2110
Reset tes824 password
you need to clear all data on your pbx.
1-turn off pbx
2-set the internal switch to clear
3-turn on
4-count to 3 and press the set button once
5-count to 10 and return the switch to normal
Oct 31, 2013 | Panasonic KX-T7730 Corded Phone
I have a panasonic TVM50 and the phones are KX-T7633. We wanted to change the message and dialed Intercom 165. Now all we see is "reorder tone" How can we get rid of this and change our personal message?...
The system would have set that 165 are the voicemail ports so the voicemail must be plugged into these ports .usually the last extension on the system Once connected dial 164 then 3. 1. 1 and follow the peompts
Sep 06, 2013 | Panasonic KXDT333 Phone
How can i pick up the call from my office phone when reception phone rings
Hello,Looks like you'll need to re-program your PBX unit. I would suggest looking up: 1.5.3.3 Outside (CO) Line Access 2.2.4 Operator/Manager Featuresin the Programming manual found here:
http://www.tongxun.com.cn/data/download/Feature_Guide.pdf
Hope this helps
Nov 27, 2012 | Panasonic KX-T7730 Corded Phone
Help me guys!!When using call fwd to outside from a custom service on a TVM50 the call will not transfer. I am using many manual in TVM50 but settings are not working. I have tried many changes to timers,...
You directed this question at me, but unfortunately I'm unable to provide you with a "real" solution at this time. FixYa has informed me that by providing you with this "solution" your question will then be made visible to other experts; hopefully one of them will be able to provide you with a real solution.
Thank you for using FixYa.
Nov 07, 2011 | Lands Phones
I need cinfigaration pbx tes824 via kx-7730
The programming of a Panasonic system is located in the Installation Manual. Our US systems differ, so the link to my public website probably won't help you. Check with your Panasonic dealer and look around for a CD. In our systems, the manuals are delevered with the system on a CD.
Carl
Sep 21, 2010 | Panasonic KX-T7730 Corded Phone
Kx-tg5632 how do i forward call to my cell
you need to call your carrier and get a forwarding code and then a cancell code.
good luck
s
Jun 11, 2009 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7633 Corded Phone Logo
26 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
