Question about JVC AV-27730 27" TV
5417R vertical IC number - JVC AV-27730 27" TV
Ihave atv lg ultraslim 21 and it uses vertical ic no la78141 what abstract can it use instead of the original one?
You can try the other LA vertical IC that is same in scale (number of pins) and in size.
Jul 31, 2014 | Televison & Video
My sanyo ds20425 has a white horzontal across the screen
On most , it is caused by Vertical IC and sorrounding components
Guide on How to find Vertical IC
Look and check for cold solder joints for IC501
part number
LA7840
Resolder the pins of the IC , and replace if necessary
Let us know if you need further assistance.
Sep 21, 2012 | Sanyo DS24205 24" TV
How can I find the part number to order a Vertical Output IC for a Sansui Model tvs2746a
The vertical output IC will have a number printed on it. You mus send this number to get a new one. Normally, all vertical ICs are available from local electronic spare part selling shops. It is not a difficult to get component. Won't cost more too.
May 21, 2012 | Sansui Televison & Video
Thin horizontal line across screen
Hello
You haven't specifed nothing about the model number or brand name of your flat panel teleivison. i assumes that it to be a picture tube based one and posts this solution before you.
A thin horizontal line across the screen with sound output is OK, is the sympton of total failure of vertical sweep. This may be due to failure of vertical output IC or loose solder terminals of that IC. The vertical output IC will heat up while working, and repeated heating and cooling may make its solder terminals to get loose. Just open your TV, pull out the board that contains vertcial output section, turn it upside down, resolder all the solder terminals of that IC by applying a little more solder, without making any solder bridge in between terminals. Check the voltage to the vertical output IC also. If this resoldering method does not help you, replace the vertical IC itself with same type and number will solve your TVs problem. OK.
May 07, 2011 | Televison & Video
DeawooTV Model DTC 2975 I want to know about vertical ic number.b,cos i can't fine out the number that ic is burn.
Hello
There are two mumbers used in Dawoo tv as vertical IC.
If used is a [9] pin one number is [TDA 8357J].
If used is a [10] pin one, number is [ LA 7848]
OK.
Jan 05, 2011 | Daewoo Televison & Video
Loss of vertical sweep
Hello
Your TVs vertical output Ic may be damaged. You just open your TV and locate the vertical section inside, usually panasonic uses Ic numbered [LA7837] which will be marked as part number IC451 on the circuit board. It is a 13 pin Ic, sometimes the number may be different in your TV, as Panasonic uses four types of LA series Ics in their sets. I think that you have some knowledge in the service field, so the complaint states only "loss of vertical sweep", and so I'm not going too deep into description. OK.
Nov 06, 2010 | Panasonic TC-21PM10RQ 21" TV
Vs-45607 Vertical Hold Problem
Good Day; Just replace the caps first, 99.9% fix if not replace 9v regulator. Good Luck, big IRISH.
Nov 23, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Sony tv no picture only horizontal line
The probable defective part is the vertical IC. If changing that does not resolve the problem, check the capacitors in the same circuit. Also, check for the proper voltages at the vertical IC. If the IC is not being fed its power, it won't work either. I don't have a listing for your specific model. If you can post the vertical IC part number (LA7837 for example), I can list the voltages per pin.
Dan
Apr 09, 2008 | Televison & Video
Tv cuts off 10 seconds after switch on and destroying vertical output ic
If the main IC is not putting out a vertical drive signal then the vertical output will not do anything and therefore will not be damaged. What exactly do you mean by the set "literally eats deflection IC's"? What is the number on the vertical output IC? I will bet that your pump-up cap or pump-up diode is defective.
Jul 03, 2007 | Sharp 27K-S100 TV
Part help
the vertical o/p generic number stamped on the fron of the ic is "TDA8172" the sony part number is "8-759-980-58". good luck
Mar 13, 2007 | Sony KV-27S65 27" TV
Televison & Video Logo
12 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
