Question about Panasonic TCP50VT25 50 in HDTVReady Plasma TV
10 blinks on power light
Screen went blank and power light just blinks 10 times over and over
  • 35 Answers
You need to replace the blown capacitors on your PSB-power supply board. A soldering kit w/flux from harbor freight or radio shack and and about a dozen new Thru-hole caps about 2V higher than the ones your are pulling out.. Or if that isn't to your liking you can just buy a refurbed board on ebay shopjmmy or partsstore. You will need to remove the back panel and pull out the PSB disconnect a few wire harness and some ribbon cables and a few screws the board will pop right out. The board with be printed and say Power Supply with the REV number (part number) printed on it. That's the one you need to look for. If you want to replace the caps yourself you'll visibly see the blown caps they should be completely flat (X) top view no puffs or bulges. It's pretty simple to remove them and solder some new ones in.
Posted on May 13, 2014
4 Suggested Answers
SOURCE: Power light blinks 10 times
You have the same problem i have. My Tv just did the same thing 3 nights ago. I unplugged the set, and let it sit ofr about 6 hours, and then tried it again. It turned on and played, but repeated the problem after about 20 or 30 minutes. So far all my research has led me to believe that its a power supply issue. Problem is, there are 5 boards in the tv with seperate pwer supplies, and the 10 red flashes indicate that its all of them. :-(. Im shopping for a new TV, and It wont be a panasonic this time.
Posted on Mar 08, 2008
  • 20 Answers
SOURCE: my panasonic th-50pz800u won't power
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
Posted on Jan 04, 2009
dsacco86
  • 1077 Answers
SOURCE: TV clicked and went blank...no picture, no sound.
Most problems with TV not turning ON is a power supply related problem. The relay click are a normal process that powers up the circuit boards. Right now the TV is most likely in " Protection Mode ". The TV detected a bad circuit board and it will prevent the TV from fully turning ON. This keeps the other circuit board from being damaged. The power light blinking is a code.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet. This will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, blinking light codes, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jul 05, 2009
Dell xps touch sreen just blinking blue light but blank screen
Sounds like it went to sleep due to low battery power. May be time for a new battery if it isn't holding charge well.
Plug it into the wall and push the power button once. It may come back on. If not...
Hold the power button down until the machine shuts off completely. If that doesn't work, remove the battery.
Feb 04, 2015 | Dell Computers & Internet
My Panasonic TC-P50VT25 just went dead (blank screen). The power light blinks 13 times. I also noticed that the fans are not running.
The power supply is the first place I would start on this one. You will have to meter the outputs to the other boards to verify this.
Jan 29, 2015 | Panasonic Televison & Video
My panasonic plasma hd tv red light flashes 10 times and will not come on
Check its fan SOS board for fault. Visit this site for more details. Pull up older posts. Blinking codes to Panasonic Plasmas are given in detail.
Mar 31, 2013 | Televison & Video
MY SONY TV LCD MODEL KF-50WE620 screen went blank. When I turn on the green light it blinks on 40-46 times every second, then turn to red color to Stand mode and blinks for 160 times, then move to power...
There is no reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Tom Miller
Broadcast Eng
Mar 04, 2011 | Televison & Video
Sony KDF-46E2000 - Screen Goes Blank
The lamp can cause the picture to cycle without spitting out a lamp error. I'd replace the lamp and clean out the dust/dirt from fans, etc to hopefully resolve your issues.
Dec 06, 2008 | Televison & Video
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
Experttv@comcast.net
Sep 07, 2008 | Sony BRAVIA KDL-40V3000 Television
Picture went off then Red light blinks all the time
Not an easy fix....requires chassis pull, careful soldering and
replacement of parts and fuses.....would you like step-by-step?
........................T.
Jan 12, 2008 | Toshiba 65HX81 65" Rear Projection...
Power indicator light blinking
Check soldered in micro fuses...F850, F851 etc.....
1) solder jumper wires on signal board = 008,010,017,048,600
2) Check / replace STK392-110 convergence IC's with Toshiba
part # 23135090 or upgade to Hitachi part # CZ01341
Let me know....................T.
Jan 04, 2008 | Toshiba 65HX81 65" Rear Projection...
Panasonic TCP50VT25 50 in HDTVReady Plasma TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
