Question about Nutrifaster N450 1056 Watts Juicer
Loud pop when i turned it on
Turned it on and it made a very loud pop sound. turned it off cleaned it out and worked fine.
Russell Hobbs Juice Extractor Won't Start
if it is intermediate workings there is a micro switch that is a must so it wont turn on when your fingers are in it might have some junk in it clean your machine. look if the micro switch fell inside machine ?
May 12, 2014 | Juicelady JL500 Juice Extractor
No longer turns on
check the motor some juice might have been inside of motor has 2 brushes need to work prpoerly on 110 vac rated at 10 amps or better. clean your machine look for signs inside not on the city streets..
Mar 25, 2014 | Waring JEX 328 Health Juicer
My #6001 juicer ( old!!) will make a very loud sound even after only 3 carrots.. causing me to stop and clean out pulp.. even may shake more than usual... so am thinking it should need an overhaul??? I...
No overhaul. These juicers do not eject the pulp and are subject to vibration especially if you
install a new blade. I've had one for 21 years and get by using a worn blade which I sharpen
with an electric drill using a small bit.
Mar 03, 2011 | Acme 6001 Juice Extractor
I have model CL-003AP juicer and I cannot get the blade off for cleaning. I went to the instruction book, on line, and they say to lift and turn at the same time. This didn't work. What is your...
just take a dull butter knife or end of a spoon and gently pry it up in 3 spots or so as you go around. then when it is clean just pop it back on and push it into place ;-)
Jan 09, 2011 | Jack Lalanne Power Juicer 250 Watts
Loud "pop" noise as if
The reset button is actually a circuit breaker in miniature but there may be a thermal fuse to protect against fire in case of failure of the circuit breaker.
If you are game, open the housing again and look for a device you don't recognize that is in series (in line) with a wire; it may be in an insulating sleeve and not immediately visible, appearing only as a thickening of the wire. This could be a thermal fuse.
They are not supposed to open under load but only when the temperature exceeds a limit and these do not reset. Unfortunately, these are now all coming from China and are not very reliable so may open even when the design temperature is not exceeded.
If concealed, you would need a simple multimeter to determine if it had 'opened' by checking for the continuity of the wire stretch.
Blenders in general are 'universal' motors which can use AC or DC and this type employs carbon brushes which do abrade with time and when they have become too short, they can become intermittent and cause such a popping sound too. Brushes are replaceable so you might check Waring's website to see if they offer a fixed-price replacement or brushes as replacement parts.
I would be prone to see the Waring restored since most replacement blenders are from China and have often more than just one problem even when new. One given to us as a present smoked while crushing ice so we retrieved our old Oster from its stash and tossed the oriental wonder.
Jan 09, 2011 | Waring Juicers
How do you open the blade on the jui3567cer
open the blade? you mean get it out for cleaning? just pop it out by putting a knife or back of a spoon under it and gently pry it up in a few places. works like a charm, been doing it for 5 yrs
Jan 03, 2011 | Jack Lalanne Power Juicer 250 Watts
Cecilware frigodrink loud rattling noise
Two of the sping are not work
Apr 20, 2010 | Juicers
No manual, how do i clean/operate?
No tool necessary. Everything just pops apart. Clean-up was a breeze. Best machine ever.
Sep 01, 2009 | Jack Lalanne Power Juicer 250 Watts
Acme juicer
There should be a lug nut in the center that loosens so you can take the blade, basket & outer basket out to clean.
Jul 26, 2008 | Acme 5001 Supreme Juicerator Juice...
Juicers Logo
21 people viewed this question
Top Nutrifaster Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Nutrifaster Juicer Expert? Answer questions, earn points and help others
