Question about Nutrifaster N450 1056 Watts Juicer
Lots of vibration
I was juicing apples and got a grinding noise and lots of vibration really shaking bad. turned it off, took it apart, not much pulp because I had already cleaned it a little earlier.
The entire unit is vibrating so badly that it sounds like a stump grinder.
This is the nature of your machine, it does not eject the pulp, so it will tend to
go out of balance. Stay away from soft stuff like oranges. Watched a guy on
you tube demonstrating an Omega 1000, essentially the same as Acme, and
he had a hard time with the vibration. Nothing softer than apples and try to feed
it continuously (no gaps), slowly and evenly. Good luck.
Apr 22, 2011 | Acme 6001 Juice Extractor
I bought a used Acme Juicer 6001 and when it starts working it's ok, but after 1 or 2 minutes, it starts vibrating and goes like crazy. I only put shopped vegetables, like cucumbers, apples, celery, and...
Just the opposite. The only way I get by the vibration is with an old worn blade which
I sharpen with a drill using a small bit. Installed a new blade, once, and the juicer took
off on me. Even the pro's have trouble with the vibration issue. If trouble persists, try
a pulp ejecting type.
After juicing just a few fruits and vegetables the machine start jumping all over the counter and vibrating really fast.
There is no solution. These juicers do not eject the pulp and go out of balance very easily.
Don't feel bad, I've seen you tube videos where the demonstrator couldn't keep it under
control. If you are unable to master it, consider a pulp ejecting or masticating type juicer.
Mar 08, 2011 | Omega 1000 Juice Extractor
I have it for a few years and used very little, today it started to make noise and vibrate a lot, I disasembled it a few times everything seems all right but the vibrations did not stop, i am afraid of...
This is the nature of the juicer, it does not eject the pulp, and they go out of balance very
easily especially with a new blade installed. Only suggestion is juice only hard produce,
and feed it as evenly and as slowly as possible. I juice apples, carrots and celery.
Feb 17, 2011 | Acme 6001 Juice Extractor
My juicer moves a lot when juicing
They all vibrate no matter what you do. Best solution, costly, is to get a pulp ejection
type juicer. Miracle MJ1000 is a nice little juicer for about $130.
Nov 04, 2010 | Omega 1000 Juice Extractor
Too much pulp in juice
You need a new slicer with a finer mesh.
Dec 29, 2009 | Waring JEX450 850 Watts Juicer
Juicer works fine until slight pulp build up in
Unfortunately, since these juicers do not eject the pulp, they will tend to go out
of balance. Juice nothing softer than apples and try to feed it as evenly and as
slowly as possible.
Nov 27, 2009 | Acme 6001 Juice Extractor
Shuts itself off when juicing
FIRST DUMP THE FILTERS, THEY DECREASE YIELD AND MAY CAUSE MORE VIBRATION.
IF JUICER SHUTS DOWN PUSH RESET BUTTON ON BOTTOM. THIS TYPE OF JUICER DOES
NOT EJECT PULP AND REQUIRES SOME TIME TO MASTER. FEED THE STUFF SLOW AND
STEADY. WANT A GOOD JUICE? TRY 1 APPLE, 2 CARROTS, 2 CELERY AND A HALF LEMON.
IF YOU ARE REALLY BRAVE YOU CAN FINISH OFF BY SLOWLY POURING 6 OR 8 OUNCERS
OF WATER RIGHT DOWN THE CHUTE. THIS NOT ONLY DILUTES BUT LEECHES MORE JUICE
OUT OF THE PULP. JUICE SHOULD BE DILUTED AND DRANK SLOWLY.
Feb 27, 2009 | Acme 5001 Supreme Juicerator Juice...
Pulp splattered
Pour some water into it, at the very end.
Jan 06, 2009 | Champion G5NG853S Household Juice...
Pulp galore!
are you exceeding the capacity of the juicer? you will get about 2 and 1/2 large glasses of juice before the pulp fills the spinning basket. Apple peels are very tough, apples and tomatoes need to be peeled before juicing. Use the filters, the juice comes out much clearer and the juicer is easier to clean up. I so a lot of carrots, carrots are super food.
Nov 21, 2008 | Acme 6001 Juice Extractor
Juicers Logo
Top Nutrifaster Juicers Experts
David Payne
David Payne
Tom Chichester
Are you a Nutrifaster Juicer Expert? Answer questions, earn points and help others
