Question about Bosch WFMC 3200 Front Load Washer
Electrical/Rubber odor after complete cycle
I noticed an electrical/rubber odor after my last load completed. It was also making an unusual banging sound (i just figured it was out of balance so I didn't really pay close attention, and can't describe it). I cleaned the drain pump which smelled very foul, there was some **** built up but not an object causing an obstruction. I am hoping to troubleshoot the problem before having it fail during use. Any thoughts? It's about 12 years old and has been a great machine. I sure hope its not dying on me...
    Scholar:
  • 101 Answers
You have a drum roller that has a frozen bearing and needs to be replaced. The rubber smell is the wheel burning up.
Posted on Feb 12, 2014
  • 10 Answers
SOURCE: Bosch front load needs new gasket
i think you mean the (door seal), and yes they can be replaced and at little cost and little effort, with out knowing what model your machine is i cant give you an accurate price quote but should be able to pick one up for for next to nothing if you look around. happy to give instructions on how to replace the old one if needed.
Posted on Feb 22, 2008
SOURCE: New Bosch water not draining
Always leave the washer door open after use to allow inside to dry completely. Any remaining moisture invites mildew.
Posted on Apr 04, 2008
barkencoa
  • 3463 Answers
SOURCE: Oily substance collecting in the door's rubber seal.
It is not oil, but a build up of grease and living bacteria, caused by doing too many low temp washes.
The only permanent solution is to replace the door seal, and at least once a month, do a hot boil wash without clothes in, but with powder or detergent in as normal.
This is called a maintenance wash, and is now recommended by all manufactuers.
Please rate my solution.
Thanks.
Posted on May 13, 2009
SOURCE: Washing machine is not completing cycle
Had the same thing. Managed to sort it out by checking a few things and getting my hands dirty.
First things first: Remove the rectangular fascia at the bottom front of the machine - on my model you only need a coin to turn the two plastic screws. Unclip the black rubber drain pipe, remove the plug from the end and drain the water into a bowl (or several bowls).
Then undo the round plug at the bottom left of the machine (more water will come out) which will give you access to the extractor pump. Check that there are no obstructions in there and that the small propeller in there can turn freely.
If there is no obstruction there then we move onto the next steps.
If you can figure out how to remove the front of the machine then you will find this part easier - I couldn't so I ended up reaching in from the back.
First, TURN OFF THE POWER. Then, on the front of the machine, on the bottom left, undo the screws that fasten the extractor pump onto the front of the machine. Then pull the machine out from the wall so that you can get to the back of it. Remove the back of the machine by taking out the ten or so screws.
Looking in from the back: At the bottom-front-right of the machine you will see the extractor pump. It will have two hoses attached to it - a fat one and a slightly thinner one. Reach into the bottom of the machine and remove the power plug from the back of the extractor pump. Then, using a pair of pliers (or something similar) to open the spring clip, remove the thinner of the two hoses (the drain hose) from the pump unit. This can be fiddly - especially if you're doing it from the back of the machine.
Pull the hose out of the machine and check it for obstructions. If there are no obstructions in there then move onto the next step.
Reach back into the machine and, again using the pliers, remove the fatter tube from the pump. Remove the pump from the machine and check it for obstructions in the entry and exit holes, and also make sure that the propeller isn't obstructed. Then shake and squeeze the fatter tube to see if there is an obstruction in there (I had about five quids worth of change stuck in there which was where my issue was located).
If you've found no obstruction by now I'm afraid that I'm stumped :-(
Best of luck.
Posted on Aug 19, 2009
57 varieties
  • 1653 Answers
SOURCE: I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Posted on Oct 02, 2009
Samsung front loading washer started smoking while on spin cycle , new rubber seal an bearing ?
my first though would be to consider if its electrical smoke of friction smoke, chances are if it smokes on spin the motor is over heating and ready to pack in its operation, new brushes may solve the problem before buying a complete new motor.
Sep 21, 2016 | Samsung Washing Machines
Direct drive whirlpool washer has electrical odor and stops.
the burn odour and stoppage an electrical fault and coupled with a 20 amp circuit breaker tripping indicates a motor fault
Capacitors are tested with an capacitance tester and not an ohm meter as ohms is a resistance and not capacitance reading
When breakers activate it indicates a massive short or current draw and the problem could be in the windings of the motor
could be water getting into the motor at times causing the intermittent problem
I would suggest that you call in a service technician or an accredited electrician to check out the machine properly
Jan 20, 2016 | Whirlpool Washing Machines
How do I stop the old water smell (earthy odor) in my LG front load washer?
All washers keep a certain amount of water in them, though front loaders, especially the newer ones, are prone to odors. This is because the are more energy efficient and use less water. That can result in more residue being left behind on the outside of the wash drum where you cannot see it or access it to clean. Some things that are helpful:
  1. Do not close the door of the washer after use. It will allow the interior to vent and dry out, reducing odors.
  2. Use only the recommended detergents, and in the amounts recommended. Many people use too much soap in HE washers. A tiny bit goes a long way.
  3. Use a front loading machine cleaner - they are sold in most grocery stores. These help clear the residue from the drum, reducing odors.
Sep 01, 2015 | LG WM-2277HW Front Load Washer
Electrical/rubber odor when load is complete
Not many machines are belt driven these days, but the symptoms are those of a slipping belt, or friction against a failed rubber mount.
To find out more you will need to remove the case (or enough of it to see what happens while it is working.
Be on the lookout for some rubbery thing (either a part, or something from a previous load) jammed somewhere where the rotating drum scrapes it.
A burning rubber smell is different to a burning motor windings or transformer smell but maybe only to afficionados. Could be a winding failure on the motor too.
Unplug, un-case and plunge your schnozz into the works seeking the odiferous source. Sounds like I am kidding, but I am not - really try it. You may need to dry run it for a while to elicit the smell before unplugging etc.
Please post how you go, and what it eventually turns out to be.
Feb 03, 2018 | Bosch WFMC 3200 Front Load Washer
What is the bruning rubber odor - new dryer!
Im not familier with that particular machine but it sounds as though bits of the rubber backing you talk about has flaked into tiny bits and moved beyond the drum and into the workings of the dryer moter and heater. Contact with these will produce the smell and slight risk of fire.
The back of the applience will need to come off and cleaned out.How you accomplise this is up to you!!. If you have some one who is very handy at this sort of thing then grt.otherwise leave it to a proffesional. Obviosly compressed air gun is the way to do it.
Oct 15, 2013 | Maytag MEDE201YW Electric Dryers
Musty smell
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically. My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Aug 11, 2010 | Kenmore Elite 45986 Front Load Washer
My GE Front load washer (WBVH6240) has an odor that smells like mildew in it. If the is left closed the odor is really bad. Do you know how to fix this or what is comes from?
run a empty cycle with bleach on whites/ sanitize. clean boot (rubber gasket at door) with bleach or other cleaner inside especially at bottom, make sure 3 holes at bottom are clear.
this may take multiple cycles to rid of odor.
For maintenance, you should wipe excess water from boot after last load, and check lower drain holes. Once a month wipe boot with windex or other. and run cleaner cycle (empty) newer machines have a special clean washer cycle. (6240 doesnt).
Also clean your drain pump filter at bottom front behind access panel.
If boot is really bad , replace.
Jul 16, 2009 | GE WSXH208A Front Load Washer
My Frigidaire dryer makes a banging noise
What you have here is a drum bearing issue. Read my award winning essay on this subject right ova HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 09, 2009 | Frigidaire GLER642A Electric Dryer
Bosch WFMC 3200 Front Load Washer Logo
127 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
