Question about Kenmore Dryers
Replacing heating element in Kenmore model 110.65922
Model 110.65224. I attempted to remove the back panel, but found an uncovered element after removing the lower front panel. Most instructions suggested taking the back panel off to get to what appears to be an enclosed element, lying parallel to the dryer. However, when I removed the lower front panel, I can see what looks like exposed heating coils lying parallel to the floor toward the back of the unit. Could this be the heating element and why isn't it enclosed considering the amount of dust and lint produced by the dryer? Any advice is greatly appreciated. Thank you.
  • Kenmore Master
  • 3,904 Answers
The heating element will have multiple coils to it with two leads coming into it. POS/NEG. If that is it then it is very strange that it is not enclosed in some way shape or form.
Posted on Feb 12, 2014
  • 126 Answers
SOURCE: Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Posted on Dec 13, 2007
  • 13 Answers
SOURCE: dle5932w electric dryer
the back of the dryer have about 16 sheet metal screws.remove all the screws with a nut driver.the back should come off.
Posted on Jan 08, 2008
  • 1073 Answers
SOURCE: Replace belt on Whirlpool LE09508KQ1 Electricl Dryer
remove the lint fiter and remove the two phillips screws then lift the top up
you will find two screws on each side of the inside of the frount panel down about 4 inches , this when removed will allow you to swing the frount arround to gain access to the belt
Posted on Apr 30, 2008
SOURCE: Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Posted on Oct 07, 2008
SOURCE: how to remove lower front panel on kenmore 90
On my 7 year old Series 90 Dryer, I
- unplug the dryer
- use a flash light to locate the two black metal spring clips (located about 3 inches from each end of the lower panel along its top edge). They can be seen in the crack between the upper and lower panels.
- use a putty knife, or similar tool, to press down each clip while pulling out that edge of the panel.
- The panel slips off the lower clips easily.
- on some models there is a lone yellow wire with a connector on the end. If it is unconnected to anything, don't go nuts thinking that you have disconnected a wire by accident. Its one of those unused wires on some models.
- collect as many coins as possible before you vacuum the inside of the machine. Leaning the machine forward can often slide hidden coins to the front. BE SURE YOU CAN LEAN THE MACHINE WITHOUT HAVING IT FALL ON YOU. Otherwise, plan on collecting the coins from the vacuum cleaner when you finish.
- replace the panel by first threading the panel on to the lower clips, then closing the panel. CLICK, CLICK. FINISHED.
Congrats you have cleaned it, possibly avoided a house fire and added to the mad money collection. Hope this helped.
Posted on Jan 13, 2011
KENMORE DRYER JUST STOPPED HEATING UP WHAT CAN I DO TO REPAIR IT?
Replace the Heating Element. The heating element is usually located behind a panel on the back. To replace you will need to remove the back cover of the dryer, then locate the heating element. The heating element is screwed into place and is easy to unscrew and replace. Be sure to have the dryer unplugged while doing this.
Here is the part for it:
http://www.repairclinic.com/Kenmore-Dryer-Model-11060602990-ID-501912-Heating-Element-Parts
Mar 13, 2013 | Dryers
Kenmore Electric Dryer 110.62922100/Runs but no heat
When theres no heat check these
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 03, 2008 | Kenmore 63012 Electric Dryer
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
Kenmore Elite electric dryer-65942401 and it runs but does not heat. I have heard that best thing to do is replace heating element, but is there anything else that needs replacing along w/it, and we can't...
You need to check the breaker, often the heat 1/2 of the 220 volt breaker trips and is not visually obvious. Best to know so check with a volt meter, or forceably turn off the breaker, FULLY off, press hard, and then back on and test again. If it keeps happening, you may need to have an electrition investigate.
There is very little failure of heating elements, but not unheard of. More common is a bra wire shorts the element. remove it and often you are good to go, but sometimes it burns through.
Oct 13, 2010 | Kenmore 65942 Electric Dryer
No heat in kenmore series 80, model 85040
hello there:
here is some troubleshooting ideas for you to help
A dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty
Oct 26, 2009 | Kenmore Dryers
Kenmore Dryer won't heat.
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Sep 09, 2009 | Kenmore 64902 Electric Dryer
Need to replace the heating element in stackable Kenmore model 417.98702891
Go to www.repairclinic.com and enter 417.98702891. You will be presented with a list of common replacement parts and may be able to view a generic Sears video showing disassembly with identification of various parts.
Mar 11, 2017 | Kenmore Dryers
How to replace heating element, kenmore model 110.60912990
lint screen in door ? remove bottom apnel ..top lint screen remove rear panel both cases ckd thermal fuse on top end also
Jul 03, 2008 | Dryers
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Mar 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
172 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
