Question about Sansui HDLCD3250 32 in. LCD TV
Cover Removal How do I remove the rear cover Sansui HDLCD3250B Television. I've removed all screws but the cover wont seperate. Am I missing something?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
This is not the same model Sansui, but it is a tv.
http://youtu.be/qMpiC8YL3SE
Posted on Feb 12, 2014
Changing the fuser for a CM1415fnw
If your capable of searching google, you may want to grab the service manual for this, heres the procedure to change it out but as you can see there are even more procedures along the way...
Fuser 1. Remove the following components: ? Right cover. See Right cover on page 17. ? Right-front cover-1 and cover-2. See Right-front cover-1 and cover-2 on page 20. ? Control panel. See Control panel on page 22. ? Left cover. See Left cover on page 25. ? Document-feeder and scanner assembly. See Document-feeder and scanner assembly on page 28. ? Rear-center cover. See Rear-center cover on page 30. ? Rear-upper cover. See Rear-upper cover on page 31. ? Speaker. See Speaker on page 33. ? Top cover. See Top cover on page 34. ? Rear door and rear-lower cover. See Rear door and rear-lower cover on page 41. 2. Remove two screws (callout 1) and the black plastic cover (callout 2). Figure 1-117 Remove the fuser (1 of 4) 1 2 80 Chapter 1 Removal and replacement ENWW 3. Disconnect five wire-harness connectors (callout 1). Remove the wire harness from the guides (callout 2 and callout 3) and one retainer (callout 4). Figure 1-118 Remove the fuser (2 of 4) 2 1 3 4 4. Remove four screws (callout 1). Figure 1-119 Remove the fuser (3 of 4) 1 ENWW Removal and replacement procedures 81 5. Remove the fuser. CAUTION: Handle the fuser carefully. The sensors that are mounted to the output side of the fuser can be easily dislodged. When the fuser is reinstalled, make sure that the sensors are present, and correctly fastened to the fuser assembly. Figure 1-120 Remove the fuser Hope this helps...
Feb 16, 2014 | HEWLETT-PACKARD CM1415fnw AllInOne Laser...
Replacing battery on Aston Martin Vanquish
Below is the procedure for an Aston Martin Vantage, perhaps the vanquish is similar?
Removal
1. Power the driver's fully forward.
2. Remove rear compartment cover.
3. Loosen and disconnect battery terminals, earth (- ve)
terminal first.
4. Release rear carpet, studs (x2), move carpet aside.
5. Remove screws (x2), battery compartment cover to
support rail.
6. Remove nuts (x2), battery compartment cover to body.
Remove cover.
7. Remove Torx screws (x4), remove battery clamps (x2).
8. Disconnect battery vent tube.
9. With assistance, remove battery.
Installation
1. Clean battery tray and clamps.
2. With assistance, install battery into its compartment.
3. Connect battery vent tube.
4. Position battery clamps (x2), install and torque tighten
Torx screws (x4).
5. Ensure battery vent tube is not distorted by battery.
6. Install battery terminals, tighten terminal nuts to correct
torque.
7. Install battery compartment cover, install and tighten
screws (x2) and nuts (x2).
8. Position rear carpet, secure with studs.
9. Install rear compartment cover.
10. Reposition driver's seat.
Courtesy of pistonheads.com
Please vote if this helps! Thanks, Mike
Jun 12, 2011 | Aston Martin Vanquish Cars & Trucks
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
Jan 14, 2011 | 1999 Ford Taurus
Do I remove the entire cover or the little door thats atached to this cover on the passenger side? There are 3 brake lights that were recommended to replace. Driver side and passenger side plus the third...
Lamp, Rear Hi-Mount Lamp Assembly
Removal
  1. Disconnect the battery ground cable (14301) .
  1. Raise the liftgate.
  1. Remove the liftgate door trim panel (46404) . Refer to Section 01-05 for the removal procedure.
Trim Panel, Liftgate Door Removal
  1. Disconnect thebattery ground cable (14301) .
  1. On vehicles with a rear window wiper, remove the three rear wiper motor cover screws and remove the rear wiper motor cover.
  1. Pry the liftgate door trim panel (46404) away from the liftgate.
  1. Disconnect the luggage compartment lamp electrical connector.
  1. Rotate the rear hi-mount lamp socket counterclockwise and remove it from the rear hi-mount lamp (13A613) .
  1. Remove the two rear hi-mount lamp housing nuts and remove the rear hi-mount lamp lens and housing.
Oct 18, 2010 | 1995 Ford Aspire
The brake lights that we need 2 fix r on the trunk /hood.( what holds the spoiler if there was 1) looked all over. either cant find or see or get 2 it?
This is right out of the manual. Hope it is what you are looking for. Cobra. :-) Lamp, Rear Hi-Mount Removal
  1. Slide rear hi-mount lamp cover (13A656) away from back window glass (42006) and remove rear hi-mount lamp cover.
  1. Remove one screw retaining rear hi-mount lamp (13A613).
  1. Lift edge of rear hi-mount lamp and pull away from back window glass.
Installation
  1. Slide rear hi-mount lamp cover onto rear hi-mount lamp to engage retainers.
    Hi-Mount Rear Lamp
    Item Part Number Description 1 921 Bulb 2 56929-S2 Screw 3 13A613 Rear Hi-Mount Lamp 4 13A656 Rear Hi-Mount Lamp Cover 5 15A442 Rear Hi-Mount Lamp Wiring
Jun 05, 2010 | 1997 Ford Thunderbird LX
Need a diagram for installing a drivers side electric power mirror on a 1995 mercury villager van
here's 1996, all I have. Please rate.
Mirror, Power — Outside Rear View NOTE: This procedure applies to both RH and LH power outside rear view mirrors.
Removal
  1. Remove the front door trim panel (23942). Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws and the outside rear view mirror mounting hole cover (17K709) from the front door (20124).
  1. Remove the wire clip.
  1. Disconnect the power outside rear view mirror electrical connector.
  1. Remove the three power outside rear view mirror bolts and the power outside rear view mirror.
Installation
To install, reverse the removal procedure. Tighten the three power outside rear view mirror bolts to 3-4 Nm (27-35 lb-in). Glass, Outside Mirror
Removal and Installation
Refer to the glass replacement procedures in Manual Mirror for power outside rear view mirror glass (17K707) Trim Cover
Removal
  1. Remove the front door trim panel. Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws.
    Remove the outside rear view mirror mounting hole cover.
Installation
To install, reverse the removal procedure. Mirror Control
Removal
  1. Use a small flat-blade screwdriver to pry the power outside rear view mirror control switch from the instrument panel (04320).
May 13, 2010 | 1995 Mercury Villager
Screen Removal - Mitsubishi WD-62527
SPEAKER GRILLE Removal
Pull the SPEAKER-GRILLE away from the cabinet to remove.
SCREEN-ASSY Removal
1) Remove 10 screws (a) from the upper cabinet rear cover (3 screws on each side and 4 screws across the
top).
2) Remove screws (b) along the bottom of the SCREEN-ASSY (8 screws on 52 inch models, and 12 screws
on 62 inch models),
3) Unplug the LL connector to the front CONTROL-PANEL.
4) Lift the SCREEN-ASSY up slightly and then pull away from the cabinet.
CABINET FRONT DISASSEMBLY
Aug 01, 2009 | Mitsubishi WD-65735 Television
On an 05 escape there appear to be only 2 screws holding the brake light cover. I've taken them off but the cover seems really secure along the outer edge and the body panel. I'm if I give it a good yank...
here is 2003. I don't have 2005. SHould be similar. Please rate as fixed if this helps.
SECTION 417-01: Exterior Lighting 2003 Escape Workshop Manual
REMOVAL AND INSTALLATION Rear Lamp Assembly Removal and Installation
  1. Remove the rear lamp assembly.
    1. Remove the bolts.
    1. Pull straight back to remove the rear lamp assembly.
  2. Disconnect the electrical connectors.
Apr 28, 2009 | 2005 Ford Escape
I am not getting fuel to my engine
Removal
  1. Relieve the Fuel System Pressure . Refer to the procedure in this section.
Cushion Cover and Pad, Rear Seat — One-Piece and 50/50 Split Fold Removal
  1. Remove the two rear seat cushion bolts.
  1. Fold the rear seat back cover and cushion (60084) forward.
  1. Carefully pull the rear seat cushion and cover (60030) out from under the rear seat back cover and cushion and remove the rear seat cushion and cover from the vehicle
  1. Remove the rear seat cushion and cover (60030). Refer to Section 01-10 for the removal procedure.
  1. Remove the three luggage compartment floor cover hold-down pins and fold the luggage compartment floor cover (45455) forward until the fuel pump assembly access plate is visible.
  1. Remove the four fuel pump assembly access plate screws, the ground lead, and the fuel pump assembly access plate from the chassis.
  1. Disconnect the fuel pump assembly electrical connector.
  1. On 4-door vehicles, remove the fuel vapor tube shutoff valve bolt and the evaporative emission tube shut off valve (9G332) from the bracket on the fuel pump assembly housing.
  1. Loosen the two hose clamps and disconnect the two fuel pump hoses from the fuel pump hose fittings on the fuel pump assembly housing.
  1. Remove the four screws (2-door) or eight screws (4-door) and lift the fuel pump assembly housing from the fuel tank (9002).
  1. Disconnect the fuel level sensor electrical connector.
  1. Remove the two fuel level sensor washers and fuel level sensor nuts and the fuel level sensor.
Section 10-01: Fuel Tank, Filters, Lines and Electric Fuel Pump 1996 Aspire Workshop Manual
REMOVAL AND INSTALLATION Fuel Pump Removal
  1. Remove the fuel level sensor. Refer to the Fuel Level Sensor removal procedure in this section.
  1. Remove the fuel pump screw, fuel pump grommet and the fuel pump bracket from the bottom of the fuel pump (9350).
  1. Remove the fuel tank sender filter bracket, fuel tank sender filter (9A011) and the fuel tank sender filter retainer from the fuel pump.
  1. Disconnect the fuel pump electrical connector.
  1. Remove the clamp and the fuel pump from the fuel pump assembly housing.
Apr 19, 2009 | 1995 Ford Aspire
Front cover removal on Panasonic CT-36HL42C
You have to remove the entire rear case to access the video input(s) panel. There are quite a few screws. Be careful when removing the case because there is an internal wire connected from the inside back of enclosure to the main power board.
Jan 07, 2009 | Panasonic CT-36HL42 36" TV
Sansui HDLCD3250 32 in. LCD TV Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
