Question about Brother IntelliFAX 4100e All-In-One Laser Printer
Stop intellifax 4100e change drum message
Turn off change drum message
  • 8 Answers
SOURCE: Fax Problem
Once you have changed the drum unit on Brother 4100 you will need to keep the front door open and then press the option button. Your dispay should give show you a drum change option. press 1 to change drum and the machine should show "accepted" after a few seconds. Afterwards, close the door.
Posted on Jan 04, 2009
leroyal
  • 2120 Answers
SOURCE: change drum soon
Instructions are in the box that the new drum comes in.
Posted on Jan 13, 2009
  • 105 Answers
SOURCE: how do i reset the message change drum soon on
Press Clear.
8 Press 1 and when the LCD shows ACCEPTED,
and then close the front cover.
Posted on Jun 05, 2009
MalKontent68
  • 748 Answers
SOURCE: Brother IntelliFax-4100e Fax Reset drum counter
With the front cover still open, you should press Clear ("Replace Drum?" should appear on the display), and then 1 for Yes. Wait for "Accepted" message and close cover.
It may be necessary to remove the drum unit and put it back in, and then, with the cover open, do the a/m procedure.
Posted on Nov 07, 2009
  • 18 Answers
SOURCE: How do you remove top cover on Intellifax 4100e?
Unplug the machine, lift the front of the control panel, at the back of that panel you will see two arms that the cover pivots on. Gently spread them apart while lifting up, not to hard or you will break them. Once it begins to lift out pay attention to the single connector at the back right, remove that connector and place the control panel to one side. Now you will see 2 screws on the front of the feed asembly, remove those. Lift the front of the feed unit up while looking under the front you will note 2 more connectors, one to the scanner and one further back to the drive motor. They are also wrapped around a couple of tie downs. Unwrap and then disconnect the connectors and remove the feed unit. Turn the feed unit over and look at the scanner,at one end you will see a plastic tab, you will press that out of the way and you will be able to slide the scanner back about half an inch. turn it back ovr and remove the scanner. Note that you do not lose the 2 small springs under the scanner. Slide new one in and reassemble. Have fun.
Posted on Jan 20, 2010
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
Brother IntelliFax-4100e There is a message on the screen to change drum, and I already changed it. Also, there is a squeggy noize everytime we receive a fax. I tried taking the drum, carthridge and I...
1. Open the front cover and then
press Clear.
2. Press 1 to reset.
However, the drum may be defective and causing the noise. Try a different one if you can.
Nov 16, 2010 | Brother IntelliFax-4100e Fax
Fax machine says: Printing Online on its LCD readout but won't print anything. We have replaced the drum and the toner. We can't get the message to clear either
Press "Menu" & "Mode" keys. Display should clear. Then press 0, enter 91. Hit stop after completion. THIS WILL CLEAR ANYTHING IN MEMORY.
Aug 17, 2010 | Brother IntelliFax-4100e Fax
Nov 07, 2009 | Brother IntelliFax-4100e Fax
My intellifax is pirnting all faded on the left side but not the right.
have you tried changing the drum imaging unit? It could either be a toner cartridge problem or the drum unit needing replacement. If it's new toner or new drum and this problem started since changing to the new, you may be able to get a replacement at no charge or a refund.
Hope this helps.
Nov 02, 2009 | Brother IntelliFax-4100e Fax
LED Message on Brother Intelifax 4100e says replace drum; drum has been replaced, but message is still showing
follow the instructions below:
  1. Open the front cover.
  2. Press the Clear key.
  3. Press 1 to reset.
  4. Close the front cover, pressing firmly on each side until they click into place.
Sep 01, 2009 | Brother IntelliFAX 4100 Laser Fax
Change drum soon
Jan 13, 2009 | Brother IntelliFAX 4100 Laser Fax
Fax Problem
Oct 28, 2008 | Brother IntelliFax-4100e Fax
Brother IntelliFAX 4100e All-In-One Laser Printer Logo
16 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
