Question about Reliable Irons
Reliable i300 breakdown - Reliable Irons
Reliable 200ir smoking
Replace the iron.
Jul 24, 2017 | Reliable Irons
My Reliable steam iron mod.V100 is not getting hot. ANY SOLUTION?
probably thermostat or element
junk it and buy a new one
May 31, 2016 | Reliable Irons
One igniter won't fire?
I appreciate your inquiry, Mark Waggoner!
From what you have described one igniter on your Frigidaire range will not start. It sounds like a possible issue with the burner or igniter. I was unable to locate any steps on how to disassemble your range. I did locate a parts manual which provides a through breakdown of all the parts within your range. If you continue to have issues I would suggest contacting a technician for proper disassembly of your range. I hope this information provided is helpful. -Matt
Frigidaire Manual Search Results
Jan 05, 2015 | Frigidaire FGF337GB Cooking Products :...
I wanna know how to fix Andis superliner clippers.mine just simply dont cut anymore??someone please help
If the clippers stopped cutting, they are probably clogged with hair on the inside of the clippers. I had two pairs of clippers where this happened. I took them to be serviced at a beauty supply store and they cleaned the hair from the inside of both pairs of clippers for me and they now work just fine.
Jul 12, 2014 | Andis SuperLiner Trimmer 04810
Wet steam coming out of iron
You have to take part the iron by unscrewing the three bolts on the side handle with a small phillips driver. Then loose the allen screw on one side of the black thermostat wheel to unloosen it. Then take out the two bolt plastic protectors under the handle and unscrew the two allen bolts, carefully separate the top from the botton of the iron, carefully not to pry loose the cables from the top to the hot shoe.
On the back you will see a small white square box, that is the thermostat, which has a button on top, all you need to do is to push it in. This will make the iron heat up unless you have a thermostat failure (Black wheel with temperature indicators), which you will need to order the part and change it.
Mar 07, 2013 | Reliable i30/120V Professional Steam Iron...
Iron only stays hot enough to iron for about 2 minutes. The red light blinks except for that time.
I suggest contacting Rowenta; if you check here at FixYa, you'll find a spectrum of problems with what should be a simple, reliable device. Several instances of the iron not turning off at all until the plug is pulled from the wall, several others that fail to turn on at all. This once was a good company and it wouldn't surprise me to find that they are now made in . . . China.
Nov 12, 2009 | Rowenta DZ1700 Iron
Rowenta DZ9080 Iron with Auto... Problem
Hello, All High grade silicones are inherently heat resistant. Look for the best silicone you can find in a tube. The higher the cost of the silicone the higher the quality. You might even try automotive gasket sealer if you want to be absolutely sure of heat resistance. This will be off an orange or blue color though.
If You need mare help feel free to contact me.
George
Jul 24, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Rowenta iron manual needed
If you dropped it it will probably be an easy fix. Just openup the unit and look for a crack in the cicuit board. This is the case 99 percent of the time in apliance drops. If you find a crack in a board simply epoxy it and on the cicuit side of the board solder jumper wires from point a to point b when you follow the boken trace(s). If more than one trace is broken repeat the process until all the circuits can be repaired. Make sure you use wire of a high enough rating to handle the current the trace handles, and also use wire with heat resistant insulation in this application.
First things first though. Just open it up and have a look. The plug to the heating element may have just been knocked off. With a little trouble shooting skills and a good look you should be able to see your problem. If you get it open and see something I did not tell you how to fix just post any question you have and I will answer them for you.
George
BRown water and stuff coming out of iron
Hi, two problems:
DIA' s problem - the brown water is due to poor water quality and debris in the boiler and iron sytem. Rowenta is clear that they do not want anyone to cleaning solutions - only clear filtered drinking water to rinse out the boiler (via the water inlet screw hole) and I have found running the system dry, letting it cool, rinsing and draining the boiler several times before putting unit away works fine.
Guest' problem with brown/black tar substance is likely caused by too hot and iron setting (steam setting may also be too high) for ironing man-made synthetics (like Nylon, Rayon, Polyester or blends are basically petroleum based fabrics) that breakdown or melt, leaving deposits on the iron's stainless steel soleplate. A secondary cause could be bad water or debris in the boiler/iron in which the solution for DIA's problem might provide relief. Cleaning the soleplate is tricky, I use nothing stronger than an old fashioned wooden orange stick to gently scrap of all traces of the "stuff" and dry "Dutch" cleanser w/ a terry cloth or old cotton sock to polish without scratching the soft stainless soleplate...
Apr 01, 2008 | Rowenta DG-980 Iron
Irons Logo
41 people viewed this question
Top Reliable Irons Experts
Are you a Reliable Iron Expert? Answer questions, earn points and help others
