Question about Plantronics 85801-01 C435-M Blackwire 435 Microsoft
Blackwire c435 echo whilst talking - Plantronics 85801-01 C435-M Blackwire 435 Microsoft
I have a Westinghouse POR881 built in oven. It has power but will not work. When switched off an back on it flashes up with F028, C435, P022.
here is their tech support number and it should be no cost to talk with them.1-877-477-7278. hope this helps.
Nov 29, 2015 | Ovens
I have a echo in my iphone when talking
it is may be not your problem. Problem Belongs to whoom your are talking with. He/She may be useing loude speakers. Or it can be problem of your mobile Service provider. Upgrade your cellphone iOS.
Apr 06, 2014 | Apple iPhone 4S
My radio squeals with echo when my amps on
adjust your talkback to just open then set your echo to where you want it. Now turn your amp on and re-adjust both the talkback and the echo . If you have a speaker nearby the radio may be feeding back through it so move it away from your radio . Now start talking with the mic and adjust your echo because you should be able to hear yourself talk through your talkback.
Dec 21, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
Hi, where can i find drivers for my Plantronics Blackwire C420-M, please ?
Here is the link; http://www.plantronics.com/hk/product/blackwire-400
Just click on software and then get its drivers and software.
Wish you best of Luck
Aug 13, 2012 | Acer Iconia Tab A50110S16u 101Inch HD...
I need to know what splitter I can use for a Plantronics Blackwire C220 headset. I need to be able to plug in 2 headsets and use one to listen only and one to talk and listen. Please tell me what splitter...
There is not a USB splitter for computer headsets like the Plantronics BlackWire C220, you would have to go to a commercial grade headset to have that function. You can use any of the Plantronics "H-series" headsets with the Plantronics Y-training cable (model 27019-03), along with a USB adapter like the Plantronics DA40 or DA45 for training purposes.
Good luck from Headsets Direct!
Sep 14, 2011 | Plantronics Blackwire C220 Headset
I can hear, but no one can hear me when I speak.
Make sure the Blackwire C420-M is the default device selected in your Sounds and Audio Device Properties under Sound recording.
Jun 10, 2011 | Plantronics Blackwire C420-M Headset
Where is the circuit breaker or fuse on a Kenmore Gas Dryer?
no heat usually means your only getting110 volts into your dryer.....you need the full 220volts to run heaters....with voltage meter you checkwires on the plug OUTLET...or inside back cover REDwire to WHITEwire =110v.........BLACKwire to WHITEwire =110v.....REDwire to BLACKwire =220v. you probably have aBAD 220V. 30 amp circut breaker..or if still using FUSES one is burnt out (In house electric panel) or burnt off RED or BLACKwire in back of dryer.....
May 09, 2009 | Kenmore 63942 Dryer
Echo while talking to some other phones
U see echoing isnt d problm f the phone... It`s the pbm of d service providers (yr network)....dnt worry they usually get repaired when the correspondn frequencies are altered.....
Apr 12, 2009 | Vtech Cordless 6041 Phone
Echo while talking on phone
I have a panasonic cordless 5.8ghz I hear an echo when I talk to someone . Can you please tell me how to get rid of it
Jul 07, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
Kenwood kvt 729dvd
connect the green wire from head unit to ground perminetly
Feb 02, 2008 | Kenwood KVT-617DVD Car DVD Player
Plantronics 85801-01 C435-M Blackwire 435 Microsoft Logo
21 people viewed this question
Top Plantronics Lands Phones Experts
Andrew Taylor
Andrew Taylor
Are you a Plantronics Lands Phone Expert? Answer questions, earn points and help others
